Question about Texas Instruments TI-89 Calculator
My TI -89 won`t turn off
I just bought it a couple of weeks ago and it has been working just fine. As of today I can´t turn it off. I use the 2nd and  [off] keys,at first it turns off but after a second later it turns right back on. I tried the diamond key and then [off] but it`s same thing. I reset and still have the same problem, I also tried taking the AAA batteries but that didn´t help. I haven´t taken the backup battery out, I`m not really sure what kind of effect that might have on my TI-89.Among other things I tried resetting my memory to its original factory setting without any succesfull results.This calculator is brand new and I have taken very good care of it, I haven´t droped it or anything like that.
  • 6 more comments
  • Anonymous Nov 12, 2007
    i have the exact same problem and have tried everything above
  • Anonymous Nov 27, 2007
    AHHH! I have the same problem mine just started doing it...As a quick fix I have just been taking one battery out and then putting it back in when I need it
  • Anonymous May 29, 2008
    Had kind of a similar problem. My screen just went darker n i was lookin for the option that said screen display but there isn`t any... so just pulled out the batteries and the backup batteries too, put them back and it was like new again....
  • Anonymous Aug 13, 2008
    When I try to turn off the calculator, it turns off but turns on again by itself. I tried taking out and replacing the backup battery, pushing the left, right, 2nd, and on buttons together, and reseting the RAM, but nothing. PLEASE help!
  • Anonymous Nov 17, 2008
    Same with me. I got mine Chirstmas of 06 and have taken excellent care of it. I tried reinstalling the OS and changing batteries (even the backup) with no success. I had mine vertical at my desk for a while, the dust theory is feasible, we'll see after i clean it out.
  • xx09 Nov 26, 2008
    I have the same problem with TI-89 Titanium. I tried all those solutions: blew into the I/O and USB ports with my hairdryer, taking out the back-up battery, pushing <- -> 2nd and On buttons at the same time and reseting the RAM, and it still does not works. Any other solution?
  • Anonymous Jan 07, 2009
    Thanks a lot for posting this solution - the hairdryer solved my two year old problem when taking out back up batteries, updating firmware, clearing Flash and obscure button combinations didn't.
  • 51plus Jan 16, 2009
    I had the same problem so I removed both the backup and the 4 batteries
    keep them out for an hour or so.
    backup all your files on your computer with new batteries  first  the  do the above .
    the calculator will reset to the factory settings so you will have to reinstall everything except the operating system and what ever is on the eeprom
    best of luck  all is not lost  this machine is a real computer.
    oh this problem occured when I started to install assembly programs.
    I have since stopped this to my dispare but I am still interested in programming  with the language on the system.  It is very good.
Solution that worked for me, taken from "Ti-89 titanium wont turn off":
Best Solution posted on Mar 05, 2008 Guest
Rank: Apprentice
Rating: 0%, 0 votes
I was able to fix the problem nut it requires several steps and only offers a temporary fix (untill the calculator is reset then it needs to be done again).
1. Press F5, then Dimond (symbol on buttion) then "Clear"
2. Press "alpha" then "S"
3. Press "0" dont mess with anything else here
4. Press "2nd" then "Quit"
Now you can turn it off but are missing the bottom text (rad,auto, etc...) to fix
6. Press "Mode" change radian to degree then "enter"
Now the text is displayed showing the mode.
7. Set the mode back to radian by reversing step 6.
Thats it I dont know how to get the bottom line back though...
Posted on Aug 19, 2009
I had the same problem. I clear the RAM, reset it and even reloaded the OS. Finally, based on advice from another website, I blew air into the I/O port on the top. It works now. Apparently dust can cause some sort of problem on the port. I then covered the port with electricians tape.
Posted on Aug 28, 2008
I had the same problem where my TI-89 wouldn't turn off. I took out the back up memory and it still wound't turn off when I put it back in. However, I tried the same process two more times and I also blew into the I/O and USB ports and now it turns off. So my suggestion is to keep taking out the back up memory and the batteries and try blowing in the ports and see if that eventually helps.
I bought mine (TI-89 Titanium) from an ebay seller, and I had this problem after a few months. I took all the batteries out (not the backup), and left them out for an hour or so. I also blew some air (something similar to compressed air) in the I/O port, and I can now turn my calculator off!
Posted on Jan 02, 2010
I had the same problem on my TI 89 Titanium. This is how i solved it: 1) I driled out the six screws with a 2,5 mm dril.(be carefull) 2) Then i took the greenplate out. cleaned the housing, te buttens and the greenplate. put it back together. and it wase fixed!
So i think its not a softwareproblem but just a dirty inside.
Posted on Jan 05, 2011
Just get a can of dust remover and clean the I/O & USB port on the top of it and it works. I just fixed one.
Posted on Apr 17, 2010
I tried blowing in the I/0 port but it didn't work for me. So I used a small Allen wrench to scrape in the I/0 port and it did fix the problem. I had even called TI support and they couldn't help me (wanted me to exchanged one for $75). Thanks hope this helps those pissed off at their calculator.
Posted on Oct 28, 2008
I think that with everything made in china - quality control is **** poor. I do not think that we get cheaper stuff. TI sure makes lot of money.<br /><br />Deserve quality stuff when you pay 150 bucks for a calculator<br />
Posted on Aug 22, 2010
    New Friend:
The problem goes trought the auto on funtion when you conect it the the computer, that's why it can be solve cleaning or scratching in the i/o port. The iphone had the same problem with the audio port stacked in handsfree mode.
