Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printing crooked The printer prints each page crooked. I have reloaded the paper and it doesn't fix. Can you help? Thank you jbmcmullin
  • Anonymous Feb 05, 2009
    I had the same problem...Figured out the back panel that covers the rollers wasnt on all the way.
As "Guest" posted on Feb 05, 2009 the problem for me was the box in the back of the printer that facilitates double sided printing. One side had come loose. I was getting "Paper Mismatch" errors, and the text was printing slanted. I simply pulled the box out and reinstalled it. Problem solved.
Posted on May 20, 2009
    Genius:
  • 1,601 Answers
  • 175 Answers
I did not see this in the HP help article but, if all of the solutions do not work you also might want to try to re-install the printer drivers.
Posted on Nov 10, 2007
Canon MX320 crooked printing
They are correct. Inkjets are almost never worth fixing, the parts are to costly. Get a laser jet you will save yourself a lot of grief.
Jul 09, 2012 | Canon PIXMA MX320 Color USB InkJet Printer
My Epson Workforce 600 prints crooked
Yours is broken and theirs is good. When they are not looking switch them out....lol
Apr 21, 2012 | Epson WorkForce 600 All-In-One InkJet...
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Paper tears when printing
Helllo sir; I would say 99 % you have paper chip stuck in the paper path , ckeck the fusing unit,
Apr 14, 2009 | HP Color LaserJet 2600n Printer
Alignment page is printing crooked
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | HP PSC 750xi All-In-One InkJet Printer
Printing crooked, blurred, bad roller?
Sounds like when you pulled out the paper jam, you misaligned the print carriage. That would produce both the noises you hear and the print quality issues. HP.com has a few web pages on their site that might help. The first one deals with noisy print carriages. Unfortunately, it's not dedicated to just your product, but the steps should generally apply:
Resolving Noisy Print Carriage Issues
There's a separate web page available for troubleshooting crooked or skewed printouts:
Printed Text or images are Crooked or Skewed
If all else fails, unplug the power cord from the printer, wait 20 seconds or so, then plug it back in. That should restart the printer and make it go into a self test which may include a realignment procedure. Watch for any error messages on the display on the printer's control panel. Sometimes to realign, it prints out two test pages and instructs you to place the first printout on the scanner bed and then press Enter.
Go to the following web page and when it opens, scroll down to the section "Replacing the print cartridges", and find step 9 in that section for alignment instructions.
Replacing Print Cartridges
Good luck.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Laser jet 4m
There is likely a problem with your fixing unit (also called a Fuser).
This is a device at the exit of the printer that squeezes the paper between a pressure roller and a heat roller. The heat is what "fixes" the toner onto the paper.
Either your paper is being fed crooked, or there is a problem in the fixing unit itself.
Remove your drum/toner cartridge. Look into the empty chamber of the printer and see if you can see any objects or bits of paper. Clean it out as best you can.
If your toner and drum are separate cartridges, separate them and make sure they don't have any bits of paper stuck between them. If they are both contained in one cartridge, then skip that last step.
Remove your paper tray and make sure the tabs are set correctly. There should be a tab at the back to snug tha paper length wise, and one at the side to snug the width. Setting these correctly will help prevent crooked feeding.
If you can see your paper pickup roller just over top of where the tray fits, make sure it is clean and not too badly worn.
Try printing something but turn the printer off about 1/2 way through the print cycle. Open the door and remove the drum. The sheet of paper should be stuck inside the drum. Examine it and see if it was feeding crooked. After examining it, remove it carefully and throw it in the trash. Don't touch the type as it is not fixed and will dirty your hands or clothes.
If the paper in the drum was straight, then there is a problem with your fixing unit. If the paper was crooked, then there is a pickup/feed problem.
Feb 14, 2008 | HP LaserJet 4 plus Printer
Page printed crooked
Ensure paper edge guides on paper cassette are set to correct paper size ie .against edge of paper.
Dec 26, 2007 | Brother DCP-7020 All-In-One Laser Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
4,313 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
