Question about Ricoh Office Equipment & Supplies
Error 0322H on a Ricoh 4410L fax machine. What does it mean?
  • 3 Answers
I had the same problem and when i replaced th toner it was ok
Posted on Jul 15, 2009
It's a serious problem, that will require a tech and parts, if you want to spend the money. Following are the possible causes of your service code: ? Synchronization detection mirror defective ? LD unit defective ? FCU defective ? LD harness damaged ? THM not in place
Posted on Jun 06, 2009
What is mean by ajouter du papeir of ricoh fax 4410L
It only means "Add paper" and i'm sure they are telling you to use the same brand name of your copier(which is a Ricoh model 4410L).
Jun 11, 2013 | Ricoh Office Equipment & Supplies
Fax Machines Ricoh Fax 4430NF error 0550H "call
Easy !
Press yellow button
Enter numbers: 107
Push red button for 5 seconds
Press number: 1
Enter: 5#810#
Press number: 1
Press (Half)tone and OK button at the same time for some seconds.
DONE ! Greet Barry
Feb 01, 2011 | Ricoh 4430NF Laser Fax
Ricoh 3310l fax shows error code 0390H in display. Anyone know what this means?
I've never seen a message like that with the 0390H code. There is no mention of that code in either the user manual or service manual. The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that problem.
If the new PCU doesn't fix the problem, you might want to try calling Ricoh for support, since their documentation doesn't mention that code.
Jun 11, 2010 | Ricoh 3310LE Plain Paper Laser Fax
Won't always transmit the fax.
what is the error code? the solution is to find the error code and what it means in the manual.
Oct 22, 2009 | Ricoh FAX3900L Plain Paper Laser
Ricoh fax error #400
Possibly the fax line is open (busy). Try ringing the fax number, see what you get. Try unplugging the fax and plug a normal analogue handset into the line. See if you are getting a dial tone.
If not, then the cabling or line are faulty. Talk to your carrier. If yes then replace the cable on the fax (if possible) or have it looked at.
Mar 03, 2009 | Ricoh Office Equipment & Supplies
Ricoh Fax 3800L Error code
Hi there the error code that you are getting appears to be for the left lock where the fuser is make sure that the door is shut fully and turn the machine off then on again if this doesn't work then it is more likely to be the laser unit and this will need replacing.
Hope this is of some help to you.
Thanks J
Nov 07, 2007 | Ricoh FAX3800L Plain Paper Laser
Fax machine error
HI,my fax machine couldn't send and receive messages.it shows me an error code that read as 0552H call service....what does it mean..? please help me.
Jan 29, 2007 | Ricoh FAX5510L Plain Paper Laser
833 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