Posted on Nov 03, 2013
  • Alejandro Torre
    Alejandro Torre Nov 03, 2013
I can't believe it!!! i blew into the I/O and USB ports with my hairdryer :) and it worked, my TI is "turnoffable" again, after a year searching for the battery in my bag, again and again....
thanks for your comments!
Posted on Oct 20, 2008
  • 38 Answers
If you bought it straight out of the box, you can complain to Texas Instruments and they will send you a replacement. At first they'll fix your calculator but if that doesn't work they'll send a second brand new one. They keep track of the serial numbers of faulty calculators and wait for users to send them back. So get on it. Go Complain. Now
Posted on Aug 27, 2008
I have the same problem w/ my TI-89 Titanium. I tried all those solutions: taking out the back-up battery, pushing <- -> 2nd and On buttons at the same time and reseting the RAM, but nothing! :( I wonder if the problem has to do w/ the on button or the Automatic Power Down feature in the calculator.
Posted on Aug 13, 2008
<- and -> and 2nd and on simultaneously.
Installation in progress
On ti-89ti hw4 os3.1
Posted on Aug 05, 2008
I had the same problem after I downloaded a tetris game to my ti-89 titanium. I tried to start the game, then a black band appeared at the top of the screen with the words "Divide by Zero" in the middle. The screen froze like that, pushing buttons could not turn it off, and even taking out the AAA batteries didnt help.
My solution was to actually take the backup battery out and put it back in, and eureka!!! Everything was back to normal. Now, I don't know any side effects, it may erase all of the memory or it may not, just remember my calc was brand new off the shelf. I couldn't find the tetris game on the calc afterwards, but I could find another folder that I had downloaded before tetris so.... use your own discretion. I really hope this helps people with the same problem, so if your willing to lose the memory instead of bringing it back, try taking out the backup battery.
Posted on Dec 26, 2007
I'm having the same problem, I bought this thing opened from staples and I see why the previous owner returned it. As soon as I'm done exams, I'll do the same
Posted on Dec 14, 2007
I'm having the same problem and soon as I can i intend on clearing both the RAM memory (by taking out both the cell battery and the AAA's) and flashing the OS. It surely is based on a corrupt memory location probably at a very low address range. I'll post a solution when I do this!
Posted on Apr 12, 2008
Ti-36x Solar Scientific Calculator issue: number buttons resetting to zero...
Look in the back of the calculator, some TI models have a pin hole to hard reset the calculator.
Mar 22, 2015 | Texas Instruments - Ti-36x Solar...
TI-89 Titanium completely frozen (Tried all reset methods)
Press left and right arrow and 2nd keys simultaneosly, hold it and then press ON. Release all keys at the same time and you will reset TI 89 Titanium.
Or, type diamond key simultaneosly with + or -
(plus or minus) key to resolve dark screen.
Jun 01, 2017 | Texas Instruments TI-89 Calculator
My TI-89 Titanium isn't turning on. I took it out of my backpack today and it wouldn't respond at all.
Try a hard reset, if you're willing to lose the contents of all RAM.
Press and hold the 2ND, Left-arrow, and Right-arrow keys.
Press and release the ON key.
Feb 05, 2010 | Texas Instruments TI-89 Calculator
My TI 89 wont turn on
Try to increase the contrast
1. Turn it on
2. press [2nd] and release button
3. Press [UpArrow] and release button
4. Repeat steps 2 and 3 until contrast is adequate.
If that does not work use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html
Install it on your computer and run it to oppen the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIConnect TIDeviceInfo. It will try retrieve the info.
If it does your calculator is fine.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and try OK..
If all that does not work, then it may be time look for a repair shop.
If you are lucky and it works, you should reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer.
Hope it helps
Jul 10, 2009 | Texas Instruments TI-89 Calculator
Can't turn on Ti-89 after not using for 5 years
Will it connect to the computer using device explorer, This way you might be able to see what the calculator is installed with. And it should turn on automatically.
Jul 01, 2009 | Texas Instruments TI-89 Calculator
My TI-89 won't respond to any buttons
I don't know how you went about cleaning the battery contacts but if there was any chance to have gotten moisture into the case, it may never work again. The circuits operate with currents in the nano & femtoampere range and even a breath of moisture can temporarily disable them because of stray currents.
The failed battery may have also damaged fine printed circuit traces as well.
Jan 30, 2009 | Texas Instruments TI-89 Calculator
"Adress Error"
reinstall the OS?
go to education.ti.com and download the operating system (AMS) for Ti-89 Titanium?
Sep 23, 2008 | Texas Instruments TI-89 Calculator
TI-89 Won't Turn On
Please don't get your hopes up, but perhaps something in the following few suggestions will work:
For the TI-89 Family, TI-92 Family, and Voyage™ 200:
  1. Adjust the contrast by pressing and releasing the Diamond Key key followed by pressing and releasing the [+] key; repeat as necessary. To adjust or lighten the display, use the [-] key.
  2. Users of the TI-89 Titanium or Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps.
    On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
  3. Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. TI-89, 92 Plus, or Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...". You will need to restore the calculator's operating system.
To reinstall the Calculator's operating system, take a look at the following TI site.
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetNumber=12089
I would hunt around on the TI knowledge base to see if there are some more useful suggestions if nothing above works. If I find any more info that could be useful I will post it.
Mar 06, 2008 | Texas Instruments TI-89 Calculator
WON'T TURN OFF
Under your On button might be some dirt, that keeps triggering the On button, and thus, keeps it on.
Clean under the On button
Oct 09, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
8,876 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
