Rinnai space heater
Pilot light will not stay lit
  • snowsnake Oct 25, 2007
    Make is-RINNAI-Model is-REH25TN      pilot stays lit as long as i hold down the button but goes out as i release the button. sounds like the thermolcoupler to me but tried a new one with the same results. does the thermolcoupler end need to be in the pilot flame to work properly?                thanks a bunch
  • 1,420 Answers
Help us out by giving us a make and model number.
Posted on Oct 25, 2007
  • Chandler Ede
    Chandler Ede Oct 25, 2007
    Make sure the flame is hitting the thermocouple. If it is and you are still experiencing shut down, inspect the connection at the gas valve. Make sure it is not cross threaded. If you have done all this and still no flame, you are looking at replacing the gas valve.
    If you have a good multimeter that measures Millivolts, connect one lead of the meter to the thermocouple and the other to ground. You are looking for between 500 and 750 millivolts when you apply a flame to the end. This will tell you if the thermocouple is good or not.
4 Suggested Answers
SOURCE: Rinnai Tropic ventless heater. Pilot will light
found that the pilot tube had dust bunnys in mine so blew it out with a air can i had for the computer now the pilot light stays on just fine
Posted on Feb 09, 2010
  • 120 Answers
SOURCE: rinnai gas heater model RCE-318H
Real odd one as if ignition fails this unit is designed to flash various lights to give you an idea of what the fault is. Also this usually happens after about 10-15 seconds. I'm going to have to ask you to clarify that no other lights flash. If I had this fault exactly as you descibe, after running some basic tests to check gas supply and any obvious damage or burnt out components I would change the the main PCB as a start and the control PCB as a plan B.
Posted on Aug 09, 2010
  • 27 Answers
SOURCE: Older style Rinnai gas heater
not a problem. however, if you want to shrink it down... it's hard to say just what your gas valve is like. There should be 2 spots on it for adjustments, the larger slot (should be covered by a brass plug) adjusts the main burner output, the smaller adjusts pilot output. crank it down and watch the pilot shrink, but in this situation bigger is better. the pilot creates an electrical signal that opens the gas valve, you don't want that signal to be too weak.
It would be wise to clean the pilot supply, to have a cleaner flame. pressurized air does well with out having to remove it.
Posted on May 07, 2011
I have a rinnai 30000 btu floor heater. The pilot will not stay lit. I have installed a new thermocouple please help
Contact rinnai support ,make sure the pilot sensor is sitting in the flame,& i hope you did not over tighten it when installing it also lightly sand the end that screws in.
Feb 21, 2015 | Rinnai Heating & Cooling
I have a 30000 btu rinnai floor heater mod 630530. The pilot wont stay lit . I have installed a new thermo couple . please help
be sure the thermocouple is in the pilot's flame and hold down the pilot lighting button long enough to heat it before trying to operate the heater...20 to 30 seconds should be enough. If this doesn't work, you may have a bad gas valve
Pilot light goes out when heater shuts down
Check the position of the thermocouple and if there is one make sure it is very close to the pilot flame Usually when a pilot light will not stay lit, it is an indication that the thermocouple is bad. Replace it.
Feb 10, 2011 | Rinnai Vent Free Gas Heater/
I can get the pilot light lit but will not stay on to light the burners
Try cleaning the thermocouple or replace it. The thermocouple senses heat from the pilot light and in turn brings up the gas to the main burners upon request from the thermostat.
Dec 20, 2010 | Rinnai Toyostove Direct Vent Heater:...
My ventless propane heating stove shuts off by itself
I have a Rinnai Ventless heater hooked up to a 20 lb propane cly with a Moble home type regulator in line, and when I light it the pilot light lights and stays on. When I turn it to the heat position the pilot light go's out and that it!
Jan 28, 2009 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Rinnai wall heater won't lite.
You may need to take the pilot assembly apart and clean the pilot orifice. If the pilot does not stay lite you may need a new thermocouple. Good Luck.
Mar 29, 2008 | Heating & Cooling
Wont run
check the flame detector it may be a millivolt generator or a flame rod feeding to an electronic circuit.
Nov 16, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Heating & Cooling Logo
495 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
