Question about Linksys (WRT54GC) Router
I lost my passkey to my AT&T 2wire router. i just got a new laptop that i want to connect to the internet, but i set my network up as secured.
  • 41 Answers
First connect your laptop hardwired to your router. Now access the web-based configuration of the router by entering its IP address in your web browser. The default IP address is 192.168.0.1. Login by entering your username and password. The default username is "admin" and the password is blank. Click the WIRELESS link from the menu options on the left side of the configuration page. For the Security settings, choose Shared Key Click the radio button to turn WEP On Enter 10 digit number in the key.That will be your new Key for secured network Click the Apply button to save your setting and reboot the router Remove the cable between router and laptop. Now search for the wireless network and connect with new key.
Posted on Jun 05, 2009
I am trying to find network name and passkey.
Hi, If you want to get the name and the passkey,
  • first step you need go to start
  • type start search 'cmd' and hit enter
  • then on the command prompt, type 'ipconfig'
  • get the default gateway ip address and type it on the address bar of internet explorer
  • it will now show you the information about the 2wire wireless information. look for the SSID and that will be the network name.
  • now the passkey will be found on the sticker on the router, it is a default one, a 10 digit key.
Now you will be able to connect to 2wire router. Thank you using Fixya, your recommendation is highly appreciated for the free support.
Jul 27, 2011 | 2wire 2700HG-B Router (2700HGB)
Connecting to a "2WIRE" wifi connection. Says the
I understand that you are having trouble connecting your Nintendo DS wirelessly to your 2Wire router. The solution is simple, your Nintendo DS only supports WEP (Wireless Encription Passkey) security. It is highly possible that your 2Wire router's wireless security is set to WPA. That means you will need to reconfigure your router so that it will be utilizing WEP as a security for your wireless connection. To be able to do this, you need a couple of information from the one who setup your router. 1. User name of your router 2. Password or your router.
Once you have gotten this information, you will need to access your router configuration page through one of the computers that is linked to your 2Wire router by typing http://gateway.2wire.net on the address bar of your browser.
It will be asking you for the username and password. If nobody had setup or changes the username and password of the router, use this default username and password of a 2Wire router. Username: (none) Password: Wireless or Username: 2Wire and Password: (none). Try any of the two. If it does not work, try admin and the word password for the password or any other combinations of the two.
Once you have entered the router's configuration page click the Home Network Tab and then click on Wireless Settings. You will see there a portion that says Wireless security. In that area, you will see a drop down where you can choose what kind of wireless security you want on your system. As I have said, the Nintedo DS does not support any other wireless security setting but WEP. That means you will need to change the drop down to WEP. That also means after changing this, you will need to reconfigure your other wireless devices (like your laptop) to use WEP as well.
Jul 21, 2011 | Nintendo DS Lite Console
Trying to connect wirelessly to 2 wire. I get limited access icon
Hi groveland1,
I see that you are having issue with your Internet Connection, Limited or no connectivity is a possible issue with your network key / security key on the router and your laptop.
1. Try and check the network key in your router.
2. Check your network settings in the Laptop and see if the security settings in your Laptop is the same as the security/network key in your Router.
3. If possible recreate your wireless connection in windows for a fresh connection from your Laptop to your Router.
4. Change your Network Key in the Router and in your Laptop see if it will connect in-case you may have forgotten you old Network Key.
Hope this helps.
Apr 04, 2011 | 2wire (1000-400108-001) Router
Don't remember how to connect my router. Do you have the instructions printed somewhere? Lost the instructions.
How to set up 2wire wireless router
  1. First, you must find your WAN (wide-area-network) connection. This is the connection to the Internet, and you must connect this cable to your modem. The modem should have a site that indicates that "WAN" or "Internet" on it - the main outlet to the Internet connection in the cable.
  2. Use an Ethernet cable to connect your computer to the modem. This is not permanent, but you need to set up the wireless network. Open a Web browser, type the IP address of the modem (usually something like 192 168 .. 1. 1), and the connection with the username and password. This information should be provided in the operations manual of the router - all routers are different, it is beyond the scope of this article to describe each situation.
  3. Once you are in the wireless modem, you must enable certain security settings. The first step is to encrypt network traffic. Each screen in the modem must have an entry "Network Encryption" button (or something like that). There are three main types of encryption: WEP and WPA have been cracked, while WPA-II (at the time of this writing) is secure. If your modem is new, you should be able to encrypt with WPA-II. Define a secure password by following the advice in the article linked in the Resources section.
  4. Change the SSID (network name) to something other than the default, when the networks have the default SSID is an open door for hackers because it is assumed that security is low.
Nov 24, 2010 | 2wire (2701HG-B) Wireless Router
How can i get a keycode
Are you looking for the wireless network key or password ?
Is there any computer online using the router.
If not then you will need to connect the computer to the router.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
You will find the wireless network key or password on the set up page of the router.
May 08, 2010 | 2wire (2701HG-B) Wireless Router
I have lost my wireless connection on my laptop
Delete the Existing wireless connections in the laptop and create another one
This should fix the issue
Jan 03, 2010 | 2wire 2700HG-B Router (2700HGB)
I cant remember my network security key
Your both stupid the NETWORK KEY is written UNDER THE ROUTER.
Jul 12, 2009 | 2wire (1000-400108-001) Router
Had a System security virus fixed it and lost internet connection
Go into your Control panel, in the Network icon, see if theres an option to setup a connection.
May 24, 2009 | 2wire (1000-400108-001) Router
Can't connect new laptop to internet through wireless
Hi...if you mean the network key, the key Windows asks for when you try to connect to a secured network, you can find this within your router settings.
As this is a 2wire model, you might also find it on a label on the router - it depends if you changed the default settings.
Please visit this page for help:
http://support.2wire.com/?page=view&article=60
- it will show you where the default network key is on the label, or if you have changed it, how to login to your router and to find it in your settings (see screenshot at base of page - your network key will just be labelled 'key'.....)
Jan 27, 2009 | 2wire HomePortal 100W (1000-400026-000)...
1800 hg 2 wire wireless
1.can i use my 2wire 1800hg with vista?hooked up to ethernet connection.- yes its possible make sure you enable dhcp on your lan side of you router and under tcp/ip on your pc set it to authomatic assign IP address and dns server address. most router use 192.168.1.1 as thier default address to access it.
to fix your passkey problem.need to access the router and try to change the passkey then save and don't forget to restart the router after you save it,by unplugging it. "make sure your passkey is 8 characters long"
Nov 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Open Questions:
Linksys (WRT54GC) Router Logo
748 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
