Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
No power at all
Would not drain water so disconnected and drained standing water but no power at all. is there a reset or should i look to the breaker
  • 6,784 Answers
Check The following components below to address this issue.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer/control
Replace if defective (note: uncommon problem).
4. Selector switch
Posted on Jun 04, 2009
Drain water light is blinking unit wont power on
Make sure the unit is on a flat, level surface. If the floor is not level or the carpeting is too thick, the unit will not be level, causing the water in the internal tray to flow to one side. This will bypass the water full safety mechanism and the unit will not automatically shut off.
Check for broken or damaged casters. Check to make sure the casters are installed securely and evenly.
Check and make sure the drain cap and/or the rubber plug is installed. If cap or rubber plug is missing, use a cork. Check and see if the drain is cracked or broken, if so, shave broken drain flat and use a cork. You can use a plumbing adhesive or epoxy to repair the drain.
And regarding that the unit is not powering on i would suggest you with the following things.
Test the outlet that the PAC is plugged into is working. If the outlet is working than the powerplug breaker needs to be replaced. If the wall outlet is not working, there may be too many appliances on one circuit. Recommended circuit is 20amps. You can also administer a power plug check: Power Plug Check
1. Press the RESET button. The reset button may be stubborn so you will need to press HARD to reset it until a click is heard and the light comes on.
2. Insert the power plug into the electrical outlet.
3. Press the TEST button. If the circuit breaker is working you'll hear a click.
4. Press the RESET button until you hear another click. The circuit breaker in the plug is now activated.
5. Do not use the air conditioner if the above procedure cannot be successfully performed.
After switching the air conditioner off, wait 3 minutes before switching it back
Jul 18, 2015 | Heating & Cooling
FAULT E6 ???
In general- flood switch sensor, water level control system/electronic control panel failure; Interrupted drain cycle emptying water.
Depending upon make and model of your dishwasher: check water pan in the base pan; clogged filter; cracked or leaking spray arm; door seal, kinked drain hose; damaged or disconnected wires at the control panel; pressure switch fault; drain pump fault.
If you choose to troubleshoot the problem, make sure you disconnect the dishwasher at the power source; whether it is a plug in the outlet or at the circuit breaker- you'll need a multimeter and various size or type nut drivers, screwdrivers, or sockets; and pliers ~ or else call in a qualified technician.
Mar 05, 2015 | Dishwashers
Hi! I have Whirlpool ADP6948 dishwasher. It's
Hi.
F4 points at at a drain problem, often the problem is caused by a dirty or defective pressure switch. Before replacing the pressure switch it is necessary to test the drain system.
First try turning power off from circuit breaker for few minutes and see if that is enough to clear the error code.
Turn power off from circuit breaker (or disconnect power cord) and clean the drain well inside the tub. Remove any water present in the tum. Check also the drain hose at the back of the appliance and make sure it is not kinked or blocked.
If that does not work remove the kick panel at the base of the dishwasher, locate the pressure switch and clean the hose connected to the pressure switch. The pressure switch is the device that detects water level, determining when to start and stop the drain pump. The pressure switch is a small plastic switch connected to a long rubber hose. If the hose gets blocked with detergent or if the switch is defective you get f4.
Resuming:
Try resetting the appliance to clear the error code.
If that does not work clean and check the drain system.
If still no luck check the pressure switch.
Disconnect power before doing any maintenance.
Regards.
Ginko
Aug 31, 2011 | Whirlpool Dishwashers
A/c will not work freon is to specs fuses are good relal is new
Sorry, but not enough information.
Required information:
Is the inside unit running, if yes is the contactor pulled in outside. If no try locating float switch on emergency drain pan ( could have a clogged emergency pan drain line)
Any further information you could provide could be useful in diagnosing your problem
Refrigerant type
Refrigerant Standing Pressure
Power at Disconnects for A/C units and if so whats the voltage
Breakers in Electrical Breaker Box (Any Tripped or in the off Position)
Water present in emergency pan underneath Air Handler
What pieces of the A/C Equipment or running if any ( Air Handler, Condenser Fan Motor, Compressor)
etc
Jul 05, 2011 | Heating & Cooling
There is a hole in the bottom rear of the freezer of my side by side full of water and the over flow is frozen all across the bottom and it leaks onto the floor
How To Clear the Drain Tube Before clearing the drain tube, unplug the refrigerator or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard. Your refrigerator has a drain that leads to the exterior drain pan beneath the refrigerator. Occasionally this drain can become clogged resulting in standing water inside your refrigerator. A similar drain exists in the freezer, which when clogged results in ice build up on the floor of the freezer.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
Clear the drain by forcing a solution of water and bleach or water and baking soda into it with a basting syringe. If the solution will not flow through, slide a length of 1/4 inch or smaller flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog.
Jun 12, 2011 | Refrigerators
I have a 25 year old KA dishwasher (by Hobart) that is not draining properly. I ran it through a second time and the same thing happened. There is 2" of standing water right now on the floor of the...
The drain usually connects with a flexible plastic hose to the garbage disposal under your kitchen sink. Run the disposal for a minute to see if that unclogs anything.
Remove the hose and blow into it (use a straw and try to make a seal between hose and straw with your hand because old drain pipes taste really bad if you kiss them directly).
Otherwise, your pump may have gond bad - dishwashers do not drain on gravity alone. they all use pumps. Yours may not be worth replacing unless you are really handy and can do it yourself.
Pumps are available and located on the bottom of the unit. Disconnect drain hose. Disconnect circuit breaker. Remove panel by toe-kick and disconnect electical hard-wired connection. Disconnect water (under kitchen sink). Pull it out from under the counter. Order new pump, install and replace. Be careful with the electricity.
Good luck.
May 05, 2011 | KitchenAid Dishwashers
Hi, we have a GE profile dishwasher, and it is not draining. How do we fix it?
If you can hear the drain pump running but notice no water draining, you simply have a plugged or locked rotor on pump. If you do not hear the drain pump at cycle start (usually at end of wash cycle or when canceling wash cycle). Motor is dead. To access: First disconnect supply power and or breaker. remove access panel and disconnect hoses to input and output side of pump, now inspect and clear blockage or replace motor if dead.
Aug 19, 2010 | Dishwashers
Contunuous draining turned into a flood when unit powered off
The fill valve is governed by the float switch. I doubt that your fill valve (solenoid) has failed.
Focus on replacing the float switch and you should be all set.
Good Luck!
May 09, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
204 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
