Question about Epson Aculaser C1100 Printer
Changing toner cartridges
We have changed the CYAN.
How to get cartridge-system to turn to next position, in order to change the next color?
Päiviö Latvus
  • 3 Answers
The answer given explains everything except how to get the right cartridge to the front. Here is how to do it.
  1. Switch on if not on already. Once it has warmed up it should have the usual messages on the display (which might include telling you that some of the toners are low).
  2. Press the down arrow until you come to the reset menu.
  3. Press the > to select that.
  4. Press the down arrow until you come to Change Toner X (where X is the colour you want to change).
  5. Press the > to select that.
  6. Wait until the printer stops churning.
  7. Open the front door and you should now see the correct cartridge at the back.
  8. Follow the instructions on the box (or in the other answer)>
Posted on Jun 24, 2009
    Genius:
  • 1,605 Answers
Since th einstruction for changing the toner is long. and I can post it here.
go to the following link and print out the instruction for futrue reference.
http://esupport.epson-europe.com/ViewArticle.aspx?lng=da-DK&kbid=313180&data=tgU002FqCAQg2JDh7ZlozEek9mmtDiJo80FB&cl=1
Posted on Jun 04, 2009
Magicolor 3730DN toner not installed
I had something similar happen with a Magenta cartridge. My only option was to call Minolta. After hours on the phone they finally agreed to replace the faulty cartridge.
I suspect that from time to tame we receive a cartridge with a faulty chip.
Aug 21, 2012 | Konica Minolta magicolor 3730DN Color...
My CP2025 is printing tiny colored dots on my pages...what do I need to do?
You will most likely need to change what ever toner cartridge that is the same color as the dots. So if the dots are pink change the magenta. If they are blue change the cyan. Most of the time these dots are a result of the toner cartridges drum having a pit or similar defect in it. Changing the toner cartridge will take care of this.
Good Luck and Thank You for using Fixya.
Oct 09, 2010 | HP Laserjet Cp2025n Printer
How exchange cartridge for Epson C1100
Make sure that Ready or Sleep is displayed in the LCD panel.
Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.Then Open Cover A.Push up the right lever to unlock the toner cartridge. Then remove the toner cartridge from the printer.
May 15, 2010 | Epson Aculaser C1100 Printer
I need black ink for my lexmarkc540n printer
This is the worst printer! i advise everyone not to buy!! changing ink every week!!!!! total garbage!!!!!!
Nov 08, 2009 | Lexmark C540N PROD SPECS TBD Printer
Streaks & Smears after changing toner cartridge.
Remove all of your toners and clean them off. Replace each one and make sure they are well setted in the unit before going to the next one. Make sure the carosel turns smoothly and nothing is hanging up on the sides. Reboot the whole printer and let it settle for 5 mins before printing. toners come lose sometimes when you turn carosel around. Hope this helps you these printers are a ***** to deal with ,but when they are right there great.
Sep 08, 2009 | Konica Minolta magicolor 2430 DL Laser...
Changing toner cartridge on copier
Open up the large front door, it will swing downwards. At the top section you'll see four boxes with front handles. Each of the boxes is a slide-out container of toner.
Follow the instructions on the new toner box to prepare it for the copier.
You'll note each toner box has a color designation (on a plastic label just above where you grab). Simply grab the handle on the one you need to replace, pull it out and then slide in a new one.
Also note there are four colors: Yellow, Magenta, Cyan and Black. The LCD screen should indicate which toner bottle(s) to replace.
Aug 30, 2009 | Sharp MX-2300N Color Copier
Changing a cartridge C1100
On the LCD display choose the 'Reset Menu' Then within that menu keep going through the options till you get to 'Change Toner M' (if it is Magenta). Once you select the appropriate Toner it will rotate to offer the correct toner. Open up the front cover, reach inside and change the position of the coloured part of the cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out first. Put the new toner in and turn the coloured part to the locked symbol.
Please take a moment to rate this solution, thanks.
Mar 24, 2009 | Epson Aculaser C1100 Printer
Minolta 2300DL Magicolor printer
EAch cartridge has a small ( about 1/4 inch square) stainless steel color metal tab at the end of the cartridge opposite the refill cap end. The surface of this little tab is visible when the cartridge is "low" on toner and this causes the machine to give the message to change the cartridge. As the cartridge gets older I've noticed that this tab moves to the exposed position more readily, which causes the message to appear. If you google how to reset the position of this tab, then the message will not appear. EVerytime I refill the toner of a cartridge I check to make sure to reset the position of this little metal tab.
It is difficult to describe how to reset the position of the tab. You have to stick a small regular screw driver into the slot below where the metal tab appears and find the lever which can be pushed to reset the position of the tab. You can likely find photos of this procedure on google.
Feb 22, 2008 | Konica Minolta magicolor 2300DL Laser...
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Konica minolta error
I had the same problem and found that one of the toner cartridges must have not been seated properly. I removed the black toner cartridge and re-fitted it. The printer now works fine again with no errors. 17H is a code relating to a fault in the rotation ......... possibly one or more toner cartridges need checking. Use the menu on the printer to turn it to the appropriate position (i.e. engine menu then select replacement of whichever toner you are checking).
Hope this fixes your as well.
Chris
Aug 27, 2007 | Konica Minolta magicolor 2300DL Laser...
Epson Aculaser C1100 Printer Logo
207 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
