Question about 1995-1997 Chevy Tahoe Ignition Starter Alarm Switch
THE IGN A FUSE UNDER THE HOOD KEEPS POPPING
I HAVE A 1997 CHEVY TAHOE,AND THE IGN A FUSE UNDER THE HOOD KEEPS BLOWING .I HAVE REPLACED THE FUSE AND WHEN I TRY TO START IT IT BLOWS AGAIN.
    President:
  • 1,114 Answers
You have a serious short. The fuse is keeping you from frying the electrical system. Did you make any changes to the vehicle recently? Is it all stock electrical? If so, check the Ignition relay in the alternate fuse panel. If that does not work, post a reply and I'll help you dig further. Hope this helps
Posted on Jun 04, 2009
I have a 2002 tahoe and the fuse for the inside lights keeps poping
Posted on Nov 07, 2009
I have a 2004 chevy surban that keeps blowing the ignition fuse what can cause this
You have a direct short to ground on that power feed circuit . You need to find a power distribution diagram to see what all gets is power from that fuse . Isolate the circuits till the fuse doesn't blow any more , then trace out that circuit that blows the fuse .
Which Ignition fuse ? Which fuse box is it in ? under hood , passenger compartment ?
IGN A
40A
Ignition Switch RUN, START, RUN/START/ACCY
IGN B
40A
Ignition Switch RUN/ACC, RUN/START
Could be ignition switch problem , Chevy has had problems with them .
Jul 06, 2016 | Cars & Trucks
I recently put it 4x6 speakers in the extended cab area, now my tail lights are out. I checked all of my connections and could not find a problem there. So is there anything else I could have done? I...
You have likely short circuited some wiring when you were working on that. If you can't trace it yourself, be prepared to have someone with a fresh perspective look at it.
Dec 27, 2013 | Spyder 88-98 Chevy C/K 1500/2500/3500...
97 chevy tahoe wont start from the key but will start from the starter
Check the neutral safety switch. Also some GM have a starter relay in the fuse box. Also you could have a bad ign switch
Apr 06, 2013 | 1995-1997 Chevy Tahoe Ignition Starter...
I have a have 2000 chevy tahoe I need to now why my atc fuse keeps blowing out
the fuse is blowing because there is a short circuit somewhere in the system,,, to help you further I will need to know what fuse it is that is blowing AND what is it that you are doing WHEN the fuse blows ??? what is the Amp rating of the fuse that is blowing ? and in the owners manual ( under FUSES ) what Amp rating does it call for ??
write me back with this info and I will do my best to walk you thru the next steps to solve this problem.
thanks,
c...
Feb 03, 2011 | 2000 Chevrolet Tahoe
1997 GC Jeep, 4.0 L . Keeps blowing fuel pump fuses. Told that 20 amp was recommended.
You should always replace fuses with the same rated fuse as the one removed. Most likely if it keeps blowing the same fuse something in that circuit is directly shorted out.What fuse is it that keeps popping?
Oct 17, 2010 | 1997 Jeep Grand Cherokee
Whre is the fuse box for a 1997 chevy tahoe?
You have two. 1 is under the hood, on the drivers side , an the other is on the side of the dashboard when you open the driver door.
Oct 16, 2010 | 1997 Chevrolet Tahoe
I have a 1995 chevy s-10 and the ecm ign fuse keeps blowing, I can put a new one in and it starts and then dies out and the fuse is blown again. What could that be anyone?
90 Safari van 4.3 engine EMC fuse keeps blowing, found white wire
going to the injector grounded out, solved my problem.
hope this helps from bustedknuckles.........
Aug 21, 2010 | Chevrolet S 10 Cars & Trucks
97 chevy thaoe keeps blowing the ecm fuse
COULD BE FUEL PUMP SHORTING OUT OR PCM HAS A SHORT.
May 16, 2010 | 1997 Chevrolet Tahoe
Keep blowing fuses under hood.
REMOVE THE FUSES ONE AT A TIME FOR EACH ITEM ON THE 50 AMP CIRCUIT. I WOULD START WITH THE POWER WINDOW FUSE FIRST. IT WOULD BE THE MOST LIKELY SOURCE OF A HIGH VOLTAGE DRAW. THEN GO ON TO THE WIPERS AND SO FORTH.
May 29, 2009 | 1995-1997 Chevy Tahoe Ignition Starter...
1995-1997 Chevy Tahoe Ignition Starter Alarm Switch Logo
1,612 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
