Question about Philips Magnavox MT1905B 19" TV
Coaxial connector broken
My kid tripped over the wire and the coaxial connector was pulled out of the tv.... Its a soldered in piece and I can remove & install a new one.... I need to figure out where I can buy the replacement one....
I have a magnavox plasma 50", when i remove it from the table i forget to unplug the coax cable from the back of the tv so i pull the connector out from it, anyone tell me what can i do to repair or replace this solution?
Posted on Jun 24, 2009
My son trip over the cable cord and pulled out the cable connector, were you connect the cable cord.
  • Using a wire cutting tool, cut and remove the outer sheath of the coaxial cable approximately 1/2-inch down from the end of the cable. Take care not to cut too deep or you will damage the aluminum sheeting and perhaps even the plastic wire insulation. Peel back the aluminum sheeting so it wraps around the outer sheathing and remove about 1/4 inch of the white plastic wire insulation using the wire cutting tool to expose the thin cable wire.
  • Attaching Connector
  • Slide the ferrule ring, which is the metallic piece used to hold the connector on the cable, onto the coaxial cable. Push the connector onto the cable so the white plastic wire insulation rests up against the inside of the connector. Slide the ferrule ring forward so it covers the bottom end of the coaxial connector.
  • Finishing
  • Crimp the ferrule ring tightly around the wire and the connector. You may notice that some of the aluminum sheeting that you pulled down sticks out of the bottom of the ferrule ring. Trim the sheeting before using the cable.
    Feb 28, 2011 | Televison & Video
    My coaxial connector broke off. i have a new F connector now but i dont see where to solder it on to. can you help me find where i should solder on the f connector?
    The connector needs to be soldered in two ways. The center connector needs to be soldered to the same point as the original. This may have broke off close to the small circuit board inside the tuner and you hopefully can see the broken piece sticking out. The tuner should ideally be removed to accomplish this. The tuner usually has two shields that snap in place that can be removed. You may be able to solder a short piece of wire to the remainder of the original connector. The outside of the f connector also needs to be soldered to the tuner shielding itself as a ground connection and you will need a soldering gun or higher wattage iron for this step. Use a lower wattage soldering pencil for the signal connection to the tuner board.
    Nov 18, 2009 | Televison & Video
    Broken coax connection on back of unit
    If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
    All you need is:
    1 - 8" piece of coaxial cable with male connector on one end
    1 - set of RCA cables (Red/White/Yellow)
    1 - coaxial coupler
    2 - small wire nuts
    electrical tape
    Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
    & remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
    Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
    Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
    Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
    Jan 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
    Tuner replacement on RCA D52W20
    All you need is:
    1 - coaxial coupler
    2 - small wire nuts
    electrical tape
    Jan 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
    Broken coaxial
    All you need is:
    1 - coaxial coupler
    2 - small wire nuts
    electrical tape
    Nov 10, 2008 | Samsung LNT4066F 40 in. LCD Television
    Coaxial output broken
    If the connector end is not damaged and the tuner circuit board is not broken, you can solder this back onto tuner, and solder the end back on the circuit board. You should take the tuner out to do this proceedure. A TV shop usually charges $50.00 to do this.
    Oct 24, 2008 | Sanyo DS20930 20" TV
    Connecting a samsung dvd-vr to TV with cable & rf modulator
    my coaxial cable hook up is broken from the plasma. Can i fix it?
    Jun 15, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
    Coaxial outlet broke off
    I assume that you pulled the F connector out of the back of the TV. In most Sharps, the F connector is attached directly to the tuner, which is the rectangular silver metal box soldered to the main PC board. Did you buy a replacement F connector or the entire tuner? Either way, the tuner must be unsoldered from the main board and the new F connector is soldered into the old tuner or the new tuner is soldered in its place. If you do not have experience soldering PC boards then let a qualified tech handle it for you.
    Jul 02, 2007 | Sharp 25R-S100 25" TV
    Coaxial input jack on the TV broken off so I cannot connect my coaxial cable from wall
    All you need is:
    1 - coaxial coupler
    2 - small wire nuts
    electrical tape
    Sep 18, 2006 | RCA D52W19 52" Rear Projection Television
    Philips Magnavox MT1905B 19" TV Logo
    504 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
