Are you following Anti-Static Procedures?
If you, or the person who took it apart has not, you can use the motherboard for a Frisbee.
(Processor for a neck trinket, and Ram Memory for Christmas decorations)
Moving on.........
HP Support > Pavilion p6610f Desktop PC > Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=4299342Product information > Product specifications > Motherboard Specifications, N-Alvorix-RS880-uATX (Alvorix),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02560084&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4299342A) Let's start with the two power cables coming from the Power Supply, that go to the motherboard;
1) 24-pin ATX main power cable
Looking at the motherboard photo, the 24-pin ATX main power cable's connector; is at the bottom.
Two rows of 12 socket holes, in a yellowish/whitish connector.
Motherboard installed in computer case, you will find it to the Right.
(The motherboard view shown, is clocked 90 degrees to the Right; in comparison to how it actually sits in the computer case)
GENERAL example,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24[NOTE* Color of connector does NOT matter ]
Note the hinged Lock Clip on the power cable's connector.
Also the TAB on the motherboard connector.
When power cable is deemed to be plugged in tightly, and properly; the Lock Clip will be over the Tab.
{Lock Clip operates on the same principle, as a see-saw on a playground. Top is squeezed in to release Lock Clip}
2) 4-pin ATX +12 Volt power cable
Looking at the motherboard photo, the motherboard connector for this power cable is;
Straight up from the white Processor socket,
To the right of the square finned Aluminum Heatsink.
General example of said power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Has a Lock Clip too.
Remember about the color of connector, thing.
Can be pink with neon polka dots. Doesn't matter.
WHAT the power cable IS, does matter.
This power cable is power for the Processor.
It ain't plugged in, you have no computer.
(Scroll down to Motherboard Layout. It is PU521 )
That's it for power cables that plug into the motherboard.
Moving on..........
The Harddrive is a SATA unit. The optical drive is a SATA unit.
(CD/DVD drive)
Means you need a SATA power cable for each one of them.
General example,
http://www.playtool.com/pages/psuconnectors/connectors.html#sataNote the L-shaped opening in the connector. Hard to see in this photo, but I will show a better view in a minute.
Also; between a SATA data cable's connector, and a SATA power cable's connector; the SATA power cable connector is the larger of the two.
Has 15 contact pins.
SATA data cable connector has 7-pins.
Often there is a lock on this power cable's connector.
A tab that sticks up, or a 'bulb' type affair.
Depress with thumb, when plugging in, or unplugging.
Harddrive needs a power cable, and data cable.
So does optical drive/s.
B) General example of a SATA data cable, and it's respective connector,
http://en.wikipedia.org/wiki/File:SATA_ports.jpgJust referring to the cable shown at the top, for now.
Now you can see the L-shaped opening a little better.
See how the 'foot' of the L goes down? That is the direction you want it, when plugging in.
The motherboard connector shown below the SATA data cable, is a SATA connector.
This particular style is OPEN.
Your motherboard uses the type that is CLOSED.
Note also the L shape on the motherboard connector.
The connector shown for that SATA data cable, is a 90 degree bent elbow.
If your SATA data cables have this style of connector, they plug into the Harddrive, and optical drive/s.
The straight type of connector, plugs into the motherboard.
It can also plug into the Harddrive, and optical drive; if your SATA data cable has two straight connectors.
The SATA data cable connectors on your motherboard, are all the way to the Left. (In the motherboard photo)
Orange, Light Blue, Dark Blue, and White.
Note that they have a L shape in the middle.
Now scroll down the HP Support page, to Motherboard Layout.
Orange = SATA4
Dark Blue = SATA1
Light Blue = SATA3
White = SATA2
SATA1 is for the Harddrive
SATA2 is for an optical drive.
If you have more than 1 optical drive, it plugs into SATA3.
(Make sure SATA3 is ENABLED in BIOS Setup)
C) The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
Looking at the motherboard photo, look again at the Orange SATA4 connector. To the Immediate RIGHT is the Front Panel header,
http://www.findlaptopdriver.com/n-alvorix-rs880-uatx-front-panel-motherboard/I believe though, that the cable coming from the Front Panel; has one solid plug-on connector. Not individual wires.
Note how the Front Panel header on the motherboard, is missing one pin. This is the Key.
The cable connector going to it, should have one socket hole blocked off.
Should only be one cable coming from the Front Panel, that has the correct plug-on connector.
The other cables coming from the Front Panel, will have different size plug-on connectors.
Going further.........
Look at what is installed in the Front Panel;
USB ports, audio ports, (Headphone and Microphone), Card Reader, etc.
You can follow the cables, and get a pretty good idea of where they go, in the Front Panel.
For example you can follow the cables that go to the USB ports.
Follow the two cables that go to the Card Reader.
Follow the cables that go to Microphone, and Headphone jacks.
Then by process of elimination, you know which cable goes to the Front Panel header.
D) Front Audio
Looking at the motherboard photo, look towards the Top/Left corner.
The Yellow header is for the Front Panel audio ports.
Headphone, and Microphone.
E) Coming down the Left side, in the motherboard photo; look at the two White rectangular headers.
Match up in the Motherboard Layout, and bottom of HP Support page.
USB1 2, and USB1 2.
EACH USB header, is for TWO USB ports.
That is why they both have USB1 2 marked near them, in Motherboard Layout.
A Card Reader SHOULD use two cables, and One USB header.
It may be though, that the Card Reader will use both of those White USB headers.
Either the Card Reader plugs into them, or the USB ports in the Front Panel.
If the cable connector fits, plug that cable in. (On)
USB is USB.
Card Reader uses USB too.
Point?
If the cable's connector fits, plug it in. (On)
In the motherboard photo, there are two White connectors;
Above the Orange SATA4 connector, and Below the Light Blue, and White SATA connectors.
(Light Blue = SATA3, White = SATA2)
The USB ports up front probably connect to them. (Front Panel)
Follow the cables to Front Panel USB ports.
What type of connector do the cables use?
All FOUR of those USB connectors on the motherboard, may NOT be used.
Perhaps just two of them.
That doesn't 'sound' very concise, huh?
However it is my contention, that each cable coming from the Front Panel; should have a different connector.
Going further;
The Card Reader, and the USB ports in the Front Panel; may have the SAME type of connector, on the end of their cables.
Again, the Card Reader uses a USB header, (Or headers), on the motherboard.
So do the two USB ports in the Front Panel.
Therefore it does not matter which USB header on the motherboard, that either one of them are connected to.
F) Looking at the motherboard photo, look above the Ram Memory slots, to the far Right.
Right above ram memory Slot 1, that is White in color. (DIMM 1)
There is a small Electrolytic Capacitor, with a Black plastic sleeve.
Right above it is a small White 3-pin connector.
This is where the Processor fan plugs in.
(CPU_FAN)
G) Right above the square Aluminum finned Heatsink, is the 3-pin connector for the computer case fan.
SYS_FAN
(System Fan)
(The square Aluminum finned Heatsink, sits on the Northbridge chip.
Which is part of the motherboard chipset)
That about does it for me.
Please post additional questions in a Comment.
Regards,
joecoolvette
[Seems like I gave a solution for this before.
I can't pull it up in Solutions I have given, so do not know for sure.
Want to see someones user account?
If you are a member of FixYa, all you have to do is click on their user name (Example; joecoolvette), or user icon ]
