Question about DeLonghi Pinguino PAC-02 Air Conditioner
Air Con Unit Not cooling the room
I have a PAC36 which is blowing semi cold air into a room 3mts x4mts x2.4mts and the temperature is staying at a constant 20 degrees which is hotter than I require. However when the outside fan kicks in it seems to blow a little cooler but the fan only kicks in periodically
I have no instructions or operating manual can anyone help PLEASE
Regards Paul
    Novelist:
  • 166 Answers
Alright, I'm obviously not there, but you could be low on refrigerant/Freon, and what is more likely, your AC is suffering from some sort of obstruction or debris, as noted in this handy diagnostic article that explains how it could cause your AC not to blow as cold air as you would like:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Hope this helps.
Brad
P.S. As to the loss of your operating manual, try to see if you can get another one directly from the manufacturer by contacting it.
Posted on Jun 05, 2009
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
Sometimes it blows out warm air warm enough to warm an entire room, yet at other times is blows cool air that can kkep a room cool. I want it to blow cold at all times. how do i do that?
dry air feels cool on the skin
moist air feels warm on the skin
this is why the perceived temperature of air from unit changes
Apr 14, 2015 | Dehumidifiers
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
Blows very cold air during dehumidify mode.
se this fact: God bless you
air conditioning system cools but does not dehumidify the room. The most common cause of inadequate dehumidification by an air conditioning system is the installation of a cooling unit which has too much capacity, or is "over-sized" for the space it is being used to cool. What happens is simple:
If an air conditioning compressor unit is oversized (too many BTUH of cooling capacity) what happens is it cools the room so quickly that the system does not move enough total volume of air across the cooling coil to remove much moisture before the room temperature has dropped to the A/C cut-off point.
In other words, an air conditioner needs to run longer, and move more total volume of air through itself to drop room humidity than it does to just cool the air. So "bigger" cooling capacity or higher BTU capacity for an air conditioning system is not necessarily better, and it can actually be a problem.
Sep 30, 2012 | Heating & Cooling
My air-con is not as cold as before. I tried to lower the temperature, but when i try setting the temperature to 18 degrees, the remote just shows 18 degrees for like 5 seconds before going back to 31...
These is because you have not service your air-con for a long time. The cooling fins are clotted with dirt & dusts accumulated for a long period of time, and the water vapour caught between the cooling fins turn into ice when you set lower the temperture for the air-con. Moreover cool air from the blower/fan cannot pass thru', the cooling fins to regulate the cool air into your room.
You have to get the professionals to do a service on your air-con.
Hope it clarify your predicaments.
Jun 15, 2011 | Sanyo Heating & Cooling
I live in a very small one room studio,and have a comfort aire window unit...air and heat.The heat works real well,but in the spring and summer,I would set the unit on the coldest setting.I can hear the...
Lets look at the output of the system first. Take your square footage of the area you are trying to condition and times it by 15. We try to get 15 Btu's per square foot of air conditioning. If your area is say 10 by 15, you have 150 square feet; times it by 15 = 2250 Btu unit is required. If you have a 5,000 Btu unit, it should be more than enough to cool the room. If this is correct, the problem may be because you have the unit set for Dry. In Dry mode, the compressor will cycle less frequently than if on Cool. If in fact the unit is on Cool, you may need to lower the temperature setting to fool the sensor from turning off the compressor prematurly. If you still can't cool the area, your unit has an issue with either refrigeration or air circulation and will need to be serviced.
Apr 09, 2011 | Comfort-Aire Heating & Cooling
Hi I have a Daytek 12000btu. The air con is blowing out cold air but despite having all windows and doors closed the cold air is not circulating around the room. Its only cold when you stand in front of...
air filter, cooling coil and blower wheel are full of dusty. Clean it. And also check RPM of indoor fan motor. If less replace capacitor. If rpm o.k, after clean run the unit. Thanks.
Feb 09, 2011 | Daewoo DSA-122L Air Conditioner
We have a fujitsu air con model ast9lsbcw which blows cold air from the outside unit and the inside unit is not cooling the room.
Sounds like you have it in heating mode or it is low on charge. In cooling mode, the outside fan should blow hot air not cold.
Jul 30, 2008 | Heating & Cooling
Carrier 42G250CF-1 won't blow cold air (on lamp flashes)
sounds like you low on freon, you will need a qualified tech to refill the freon.
Nov 19, 2007 | Heating & Cooling
DeLonghi Pinguino PAC-02 Air Conditioner Logo
950 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
