Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
The pull out faucet is loose, wobbly, won't stay attached.
The hose seems to retract but the head doesn't tighten to the "spout".
  • 39 Answers
Make sure that there is a weighted ball connected about halfway down the retracting hose. If not you need to go to a supply house and purchase one and its a simple install.However if there is one attached you can loosen the 2 screws and slide it up closer to faucett but not so far that you can't pull out the sprayer as far as you need. Also make sure nothing is obstructing it under the sink. bottles, cleaners, etc.
Posted on Jul 11, 2009
Faucet head dangles. won't stay docked? how to fix???
If this is a kitchen faucet that the spout is also the spray, then my guess is that the weight on the hose under the sink has come. It takes a small phillips head screwdriver to tighten. Good luck!
Mar 27, 2017 | Plumbing
How do you remove the spray head from the supply line on a Grohe Ladylux?
Ok not sure what you are asking , but here it goes. If you are wanting to take off the sprayhead simply pull the sprayer out and unscrew. If you want to remove the spray hose from the bottom of the faucet simply grab the red spring loaded connector near the TOP, and pull down spring to release (kind of works like an air hose quick connect). If you want to remove the arch the hose must be removed from the faucet first, then simply jerk up on the arch to remove. When the arch is removed, there is a specialty tool that came with the faucet (which most plumbers keep) to tighten or loosen the faucet. Hope this helps. Luckydog
Jun 03, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
Faucet problems
-You mean it's loose and wobble...?
If so re tight its lock nut from under neat.
Good luck
Mai
May 02, 2014 | Plumbing
Kitchen faucet hose will not retract on its own
Faucet hoses use gravity to pull them back down into position. You want to add some weight to the hose or clear the space underneath your sink. Usually a big heavy nut will do the job as well.
Feb 17, 2013 | Delta 24T2621-LS-R6 Single Control Mixing...
The faucet has a single spout, no manufacturer identity, and the spray attachment can be pulled out. The entire faucet is loose at the base with no apparent means of "snugging it up" either from...
There should be screws that when tightened, will push against the metal flange that rests against the underside of the sink thereby pulling the faucet down and tightening it. Good luck!
Aug 05, 2017 | Moen Muirfield Kitchen Faucet with Side...
Trouble with a Franke kitchen faucet - the spout has a retractable internal hose for spraying down the sink - it is not retracting as it should
Look at the clutter under the sink. Is the hose tangled or caught on something? There should be a weight clamped to the hose to make it fall back into place. This weight minght have slid down the hose.
Jul 17, 2010 | Franke FF-303 Kitchen Faucet with...
The pullout spout leaks
pull out the spray part and tighten the nut around the hose or take it loose and replace the washer
Jun 28, 2009 | Kohler K-15160-7 Coralais single-control...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
Delta faucet is loose ;moves right-left/wobbles. Tightening?
Try tightening the allen set screw behind the spout "you need a special (allen keys) to do this, and one should have came with your faucet". You can also buy or borrow an set of them.
http://www.efaucetscomplete.com/SpecSheets/T2755CBLHP_Install.pdf
Copy and paste this to your address bar for directions.
Jan 30, 2009 | Delta Victorian T2755-NNLHP Bathroom Roman...
Kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Oct 16, 2008 | Plumbing
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
1,300 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
