Question about Garland Convection Oven - MCO-NAT Gas
Imperial convection oven LP gas, gets up to temp and then cycles every 3-4 seconds low burner to high burner
  • eriksonenriq
    eriksonenriq Jul 29, 2012
    how to install of fan switch to off
    Brigadier General:
  • 8,619 Answers
Hi
Please check the switch contacts, they may be shorted closed. Check the circuit for any grounds and replace the switch if necessary. For this you'll need to remove the switch and also need to check for the wiring from ignition switch to the burners. Please tell me the model number of your imperial range so that i can assist you better.
Also check the Gas valve/connector whether its firmly held. Also tell me if it clicks after the gas is lighted.
Please see this link for spark module diagram--
Imperial spark module and wiring diagram
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jun 04, 2009
Imperial single older convection ICV pilot lights, have flame, but wont light / heat oven. replaced thermostat, didnt help problem, now what?
I suspect the thermo coupler if there is one. I had to replace ours. I took it out and took it to a repair man and he sold me one just like it. Works good now. Make sure the parts are clean where the gas comes out as well The burner as well.
Oct 20, 2016 | Imperial Ovens
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
What causes the flame switch to cut out ion an Imperial ICVD convection oven
This flame sensor switch is a safety device that only allows the main valve to open after is is satisfied there is a pilot flame. Otherwise if there were no pilot and the main valve was allowed to open, the inside of the burner area would quickly fill with gas and pose an exposion hazard. The original capillary tube type switch is obsolete and a new electronic unit conversion kit is available. Contact Imperial tech support for more information
Apr 29, 2012 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
Convert to lp gas
You will need the owner's manual to follow their LP conversion instructions. You will need the make, model and serial # in order to buy the LP conversion kit (if needed) from a local appliance parts store or from the store where you bought the appliance. Typically, you will be either adjusting (turning down) or exchanging the main burner orifice(s), as well as adjusting the air shutter on the burner venturi tube, as needed for a bluer flame. The appliance regulator will need to be converted, which is usually done by flipping the cap. If you don't have your owner's manual, leave another comment for me with the model # and I'll see if I can find it online for you. I have not worked on this particular type of oven in my neck of the woods, but ovens are all pretty similar in design. Some also have a thermostat that needs to be converted by turning the Nat to LP selector behind the temp dial. Hope that helps. Douglas
Jul 20, 2010 | Imperial ICV-1-H Turbo-Flow Electric...
Vulcan convection oven model SG4d-1 will not ignite burners
Gas does not ignite. No spark. No Ignition light is not ON.
1. Shorted electrode on igniter/flame sense.
2. Igniter cable (high voltage) OPEN.
3. Heat relay malfunction.
4. Centrifugal switch in blower motor inoperative.
5. Transformer inoperative.
6. High limit thermostat open.
7. Interconnecting wiring malfunction.
8. Ignition module malfunction.
Sparks but gas does not ignite.
1. Gas solenoid valve off or inoperative.
2. Manual gas valve closed.
3. Gas supply OFF or insufficient gas pressure.
4. Inerconnecting wiring malfunction.
5. Igniton module malfunction.
Feb 23, 2010 | Vulcan Convection Oven - VC44EC-208-1
Upper & Lower Broiler Flame Adjustment
MY KENMORE OVEN BURNER FLAME IS TO HIGH AND IT WILL NOT TURN LOW
Jul 16, 2008 | Ovens
Bosch HBN 642 -- single oven cycles and doesn't get above 325
WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
May 28, 2008 | Ovens
IMPERIAL ICV-1 SINGLE DECK CONVENCTION OVEN
this is a common indication that the ignition module is probably going bad or the flame sensor is not sensing the flame on the burners. There are other, more technical issues possible but this is usually the most common. The "not restart" , if referring to the burners, is an indication that the ignition module has "locked out" the system, usually after 3 failures of attempts to light the burners.
Oct 31, 2017 | Imperial ICVD-1-H Turbo-Flow Gas Single...
ICVG convection oven shut down during cooking process
Wrench, clearly something is causing them to do what they do. Best I can give you are thinking points.
Does this happen every time?
Is there something else on the circuit that could cause undervoltage?
If the hi temp is tripping, why? Put a thermometer in the oven and see where it is.
Get the factory guy on the phone.
Dec 20, 2007 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Garland Convection Oven - MCO-NAT Gas Logo
Top Garland Ovens Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Garland Oven Expert? Answer questions, earn points and help others
