Question about Canon imageCLASS MF6550 All-In-One Laser Printer
What is a rx report - Canon imageCLASS MF6550 All-In-One Laser Printer
    President:
  • 1,126 Answers
Rx Report is reception report for documents that have been received.
Tx Report is a report (confirmation) of faxes sent (transmitted)
Posted on Jun 04, 2009
How do I get a paper conformation for faxes on a cannon mx922
From page 98 of the fax users manual:
"This report is printed after each fax reception.
• At the time of purchase, the machine is set so that RX REPORT is not printed at all.
You can set the machine to print RX REPORT each time it receives a document, or only when an error occurs by selecting RX report in Auto print settings under FAX settings."
You should have the manual on the cd that came with the printer. If not try the link listed.
Canon Consumer Home Office PIXMA MX922
Dec 22, 2014 | Canon PIXMA MX922 Wireless All-in-One...
Can you please tell me how to print Fax activity report each time? means whenever I send a fax I need confirmation receipt thats its gone through.Can't find anything in Manual.
ACTIVITY REPORT
The FAX is factoryset to automatically print an ACTIVITY REPORT after every 20
transactions. If you want to print an ACTIVITY REPORT before it is automatically
printed, follow this procedure:
Transactions in an ACTIVITY REPORT are listed chronologically.
1 Press Function.
2 Press Report.
3 Press OK.
• The FAX prints an ACTIVITY
REPORT.
• If you prefer the FAX not to print an ACTIVITY REPORT after every 20 transactions,
disable the ACTIVITY REPORT setting ( p. 145).
• Please note that only one transaction number (TX/RX NO.) is assigned when you send
a document to several fax numbers in one operation.
ACTIVITY REPORT
PRINTING REPORT
27/12 2002 15:00 FAX 123 4567 CANON 001
ACTIVITY REPORT
ST. TIME CONNECTION TEL CONNECTION ID RESULT
* 27/12 13:43 905 795 1111 Canon CANADA 5001 AUTO RX ECM 1 OK 00'33
* 27/12 13:45 905 795 1111 Canon CANADA 0001 POLLING RX ECM 0 OK 00'00
0 STOP
* 27/12 13:51 03 3758 2111 Canon TOKYO 0002 B'CAST ECM 3 OK 01'18
* 27/12 13:53 2 887 0166 Canon AUSTRALIA 0002 B'CAST ECM 3 OK 01'18
* 27/12 14:10 905 795 1111 Canon CANADA 5002 AUTO RX ECM 1 OK 00'18
* 27/12 14:16 2 887 0166 Canon AUSTRALIA 5003 AUTO RX ECM 4 OK 03'59
* 27/12 14:27 20 545 8545 Canon EUROPA 0003 DELAYED TX ECM 1 OK 01'20
27/12 14:30 20 545 8545 Canon EUROPA 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:31 03 3758 2111 Canon TOKYO 0004 DEL SQ BDCST ECM 1 OK 00'36
27/12 14:57 2 887 0166 Canon AUSTRALIA 0005 TRANSMIT ECM 3 OK 01'25
0 STOP
27/12 14:59 1 432 2060 CANON OPTICS 0006 TRANSMIT 0 OK 00'01
0 #018
go to this site to download manual (see page 11-3)
http://files.canon-europe.com/files/soft30110/manual/FAX_L220_L295_UG_ENG.pdf
Dec 16, 2010 | Canon L220 Plain Paper Laser Fax
How do i print activity report from canonL100
Press the MONITOR BUTTON,it is the button with the block and a eye sign in it.TX RX RESULT will be displayed.Press the arrow down ones PRINT REPORT will be displayed,press ok,TX RESULD will be displayed.By pressing the arrow down you can choose beteen RX,TX and ACTIVITY reports Press ok and it will print out.
Aug 19, 2009 | Office Equipment & Supplies
We are getting a message "waiting on report" when trying to fax
I experienced this problem when "Fax Setting -> TX Setting -> Print Report" is configured before you send out the fax.
After your Fax was sent, and the message "Waiting for report" appear forever and does not leave.
It is because your INK Level is Low and your have set "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report will not be printed out due to ink level is low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed out immediately, the message disappear.
May 29, 2009 | Canon PIXMA MX300 All-in-One Printer
Need to cancel RX report page
Flip open the one touch panel, Punch "Data Registration" arrow right to #3 Fax Settings, punch set, arrow right to Report settings, punch set, arrow right to RX Settings, punch set, Arrow right to OUTPUT NO, punch set. punch stop, your done!
Feb 19, 2009 | Canon LaserCLASS Fax 710 Printer
Cannon MX310 - Fax - Waiting for report
I had the same problem.
My INK Level was Low and I had the setting "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report would not print due to the ink level being low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed immediately, and the message will disappear.
Jan 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Fax Report Question
i believe it means rx receive and tx transmitt
in rs 232 communication (serial communication modem fax etc) line 2 is tx (transmitt and 3 is receive rx hope that helps
Dec 30, 2008 | Brother IntelliFAX 2800 Laser Fax
I want to have the MX310 to answer on 4 rings
Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [ RING COUNT] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
To print the Activity Report, Coded Speed Dial List, User's Data List or Memory List: 1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select the desired report, then press <OK>. The report or list is printed.
Try to download the manual
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603#DownloadDetailAct
I hope it helps!!!
The TX Report and RX Report print upon transmission or reception offaxes depending upon the settings made in [FAX SETTINGS->TXSETTINGS->TX REPORT] and [FAX SETTINGS->RX SETTINGS->RXREPORT], respectively
Dec 08, 2008 | Canon PIXMA MX310 All-In-One Printer
How do I turn on the Fax conformation
you need to go into rx setting and turn rx report back to on,
and go to TX settings and turn Tx report on.
this can be found in menu, device settings, fax setting, (tx and rx report will be shown) change it from there
hope this helps
Oct 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon FaxPhone L80
Press Function, Data Registration, and then Set. Use the up/down arrows to select "report settings", then Set again. Using the arrows and Set change the values or TX REPORT and RX REPORT to "YES". This will pring a TX/RX report after every fax. When you are done press Stop/Clear. This is from Sectioon 14 of the owners manual. Let me know if you need more help.... Mediaman85@mchsi.com
Aug 20, 2007 | Canon FAXPHONE L80 Laser
Canon imageCLASS MF6550 All-In-One Laser Printer Logo
1,645 people viewed this question
old marine
old marine
