Question about Microsoft Xbox 360 Console
None of my games are working, they all say unreadable disc. I bought a new game to see if it was the xbox and it said unreadable disc as well what do i do?
    Problem Solver:
  • 9 Answers
Sounds like a DVD drive failure, which is not uncommon in the first or even second generation xbox 360's
if it's out of warranty take apart the xbox and replace the drive. if it's not call Microsoft and get it repaired
Posted on Jun 04, 2009
    Problem Solver:
  • 18 Answers
# Turn console off and then on. # Clean the disc and examine it for flaws or scratches. # If this behavior occurs with one or two discs, search the Microsoft Knowledge Base for the specific game title(s). If you find a known problem, follow the information outlined in the article. # Delete the appropriate saved games. See Note 1. Copy a saved game to a Memory Unit (MU) if you have one available. # Try three other games, and then try the original game again. # Try the game on another console if possible. # Replace the disc at retailer. # Repair the console Note 1 If a saved game file is corrupted, it can produce a disk error message in that game, particularly when the game starts. You can resolve this issue by deleting all saved game files for the affected game from the Xbox hard disk. This method is effective approximately twenty-five percent of the time. If you experience this disk error message with more than two games, this procedure will likely not resolve the issue. Another trick to try is to turn your console so its vertical( sometimes works)
  • 8 Answers
SOURCE: xbox 360 unreadable disc
If you have a close-by friend check the game on his xbox to see if you get the same error. If you do not, then it is most likely your xbox. You may need to return it to Microsoft.
Try to insert the disc, power off the xbox, unplug it completely. Wait 30 seconds then plug everything in and power it back on and see if you get the same error message.
If none of these suggestions are an option, you may want to purchase a $10-$25 CD that has bristles that cleans the lens that reads the CD's inside the unit. (I know Maxell makes them) Then try the game again.
Posted on Dec 29, 2007
THE SAME THING HAPPENED TO MINE I SENT IT TO MICROSOFT AND THEY FIXED THE PROBLEM. IT USUALLY IS THE DISC LASER THE READS THE DISC.
Posted on Apr 29, 2008
ctf1800
  • 4402 Answers
SOURCE: my game wont work
http://serviceman.site88.net/index_files/GameConsoles.htm
Posted on Jul 07, 2008
  • 28 Answers
SOURCE: My xbox 360 keeps saying disc is unreadable!
bad disc drive most likely, unless you tempered with it...could also be a bad connection
Posted on Feb 07, 2010
  • 12 Answers
SOURCE: xbox says disc is unreadable
Your xbox may be overheating. To fix the problem, what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in.
Posted on Nov 05, 2011
Fifa 13 says unreadable and all other games work
sounds like the fifa 13 is scratchd 1 go to bathroom 2 use soap 3 dry the disc 4 insert disc into the drive and restart the console 6 if this dosent work call xbox they will give support
Nov 03, 2012 | Microsoft Xbox 360 Console
I bought a new xbox360. the game that came with it works great. I also bought the guitar hero. when i put in my new disc and it says unreadable. Replaced with a new disc still says unreadable. Other game...
If the guitar hero is new, I recommend taking it to where you purchased it and having it replaced. Tell them it will not play on your brand new XBox. Sometimes, rarely, you can get a defective disc.
Hopefully that will fix your problem. If not, you might look into returning the system for a new one.
Jul 25, 2011 | Rockstar Games Video Game Consoles & Games
Bought a brand new game, fire it in ,it starts up, it goes through its procedure then about 2 mins later it says unreadable disc, old games work fine any ideas ta much rob the new disc works in...
this is simple only to fix the problem,, check your xbox version and the game version.. some games will not support for some xbox.........
its it better you can use repair guide to fix this problem...
click here to download the repair guide...........
Oct 05, 2010 | Microsoft Xbox 360 Console
Feb 07, 2010 | Microsoft Xbox Console
It says the disc is unreadable and ive cleaned
Ok this worked on my mw2.
Take some toothpaste, a soft cloth.
wet the dist then dab a small amount on the game disk. (NOTE!!) STREAK OUTWARS TO THE EDGE NOT IN CIRCLE IF YOU DO NOT DO THIS IT WILL MAKE IT WORSE!.
after youve done this wash and repeat 10-15 times (note) it will take about an half an hr if you do it properly.
Dec 31, 2009 | Microsoft Xbox Console
Fight Night Round 4 disc unreadable
carlo me hi hello to all im new sign up to fixya hi 2 all!.
Jul 06, 2009 | Microsoft Xbox 360 Console
My game wont work
Jul 04, 2008 | Microsoft Xbox 360 Console
Madden 08 is unreadable with my hard drive connected
Hmm.... I encountered this once. Check the disc and check for scratches. Then, use a dry soft cloth (must not be wet at all) and rub it around the disc but don't rub the center of the disc. If this doesn't work swap the game. I mean give the Madden with the problem to EB Games or Gamestop and swap it for a brand new one. It should work fine.
Jan 02, 2008 | Microsoft Xbox 360 Console
Xbox 360 unreadable disc
Dec 29, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
99 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
