Question about Philips 9P6040C 60" Rear Projection Television
Phillips 51pw9363 51in
My tv has no signal i can hear the sound but my pix is fuzzie or lines will go up real fast with no pix showing. any help will do
  • Philips Master
  • 3,459 Answers
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom:  No Video. Audio is intermittent. Power light still works
Posted on Oct 12, 2008
Just bought a 55" DP55D44 Sanyo TV, and the picture seems to be showing fuzzy. How can adjust this?
The fuzziness is radio noise from space. No I am not kidding. It's from the background radio spectrum of the universe's creation and it is uniform and OMNI-directional, so it will always appear as snowy noise that is fuzzy in appearance. You can't remove this noise unless you connect a signal from a TV station or cable that is much stronger in strength than this noise. If you mean that a TV signal comes in and appear fuzzy, it is because this TV signal is very weak and you need a better antenna to increase the signal gain. Hope this helps.
Jan 02, 2015 | Sanyo Televison & Video
Phillips 47" flatscreen sounds still
If the TV menu displays your problem is most likely not the Tv , but is caused by the signal source:
Cable box or connections. Reboot everything test using other sources like a DVD player to isolate the problem.
Aug 20, 2011 | Televison & Video
Intermittant sound but the screen is fuzzy with a thick line running down the center of the screen. When playing dvd player picture is fine
this is a problem with the incoming signal of the TV. Check your antenna, set top box or the cable tv input. If the signal is OK then the tuner of the TV is spoilt
Jan 24, 2011 | Mitsubishi Televison & Video
Samsung lns4051d 40in has horizontal lines across screen and additional "fuzzies" on hd channels
This sound likes the incoming signal is week. You should play a DVD player to see if the problem stays same or not.
If you try all sources ie HDMI, AV Component, etc...the TV show the same problem. There are two possibilites: T-Con board or main board need replacing. You should need technician to figure out the problem. Hope it help.
Aug 13, 2009 | Samsung LN-S4051D 40 in. LCD Television
Video game broke my tv
There may be a couple of issues. One could be that if you bumped or wiggled a coaxial cable(for cable or sattelite) the end may be grounding out, and interfering with the video signals in general. For this you may need to call an audio/video installer or your local cable guy. Another solution may be that in your "Quick Set Up Guide" there is a page about setting your convergence. Follow the steps listed in the guide, and see if it helps. If all of your input cables are tight to the back of the TV and you have set the convergence and it still doesn't help, call the Phillips support line @ 1888 744 5477.
Aug 05, 2009 | Televison & Video
Screen failure
sounds like ur xbox is about to go red light soon. It is fixable and i can list the steps for fixing it if u'd like. Kinda complicated, but ive fixed 30+ systems using the process
Jan 13, 2009 | Microsoft Xbox 360 Console
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Phillip tv, picture is fuzzie, Gfx shows a double emage.
please reply to this same post and I will assist you, sounds like the convergence ICs, but I will need your model number in order to help you.
Aug 09, 2008 | Televison & Video
Have a beautiful picture but no sound
your problem is in sound section only. 1 signal line for sound coming from vif section 2 supply to audio section. 3 component fail in audio output section. 4 loose contact in audio section 5 speakr & its connecting wire.
Sep 27, 2007 | Sylvania 6427TE 27" TV
Philips 9P6040C 60" Rear Projection Television Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
