Question about Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed
My mower will run for a bit then start dieing
I put gas in my mower and started dieing so i empted the gas out and chaned sparkplug and fuel filter.It worked for a few mins and died again..i took the top off and removed the rust from the magnet and ran a little longer but died again can u please help me any at all..thanks j.taylor
    Problem Solver:
  • 4 Answers
Sounds like there may be trash in the carb. when the gas bowl is full it runs until the gas runs out then it dies. Take the breather off get it started and then put you hand over the intake on the carb. sometimes this will allow the trash to be sucked on through do this several times take your hand off before the motor shuts down and then do it again until you clear it up. If this does not fix the problem you can take the bowl off the carb an see if it is getting fuel with the float hanging down this opens up the needle valve to let gas fill the bowl. there should be a steady stream of gas coming out. when the bowl fills up the float floats up and closes the needle valve. If there is not a steady stream of fuel coming out with the float hanging down with the bowl off you may have to remove the float and needle valve and clean out the needle valve jet with something like a sewing needle. If you are getting gas steady and fire to the plug it should run.
Posted on Jun 05, 2009
My john deere riding mower model # lt160 will not start. what could it be?
Check fuel line. It could be stopped up. Also check inline filter or in tank filter for trash.
Nov 29, 2014 | John Deere Garden
Why does my lawnmower die after starting?
What does cleaned it "somewhat" mean? You need to rebuild it, not just clean it. Buy the proper kit for it and rebuild it.and make the proper adjustments to it after you put it back together. If you're not sure. When you take it apart slowly turn in the adjusting screws and count the number of turns until it bottoms out, then reset it to that number after you rebuild it, that should get you close enough for it to run properly.
Aug 11, 2014 | Garden
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
Mower tries to crank but want start up? Replaced sparkplug , oil filter has gas
Pull the spark plug and squirt alittle bit of gas or starting fluid directly into the cylinde rand reinstall plug . It will fire I promise. Repeat if necessary untill it stays running. Hope this helps
Nov 04, 2010 | Craftsman 21 Hp 42" Lawn Tractor Riding...
Starts ok but dies out. has new sparkplug and air filter.
Carb might have dirt in it or the float is out of adjustment and only allowing a little bit of gas in it. Enough to start it but not enough to keep it going. Clean and adjust float.
Jul 09, 2010 | Craftsman Garden
WILL NOT START
Ok...time to take her pulse then!
1. Does it have fuel? Look for water in fuel *(check gascan too!)
2. Does it have spark? You need to remove the plug and inspect it. do you see any oil, fuel or even water on the plug tip? You can plug in the sparkplug and dangle it near the metal part of the engine and confirm that the plug makes spark. If it doesnt get another one just to make sure the plug isnt fouled out.
3. Can the engine breathe? Remove the air filter and see if the filter is oil,water or fuel soaked. Is it rusty? Covered in dust, dirt, fuzz or fur?
You can check the engine once you are sure you have spark by putting a splash of fresh gas in the sparkplug hole before putting the plug back in and attempting to start it....leave the air filter off for now. You dont want a bad filter getting in the way right now. If it starts and runs you can put the air filter back on and try to start it....if it wont start....replace filter too!
Good luck and be careful!
Jun 28, 2010 | Briggs & Stratton 190cc 875 Series OHV...
Lawn mower starts and runs until I start pushing it, then it just dies out.
Sounds like the carburetor is gummed up. Short of taking the carb off and cleaning, some good fuel line/carburetor cleaner such as Gumout (available at any place that sells auto oil/filters, etc. Wal-mart, K-Mart, Autozone). Put a bit of fresh fuel in the gas tank and add about 2 or 3 Tablespoons of fuel line cleaner. Start mower and let it run a bit. May run rough, but should clean the carb out unless plugged bad. If this doesn't work, the carb will need to come off and be cleaned. Can be done by the homeowner, but if you are nervous about tackling this job it may be best left to the mower shop.
Nov 29, 2009 | Craftsman Garden
Lawnmower starts but won't continue to run
if you are getting no fuel to the plug you either have a stuck float, plugged fuel line or filter. does the gas reach the carb bowl? does the mower have a fuel pump? if so the diaphram might be bad.
Jun 30, 2009 | Garden
Lawn mower dies
Find the fuel air mixture screw and while the mower is running turn so mower almost stops then turn them back till the moter is running smoother.Give it some throtle to see & hear how it is running
Nov 02, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed Logo
229 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
