Question about Hayward Pool Products Hayward Super Pump
My new Hayward Super Pump is over Amping
My old Hayward is about 5 years old and had no problem. Opened the pool this year and found the original pump was getting hot. Found Loose wires in the breaker. Tighten, and found the pump was still getting hot. Figured the windings were fried and repalced with new exact pump. This pump is still geting hot to the touch. All voltage is stable but the Amps are 8.0 recommends 7.3. We have constant voltage to the circuit with no drop, replaced Breakers as well.
  • John Prohaska
    John Prohaska May 11, 2010
    Any changes in the discharge piping? New valves, add a fountain?
    Are the amps you list from the motor shown as max load amps, sf amps, just amps? What is the service factor (s.f.) on the motor?
    Temp alone is a poor indicator as the motor Hayward uses is thermally protected and will shut off if it gets 'too hot' all on its own.
  • 27 Answers
If the pump runs hotter than it is engineered for the thermal overload will trip. Most newer pumps run hotter due to design changes. It has a 1 yr warranty let it run.
Posted on Jul 20, 2009
  • 15 Answers
Sounds like the wire gauge (thickness) is to small
Posted on Jun 23, 2009
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: new 1.5 hp super pump hayward, blows circuit when
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
Posted on Jun 14, 2009
john224
  • 1378 Answers
SOURCE: hayward 1hp super pump stops working
Your motor has a thermal protection switch in it the reacts to an overheating condition. Once the motor cools enough it will turn back on. You may be able to have the motor rebuilt for about half the cost of new if it is not damaged to severely. Take it to a local electric motor repair shop for service. If it is damaged beyond repair, you can shop around for a new one. If you would like a quote, contact us at www.arrowpools.net with your pump model number and we can quote it.
Posted on Jul 12, 2009
MOTORWIZJ
  • 1363 Answers
SOURCE: Clicking noise in new Hayward Super Pump
make sure the pump motor is set for 115 volts, it soumds like you have the motor set at the factory 230 v setting and are trying to run it on 115 v look on the motor label it will show you how to set the motor up for 115 v (if the breaker is wide 230 if its skinny like the ones that control your lights its 115v ..if you have ran it for awhile like this you may want to search your area for your local pool pump motor repair guy w/ free testing, because you may have damaged the start capacitor about 20.00 or less fix.if not this can come back to haunt you later,,jay
Posted on Dec 14, 2011
I have a Hayward Super Pool pump for my inground pool. Was running the pump, heard a noise, by the time I got over to the pump to check it it shut off. It has been off for over 2 hours. It is not hot....
Get another brand. Hayward is junk. I had the same exact thing happen. Of course warranty is only one year. I paid out of pocket to replace the motor. Guess what happened 2 years later?
May 08, 2014 | Hayward Pool Products Hayward Northstar...
I have a hayward pump model SP2610X15 that will only hum when turned on. I replaced the capacitor, it did not help. What else could be the problem?
DIRTY START switch or the motor is locked up, breaker off ! remove motor from tank body and see if the motor will turn over if it does could be the switch or the motor is shorted witch there is no fix but a new or rebuilt motor. search your area for your local pool pump motor repair guy with free testing..
Jay the pool pump motor repair guy longwood Fl
Apr 02, 2012 | Hayward 1.5hp Pool Pump Motor Motor A O...
Hayward Swimming PoPump is 4 years old - when I opened pool, pump
it you've inspected all the wiring for possible shorts, the most likely problem is that the motor has developed a short in the windings. You may have to replace the motor. First check for loose connections and make sure the wiring going to the pump is good. Also, check the start capacitor, should be under the hump or under the end cover on the motor. If it's bloated or leaking, it's bad.
Most likely the winding have a direct short.
Apr 05, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Haywards Super Pump Tick tack sound
You may have been running it on the wrong voltage for 3 years especiallyif you feeding it 120 volts to a 220 setup. Assuming it is getting the right voltage and it clicks off and on you run winding is bad so the start winding cliicks on to bring it up to run speed opens the switch but the run winding isnt there so it repeats the process forever till it fails.
Jul 15, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hello, We have had our Hayward Super Pump 1hp for 6 years with no problems. Just yesterday it started tripping the circuit breaker. It would run between 30seconds to a minute and trip the breaker. Could...
6 years is a good time - you must have house for your pump :)
If you are close to a pool shop - take it in and get it tested - somtimes it will just need a service.
Jul 13, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Hayward 1hp super pump stops working
Jul 12, 2009 | Hayward Pool Products HAYWARD 1 HP 2 SPEED...
Lossing Prime
It's pulling in air very slowly from somewhere:
priming pot lid,
valve body tops,
valve handles,
pipe unions, --
check gaskets/o-rings-- replace defective ones, lubricate
tighten everything possible
Apr 10, 2009 | Hayward 1HP Super Pump II Inground Pool...
Hayward Pool Products Hayward Super Pump Logo
436 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
