Question about Ryobi Cultivator
Fuel lines on my cultivator corroded. I do not
Fuel lines on my cultivator corroded. i installed a new tank, but I do not know where each line connects.
which tank to which primer
which primer to which carb
which tank to which carb.
  • 513 Answers
Ok you have two fuel lines coming in from tank the one that has the fuel filter atached inside should go to the top & the other is just the return line try that & let me know if it helps wade at wadembly@aol.com
Posted on Jun 06, 2009
Which fuel line is the intake line at the carburetor?
The fuel line goes:
  1. From the filter in the tank to the carb, usually the bottom most connector.
  2. From the carb to the Primer. The tube in the center of the primer bulb.
  3. From the primer, outer tube to the fuel tank.
Get the manual online from Troy-bilt herehttp://www.troybilt.com/equipment/troybilt/tb146-ec-4-cycle-garden-cultivator
j
May 07, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Air in fuel ryobi tiller
you will have 2 lines at the tank. 1 is the supply line with one end having the fuel filter on it and sitting at the bottom of the tank. it generally runs to the inlet side of the carb. the output side of the carb usually goes to the primer bulb inlet, the last hose usually goes from the outlet of the primer bulb back to the fuel tank but only goes in 1/8 to 1/4 of an inch. it should only be in far enough to seal the hole and allow the fuel back in to the tank
Mar 29, 2013 | Ryobi Cultivator
Hello, my Ryobi 410r tiller/cultivator needed new fuel line so I bought the fuel line, return and a new bulb primer. Unfortunately, I can't remember what hose goes where!!! Specifically, I've...
The primer pulls fuel through the carbruetor
So take your return line from the carb. and hook it to the inlet side of the primer and the other side
of the primer bulb transtions into the fuel tank.
You know when you have hooked it up right when you press the primer it fills with fuel and dumps back into the tank.
Jun 16, 2011 | Ryobi Garden
Ryobi cultivator #RY60511A : Need diagram or text to show the fuel lines from the tank to the primer and the carburetor.
here is a manual,Tim:
http://lawnandgarden.manualsonline.com/mdownloads/38dcb043-331f-461b-a08c-072d67fc76c0.pdf
here is a diagram:
http://photos.hobbytalk.com/showphoto.php/photo/34693
in a nutshell:
1 connect top carburetor line to short nipple on primer bulb.
2 bottom carburetor line to fuel line with filter (inside tank).
3 connect remaining fuel line that comes out of fuel tank to the large nipple on primer bulb.
Hopes this helped Tim
May 29, 2011 | Garden
Need to know fuel hose routes from fuel tank to carb
I will include routings for an on the carburetor purge bulb and a remote purge bulb.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Apr 29, 2011 | Mtd Garden
Two fule line where do thay go on the carb
The fuel line that has the fuel filter on it goes on the side of the carburetor, it is the inlet for the fuel. The fuel line that goes back into the tank and has nothing else on it goes onto the carburetor closest to the primer bulb. All else fails, you can pump the primer and see if the fuel goes out or in by putting your finger over the inlet lines on the carburetor. If the primer bulb goes flat but does not inflate back up then that is the fuel inlet. Alternately, if the primer bulb will not go flat without air going by your finger then that is the fuel return that goes back into the tank without the fuel filter.
Mar 31, 2011 | Yard Machines Cultivator
The gas line for the in-gas filter corroded. Does it go to the pump bulb or carburator and how far down do both lines go?
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Sep 03, 2010 | Ryobi Cultivator
Poulan P3400 Chainsaw Fuel Line Routing
If the saw has a primer bulb, then you require one line from it's output out to the tank return. Another line runs from the carburetor outlet to the primer inlet. Make sure that you use original rubber lines, not plastic replacements. The primer ports are found by trial and error--hook the filtered line directly to one primer port and leave the other port open. If the bulb is in good condition, and correctly connected to fuel, the bulb should fill with fuel after several pumps. If nothing, reverse the port connection at the primer--and pump test again. One of these two connections should allow pumping to occur. When you get pumping, install the tank return line to the empty primer port. Remove the filtered line from the primer and install on the carburetor. A new piece of line runs from the now empty primer port and connects to the output port on the carburetor. If the carburetor lines are correct, you should be able to pump fuel through the carburetor body and out to the primer bulb. If nothing happens, you may need to swap the carburetor lines, and you will likely need to service the carburetor. Hope this helps!
May 25, 2010 | Garden
Fuel line routing yard machine 31cc cultivator 21A - 120R000
unit with primer bulb,,,,,line from gas tank with filter, goes to bottom of carb, from top of tank to suction side of primer bulb, from output of primer to tank return
Apr 29, 2010 | Yard Machines Cultivator
Ryobi Cultivator 410r
The linefrom the tank with the filter goes to the mixture inlet on carb. The fuel return goes to the suction side of bulb. The bulb outlet line goes to the tank. Hopes this helps
Mar 19, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi Cultivator Logo
456 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
