FixYa.com
Tags:
Refrigerators
Generic problem for all Refrigerators
Side-by-side GE TFX25JRYWW
posted by myrna123 on Oct 25, 2007
Thanks, the ice maker makes crushed on cube setting. I took the front off and saw wires, is there a part # to order please?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 25, 2007
FixYa! (100)
fridgetech
Rank:Guru Guru
Rating: 88%, 706 votes
There is a metal rod on the ice bucket that fits into a solenoid at the back.  Pull out the bucket and make sure the solenoid is pulled down.  Put the bucket back in and see if cubes work.  If not then replace the solenoid.  You can get it at http://www3.sears.com/.  Part # WR62X58 and cost is $29.27.  You should hear a loud click if the solenoid is working.  If your able to check to see if you have voltage to that solenoid when activating the ice dispenser.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 27, 2007
Not Rated (0)
shankman
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I cannot believe this worked, the lever was in the correct position, I just checked it and put the bin back in place.  I have cubes!  I was sure this was a faulty control module (selector switch on front of Fridge).  Thanks
This Problem Also Relates To: GE (GTS16BBS) Top Freezer Refrigerator GE GSS25SGMBS Side by Side Refrigerator GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator GE Profile? GCG1580LSS 15" Built-In Trash Compactor with 1.4 cu. ft. Capacity, Hidden Controls & Remo... GE Energy Star PDS22SIS Stainless Steel Bottom Freezer Refrigerator GE PFS22SISSS Stainless Steel French Door Refrigerator GE GSL25JFPBS Side by Side Refrigerator
Can you Help with these Refrigerators problems?
Danby (DAR604BLS) Refrigerator
ge refrigerator model gss22wgph...
Side by side frige is only 2... Answer This...
Kenmore 50522 / 50524 Side by Side...
kenmore model #106 55522400
ice maker is making ice but not... Answer This...
Refrigerators
GE pss26mg Profile
How do you change a water line... Answer This...
Refrigerators
water is pooling in the
water is pooling in the bottom... Answer This...
Whirlpool GS6NBEXR Side by Side Refrigerator
refrigerator ice machine
Our brand new whirlpool... Answer This...
Repair Service
Find Refrigerator Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
