Question about Zebra Z4M Printer
PRINT "LOOPING" I HAVE THIS SAME PROBLEM!!!!!! I have the ZM400 model. small files print well. larger files loop like there is no tomorrow. seriously considering throwing this peice of monkey sh** out of the car window. My IT guys are like talking to a couple of block heads. i contacted Zebra. they said it was our data base. i contacted "our data base" and they said it was zebra? im stuck between a rock and a bunch of idiots. i would be willing to pay good money for someone to notify me with a fix for this rediculous mess.
My problem is listed on this site as well. I have found my problem to be the HP Jetdirect. When I have tested the same print job on the same model printer but using either the the Zebra Net Printerserver II (kindly loaned to us by UniqueID for this testing) or one of our units that has a wireless cisco card the job terminates correctly. rhysw@allport.co.uk
Posted on Jun 15, 2009
LA IMPRESORA ZEBRA ZM400 CUANDO SE ENCIENDE APARECE EN LA PANTALLA LCD, EL MENSAJE HEAT OPEN, COMO QUITARLO?
there is a possibility that you need to just the print head assembly, if when its at close position, the print head is far from the sensor.
With the print head is open, you will see 3 screw on the left, louse them and adjust all the print head mechanism, up and down some milliliters tie the screws again, close the printhead , try again and see if errors desapeer
Jul 24, 2014 | Zebra ZM400 Thermal Label Printer -...
Zebra zm400 does not want to print from file
Hy, what file? thanks. try driver from www.seagulscientific.com.
Jun 03, 2014 | Zebra ZM400 Thermal Label Printer -...
The print out of ZM400 misalign to the left. How to make it back to the centre of the label?
Printing from an Internet Browser can cause this result if you have not set the margins, footers, and headers.
File ' Page Setup
Change all margins to 0.01 (or as close as possible, it may override you) and all SIX bars below that to Blank or Empty.
Apr 10, 2013 | Zebra ZM400 Thermal Label Printer -...
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Zm400 print a part of a label. Hello, my Zebra ZM400 only print 1/5 last part ot the barcode label. Could you please tell me how to fix it?
What part, rigth site or bottom site?
check the lengt and the with from the driver and print the testpage (have to print on full label)
if is one of the sides, try to give more pressure to that side on the printhead.
Nov 17, 2010 | Zebra 203DPI Printer
Printing and counting problem with Zebra ZM400. We have connected a Zebra ZM400 to our network and we now have a problem with printing. When we print he prints the labels 1 by 1 instead of de total...
if you sending a file (ex. pdf or picture). to the printer, can do this, if you send the proper format with normal fonts (caracteres))to the printer, work fine. build new label from zebradesigner
May 20, 2010 | Zebra Z4Mplus Label Printer
I have a printer ZM400 300dpi and I changed the print head to 203dpi. After that, the words are bigger than normal and don't calibrate properly. I've tried to calibrate and upgrade the firmware but don't...
If you continue to use your 300dpi printer driver then the text will be printing larger because the dots on the 203dpi printhead are larger(.003 on 300dpi and .005 on 203dpi). Change your printer driver to the 203dpi version for that printer. Then it will print fine.
Calibration is another issue and shouldn't be related to printhead dpi although you may find the calibration issue solved when you change the printer driver.
Hope that helps
Apr 21, 2010 | Office Equipment & Supplies
Prints larger that print preview shows...
Firstly make sure your using the correct drive ZM400 rather than Z4M. if you are using the applications driver make sure of headers and footers sizes and the print area is set correctly. If your using odd sized lables download some new drivers from the Nice Label website, they are far more adjustable that the standard Zebra drivers.
Aug 29, 2009 | Zebra Z4M Printer
Printing loop
Have you tried sending print jobs thru the parallel port only? I think it has to deal with your jetdirect box. You can try reseting that as well.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
May 26, 2009 | Zebra Z4M Printer
Printing loop
try to reset the printer to factory default.
on setings, without the printer cable plug in. and try again.
Oct 10, 2007 | Zebra Z4M Printer
Zebra Z4M Printer Logo
212 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
