Question about ASUS S-presso Standard S1-P112 (S1P112STANDARD) Barebone
Trying to install windows xp on SATA hdd wd raptor 74 g , i can see it in bios  but can`t install windows on it, i boot the cd with data lifeguard tool from western digital but nothing....need help
  • 1 more comment
  • uflorin13 Oct 25, 2007
    i don't have a floppy disk ,and no cd for de sata
  • uflorin13 Oct 26, 2007
    i try everything in bios still no...i got now the usb floppy but can find the driver....the hard d is wd740adfd   raptor 74 gb ....barebone system asus s-presso ,mobo p4p8.....
    mobo P4P8T
  • 38 Answers
You need to put the sata drivers onto a floppy disk and when it asks during the xp setup do you want to install any 3rd party drivers say yes and load the drivers from the floppy. The sata drivers with the floppy generator should be on the drivers cd you recieved.
Posted on Oct 25, 2007
  • 1 more comment
  • Alessandro Fuchs Oct 25, 2007
    you need to purchase a usb floppy drive, this happened to me with my new laptop. The driver cd would have come with your motherboard. If not, you should be able to get the sata drivers from the motherboard manufacturers website.
    just thought of one other solution. If you bios supports the feature you can disable raid or you may be able to set sata to have native IDE support. This can sometimes work.
  • Alessandro Fuchs Oct 26, 2007
    im headed out for a few minutes but when i get back ill take care of finding that driver for you.
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
I'm trying to install WD Caviar Green 1TB in my Dell Dimension 4600. It appears as though the exhisting hard drive used a SATA connection w/molex power connection. I have tried downloading the WC...
I BELIEVE THAT WD PROVIDES A CD WITH "WD DATA LIFEGUARD UTILITIES." IF YOU USE THAT DISK AND SELECT "DRIVE TO DRIVE COPY" SELECTION. THIS SHOULD CREATE A CLONE OF YOUR ORIGIONAL DISK. SELECT THE NEW DRIVE TO BOOT FROM EITHER IN BIOS SETTINGS OR FROM THE BOOT SELECT "F12" OPTION.
THE PC SHOULD BOOT FROM THE NEW DRIVE IF SELECTED
ED P
Aug 09, 2010 | Dell Dimension 4600 PC Desktop
Booting
When it come to deleting partitions or adding partitions I suggest you download WD's Data Lifeguard Tools. WD's User manual;
http://www.wdc.com/en/library/other/2779-001005.pdf
The object is to setup you're partitions in DOS mode by creating either a bootable CD or a bootable floppy disk. Using windows is not always the best way.
Same for you're Samsung drive, ES-Tool;
http://www.samsung.com/global/business/hdd/support/utilities/ES_Tool.html
Once completed installing you're operating system should be simple. Be sure to check the boot order in you're bios before loading you're OS.
Mike
Jun 06, 2010 | Asrock ConRoeXFire-eSATA2...
Can't install Windows XP Home on Compaq CQ50-139M Notebook
I would run a deeper scan of the hard drive while hooked up to the SATA -USB enclosure. Try using either Seatools or Western digital Data lifegurad tools and run the long scans. If the XP CD is in fact SP-3 it should have all of the necessary drivers for SATA drives. I am suspecting some bad sectors and a possibly failing hard drive, which would also explain why Vista froze.
These diagnostic tools can be found at:
http://majorgeeks.com/Western_Digital_Data_Lifeguard_Tools_d2855.html
and
http://majorgeeks.com/Seagate_SeaTools_for_Windows_d2858.html
Sep 27, 2009 | Acer Aspire 5610-4648 Notebook
WD Sata drive was working perfectly then during the night
As you hear a tickling sound, I am pretty sure the HDD has gone faulty. Only way to see whether you can recover the data by your self is to fix the HDD into a external SATA enclosure and see whether it works and detected by the PC.
Otherwise the only option is to go to data recovery specialists who are normally very expensive.
It is worth contacting a local computer shop first.
All the best!
Jul 28, 2009 | Western Digital Raptor® WD1500ADFD 150 GB...
Hdd wd raptor 74 gb serial ATA
does the machine recognize the hard drive ????
Windows software doesn't care what hard drive you have, as long as the machine can detect it and mounted.
Sep 06, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Installing win xp
Check in Bios whether your sata hdd is detected or not.if yes select the first boot driver to cd/dvd rom and second boot drive to sata hdd..
Jul 22, 2008 | Intel Motherboard
NI8 SATA DVD Drive compatability
You must have added the SATA drive after setting up the IDE. If both drives are using the same os this will not function. Ony one drive can have the os on it. All SATA's are seen as a master.
To correct this problem, disconnect the IDE drive. Hook up the SATA drive. Again if the SATA has the os on it everything will run. Change the jumper on the IDE and set it as a slave. Hook the IDE up. Enter the bios & do not list the IDE in the boot to section. Problem solved. While in windows, format the IDE drive.
You do not want windows thinking you want a dual boot system.
So you understand, in the bios -boot settings this is how things should be listed.
Boot device 1 Sony Optiarc DVD drive
Boot device 2 WD raptor SATA, In-stall your os to this drive
Mike
Mar 22, 2008 | Abit NI8-SLI Motherboard
I can't use HDD sata on mainboard ASUS P5RD1-VM
Things need to be turned on in your bios patrohi. This is why windows didn't boot to the SATA. You need to use your manual & make sure the, Serial ATA Controller is [Enabled]
Within the Advanved menue under SouthBridge Configuration.
At the Main menue the SATA drive should be listed.
Boot settings need to change as well. At Boot Settings Configurations. Make sure your SATA drive is listed.
Boot order should list like, Floppy 1st, CDROM 2nd, SATA 3rd. The SATA will not list as a SATA but the model number of the SATA drive. Once all these settings are set save & exit. Your drive should show up for work & the windows CD should load.
Feb 20, 2008 | ASUS P5RD1-VM Motherboard
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
ASUS S-presso Standard S1-P112 (S1P112STANDARD) Barebone Logo
377 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
