Question about HP Compaq Presario V2000 Notebook
My hp presario v2000 battery/fan does not work
My computer battery does not work but the battery itself works.....my roomate has the same computer as me and we switched batteries and my battery worked in her computer yet her battery did not work in mine....i think that it might be a problem that my computer has...also my fan stopped working...its doesn't give air no more and i didn't do anything to it...it shuts off when it overheats what should i do?? and can this be a cause of a virus??
  • 4 more comments
  • pepito212001 Nov 09, 2007
    my fan will not work
  • Anonymous Jan 30, 2008
    my fans out
  • Anonymous May 03, 2008
    Fan dont work.Software or hardware problem?
  • Anonymous Sep 30, 2008
    i've hp pavilion dv2601tu notebook. my notebook's fan is not working.
  • lgermanetti Jan 18, 2009
    Same fan issue, the fan won't work , computer overheat and restart
  • hidoy May 11, 2010
    Solution link . . . www.Laptop-Problem-Sollution.com
    Problem Solver:
  • 11 Answers
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
The fan needs to be replaced or repaired. You'd better take it to the repair shop to check the power of your laptop. Overheat will cause many problems, and damage your motherboard.
If you would like to order new batteries in the furture, you may visit http://www.lflytech.com/batteries.php?cid=1&bid=21&pid=983
Posted on Aug 03, 2009
Try getting a 3rd party external fan: try this site where I got mine from: www.coolermaster.com.cn
Posted on Jun 27, 2008
  • 520 Answers
The fan is reasonably easy to repair(its only a magnectic coil rotor) and is usually clogged not broke.but ur problem seems to be a power issue on the main board.which;if you dissassemble yourself and take the board to a electronic repair shop it wont cost much but if you dont have the confidence for this and you need to take the whole pc then it will cost because the dissassembly of the pc is time consumeing
Posted on Mar 29, 2008
  • tat4u
    tat4u Mar 30, 2008
    if you need a service repair manual for ur model let me know and I can send u one.
    not only do they explain disassembly but also have a good fault/solution section
I have a compaq Presario V2000 and the fan has stopped working also. It will cost too much money to fix it, and I dont know enough about laptops to fix it myself.
I have solved the overheating problem by buying a laptop cooler pad.
Posted on Mar 24, 2008
  • vtronicstech
    vtronicstech Jun 19, 2011
    I think your computer is really a problem existing, and you should go to the HP after-sales store to solve this problem completely not fix it by yourself.
    If you want decrease the temp. of the computer, it's better to buy a cooler pad for your computer soon.
    http://adapter-battery-charger.com
    twitter:@michellegoo
    Problem Solver:
  • 6 Answers
Sure there might be some problem with the fan
because if will not the system will shut due to the overheating
there must be a problem that the fan will be full dust ....
plz first try it by cleaning the fan .....
Posted on Nov 10, 2007
    Scholar:
  • 84 Answers
The fan most likely needs to be replaced. When the computer overheats as a safety feature it shuts down. If you do not know how to replace the fan take it into a repair shop. The does not seem to be the problem.
Posted on Oct 25, 2007
Immobilizer reset switch
Disconnect the battery terminals and jumper the positive and negative leads together. This will completely drain the computer and it will have to reset itself as it comes up. Leave the jumper on the leads for an hour or so. When you reconnect the battery, your problem might fix itself.
Mar 02, 2014 | Nissan Cars & Trucks
York stamina treadmill
what is the power source? does it work by batteries or AC or both.
If it works by batteries check the batteries to determine if they are good or bad and need changing.also check for short circuits or corrosion in the operating panel controls.Ususally it is just the batteries that need changing and the compartment holding the batteries need to be cleaned.After cleaning and changing the batteries,make sure that you dry the soluables with a paper tawell or a clean rag,After you have done this the unit should return back to nomal operation if it does not you may have a problem with the computer itself and if that 's the case you will
need to find diagnostic codes designed to troubleshoot the computer.Hopefully just the battery change and the clean up will
be sufficient to return the unit back to intact.
Nov 09, 2013 | Exercise & Fitness
1993 ford explorer wont idle after starting
Check for codes first. Could be your egr valve is sticking. They get carboned up.
Jul 16, 2017 | Cars & Trucks
My mp3 player doesnt wok by itself but when i plug it into my computer it works...... ????
your mp3 battery is dead. . . consult a technician to replace your mp3 battery. . .
thanks and have a nice day. . .
May 04, 2011 | SanDisk Audio Players & Recorders
I bought this Samsung tv and it has a special remote for it.. My roomate has the same tv and I put the batteries in the remote in the living room where his tv is. It won't work on my tv but will turn on...
Take the batteries out of the remote about an hour.Put it back in tries functions on ur tv and only ur tv,not ur romate tv.Same tv,but all functions in each devices,have a slightly deviation of diffrent infer red signal wave.
Jul 10, 2010 | Televison & Video
My ipod wont turn on or charge.
More than likely the battery just needs to be replaced. I let my nano go dead and it was doing the same thing. So just get it replaced and that should fix your problem.
Mar 23, 2009 | Apple Audio Players & Recorders
Toshiba Tecra 8000 keeps switching itself off.
I'd suggest removing the battery. Most laptops can run directly off the AC adapter. If it will boot up OK without the bad battery, you can either leave it like that, or buy a new battery.
If it won't boot, then you have problems other than the battery.
Feb 08, 2009 | Toshiba Tecra 8000 Notebook
Viruses will not cause these symptoms....
First of all, do not keep running the laptop in that fashion, the CPU will overheat and die on the unit. Have it serviced for the fan problem. The circuit that controls the battery also may be bad. In any case , you need to have it serviced.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 30, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Turn off by itself
Yes, you can buy new charger/batterys in PC World really cheaply and theres a Sale on now beacause its just after Cristmas so try there.
Dec 24, 2007 | Panasonic Toughbook CF-27 Notebook
HP Compaq Presario V2000 Notebook Logo
656 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
