Question about Kenmore Dryers
I am looking for the part number for the heating element on a Kenmore Dryer 11084832201
  • Michael Masters
    Michael Masters May 11, 2010
    HI. i couldn't find the part number but, i have found the actual element that is for your dryer and, you can purchase it by clicking the link below.
    CLICK HERE
  • 6,784 Answers
HI. i couldn't find the part number but, i have found the actualelement that is for your dryer and, you can purchase it by clicking thelink below.
CLICK HERE
Posted on Jun 04, 2009
  • Michael Masters
    Michael Masters Jun 04, 2009
    Use this link to order your element online
    www.repairclinic.com/SSPartDetail.aspx?s=t-11084832201-%3d%3dc244i525502&PartID=525502
We have a Kenmore electric dryer model 11066962501 that has stopped heating, can we get some help opening and repairing?
might be your heating element that is burnt check the model of your dryer then look upnon youtube to replace the heating element simple and cheaper can buy the specific element with the serial part number on the original part :)
Sep 21, 2017 | Kenmore Dryers
Kenmore series 80 Gas dryer doesn't heat
Look for extreme fluff buildup inside and outside causing air restrictions. check your fusea5500f3.jpg
Mar 17, 2010 | Kenmore 64742 Electric Dryer
How to replace a heating element for a kenmore
Hello there
i am posting instruction for this dryer below
(For some help with that, and before buying an element you might not need, please see my article entitled 'The No-Heat Dryer'). Note: Always check airflow out the vent before firing up your dryer with its new element. A partially clogged vent can burn out an element - even a brand new one - fast! Just run the dryer on the 'no-heat' or 'fluff' setting, then go outside and check for a good strong flow of air from the vent hood. If there's any doubt, Whirlpool makes a cool little airflow test kit for their dryers that will tell you for sure, from inside.
There are basically 3 styles of heating elements in use for these dryers.
1) Most common is the 'long' one, part number 4391960, accessed from the back of the dryer, and which looks like this:
wpl%204391960%20el.jpg To replace this one, power down and pull the dryer out and remove the back cover. You'll see a long, vertical 'can' on the right side, with the element coil inside. To remove this can, simply pull the element wires (can be hard to remove; I use a long-nosed pliers), the limit thermostat wires just above them, and the thermal fuse wires if equipped (this is a little device mounted high on the side of the can, with two wires attached). One 5/16" hex screw at the top and a little strap holds the can in place. Remove this screw (You can look through the small hole that lines up with it, originally to poke a long screwdriver through), tip the can rearward, and lift it off its two bottom hooks. Once the can's out, one screw holds the element inside. Remove it, and the old element coil will slide out. Slide the new one in, reverse this process, and you're done!
Nov 13, 2009 | Kenmore Dryers
The dryer turns on but no heat is this the heating element or something else?
Most likely it is the element. The only way to be sure is to visually inspect it.
Aug 20, 2009 | Kenmore Dryers
DRYER HEATING ELEMENT
Kenmore dryers are manufactured by Whirlpool. In many cases the part numbers are identical between model numbers. Look at the dimensions of the heating element and compare part numbers. Chances are, the parts are identical.
Jun 29, 2009 | Dryers
Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Jun 14, 2009 | Kenmore 63942 Dryer
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
I have a kenmore Ellite Dryer that works but is not heating.
Is this a gas or electirc dryer?
If it's an electrical dryer it's probably the heating element.
Pull the dryer out, remove the back panel and look to see if the heating element is heating up (turns red). If not it's the heating element which is pretty easy to change.
Call an appliance parts store with the make and model number before you pull it out to make sure one's available and always take the old one with you to verify it's the same.
Hope this was helpful.
Good Luck!
Jan 21, 2009 | Kenmore 63942 Dryer
Heating element for kenmore dryer won't turn on
Hi, I have an 11yr old 80 series elec. dryer and just fixed the same problem. On the heater element is a thermostat with 2 wires and above that about 14" is another piece with 2 wires. I had to replace the top one. They sell them together in a kit called Thermal cut off kit. Sears sell it for 25.49 look up part number 279816 or 3399848 again these numbers are for my dryer but you can look them up on the sears parts web site. If you have a sears service center near by they let me buy the parts to see which one it was and then return the ones I didn't need. I hope this helps.Good luck
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
