Question about HP Photosmart 3210 Printer
Paper won't load up....
I put paper in the main tray and print but it will not catch the paper and will not load up.......please help
  • lkerr2004 Dec 09, 2007
    Printer will not feed the paper from the tray. If i push the paper into the back rollers, it will take the paper. HP will not give any blow up or expaned views to see how to take printer apart to see what is wrong with rollers. Not even the size of the star wrench to use to take the tray out.
Disconnect the printer from power source and computer. Remove the rear access panel and very carefully use a alcohol moistened cotton swab to clean the all the black rubber pick-up rollers. Use a gentle sideways stroke while cleaning and turn rollers to clean all sides. Allow the rollers to dry and replace the rear cover and power up. Worked wonders for me. HP has certain 3210 printers that have this problem.
Posted on Nov 11, 2007
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
Hello, I have a question about the HP 1312 all in one printer. Does it print on legal size paper and where do I load the legal size?
Yes, it can print on legal size paper. Do the following:
Lower the paper tray, and if necessary, slide the paper-width guide to the outermost position.
Fold out the paper-tray extender to catch paper as it exits the device.
Tip: For best results when loading legal-size paper, fold in the paper-tray extender before loading the paper to avoid a paper jam.
May 13, 2011 | HP Office Equipment & Supplies
Starts like it is going to print.......orange light blinks along with on button........Even though there is paper in the main tray, it says load paper....out of paper.
Try putting paper in the accessory tray, also , make sure the "type" of paper is correctly set in the print properties. When you select print, you have these options.
Jan 15, 2011 | Office Equipment & Supplies
My hp laserjet 3005 does has paper loaded in try 2 but always prompts me to load tray 1 to print. I would like the printer to print from tray 2 when it's loaded and try 1 is not loaded. Thank you.
Thank you for contacting FixYa with your printer inquiry.
This is a common problem. The device can be set to print from tray 1 if it is loaded, or to print only from tray 1 if the type of media selected is other than standard bond.
Pull out tray 2 and make sure the paper size adjustments are properly set to match your size of paper. If you are using std bond and the adjustments are set to A-4 it won't pull paper.
HP Control Print Jobs Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=1846088&prodTypeId=18972&objectID=c00764862
HP Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00764851&lang=en&cc=us&taskId=101&prodSeriesId=1846088&prodTypeId=18972
Hope this helps helps. Please keep us updated and remember to rate this answer.
Sep 02, 2010 | HP LaserJet P3005 Printer
IMy wife pulled the paper tray completely out of
Loading your paper
Paper loading tips:
● Load paper with the side to be printed facing down.
● You can print photos and documents on a wide variety of paper sizes, from
8 x 13 cm (3 x 5 inch) up to 22 x 61 cm (8.5 x 24 inch). The 10 x 15 cm
(4 x 6 inch) photo paper is available with and without tabs.
● Before loading paper, pull the Main paper tray out (use the Main tray release or
the tray grips) and slide out the paper-width and paper-length guides to make
room for the paper. After loading paper, adjust the guides to fit close to the edges
of the paper without bending the paper. When finished loading paper, push the
Main tray back in all the way.
● Load only one type and size of paper at a time in the same tray.
● After loading paper, extend the Output tray extension to catch your printed pages.
Use the directions in the following table to load the most commonly used paper sizes
into the printer.
Paper type How to load Tray to load
Any supported
photo or plain
paper media
1. Extend the Main tray by
pulling it out with the Main
tray release or the tray
grips.
Load the Main tray
Chapter 2
(continued)
12 HP Photosmart 8200 series
2. Slide the paper-width and
their outermost positions.
3. Load paper with the side
Check that the stack of
paper is no higher than
the top of the paperlength
guide.
4. Adjust the paper-width
inward until they stop at
the edges of the paper.
5. Push in the Main tray all
the way in.
6. Make sure the light on the
Photo tray button is
turned off to enable
printing from the Main tray.
Load paper and adjust guides inward
1 Paper-width guide
2 Paper-length guide
1 Push the Main tray all the way in
Aug 03, 2010 | HP Photosmart 8250 InkJet Printer
How to load paper
Your model has two trays on the front. The bottom one of these two is where you load the blank paper.
1. Raise the output tray to load paper into the main input tray.
2. Slide the paper-width guide to its outermost position.
3. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
• Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
• Make sure all the paper in the stack is the same size and type.
4. Insert the stack of paper into the main input tray with the short edge forward and the side to be printed down. Slide the stack of paper forward until it stops.
5. Slide the paper-width guide inward until it stops at the edge of the paper.
Do not overload the main input tray; make sure the stack of paper fits within the main input tray and is no higher than the top of the paper-width guide.
6. Lower the output tray.
7. Pull the output tray extender towards you, as far as it will go.
I hope this helps!
Dec 08, 2009 | HP Photosmart C5280 Printer
Dell 3000cn keep getting load mpf when i try to print but there is paper in the tray. how do I get it to recognize the paper. I've changed nothing on the computer but this just started to happen! please...
I have a Dell 3010n myself, and a few times I did run into that "Load MPF" issue.
1.) Before printing a document, please check and see the properties. i.e. Kind/type of paper, which tray, or if printing envelopes or any other document than a regular 8 x11 paper. Putting all the tray and paper type selection on "Auto" can be very helpful.
2.) On the printer itself, there is a menu button where you can configure the type of paper, i.e. regular 20 llb. copy/print paper, glossy photopaper, thicker paper - after you place a fresh load on the paper tray and slide it in, usually it will ask you which type of paper you just loaded. Make sure it is the same settings as the document that you are trying to print: i.e. if document settings on computer was set to print on photopaper and you have regular paper on the tray, the printer will do a "Load MPF".
The paper sensor on it is amazingly (for a Dell, that is) sensitive and it can differentiate across a lot of paper types/thickness. If you have several computers and user across a network, and there are several paper-type settings done on the printer itself, this "Load MPF" issue will present itself more often.
In my case, it's simply because the person who recently changed the paper-type to glossy cover paper from some user who previously printed to a transparency forgot to revert MPF/Tray 1 to regular copy/print paper. Most cases, the printer setting on the PC has been left to print on to a transparency by default, so even if I stack the tray with copy paper to the hilt, it still will do "Load MPF".
Jul 25, 2009 | Dell 3010cn Laser Printer
Paper won't load
first this to do is turn it off unplug, take paper tray out and remove paper and clean the tray, take the printer and put it on it's side (the side where the paper tray goes and see if you get any paper dust to come out. other wise blow air into that area you will see a roller on top need to clean that.
Feb 08, 2008 | HP Photosmart C6180 All-In-One InkJet...
Can't print onto 4x6 photo paper
Did you try this from HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00748340&lc=en&cc=us&dlc=en&product=1155996&rule=45149&lang=en
I also suggest you remove the back door & clean the wheels with a clean no lint water dampend rag. Replace the door.
Jan 26, 2008 | HP Photosmart D5160 InkJet Printer
Hp photosmart d7160
hp photosmart d7160
how can i print 4x6 photo paper ? it says load paper in the main tray its only printing with large plain paper , even if its set to photo tray , and if i put the 4x6 in the main tray it says wrong paper zize ...
Nov 10, 2007 | HP Photosmart D7160 InkJet Printer
HP Photosmart 3210 Printer Logo
183 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
