Question about HP DeskJet 932c InkJet Printer
Colors are not printing correctly. put in a new cartridge, test page came back with only black, yellow, and blue. fiddled around with it a bit to no avail. put in anther new cartridge, test page came back with black, yellow, blue & green. what to try next?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 275 Answers
I use a small diameter silicone tube to carefully "prime" stubborn new carts by sucking a drop of ink out of the tiny print holes in the printhead part of the cart. Ink can dry at the head and since these carts work by electrical excitation, there needs to be liquid of each color at the holes. Slap a drop of water with your finger on the holes to start easy hesitant ones. Do not get the contacts wet.
Posted on Dec 08, 2010
Why won't a new tri-color cartridge print red?
Tri color cartridge contains Cyan,Magenta & Yellow color inks, mono cartridge contain black ink, combination/mixing with these inks desired color out put will prints on paper.. If any one or more inks are missing/dried, result mis matched print outs on paper.
In your case I feel it's Magenta ink is not firing..,nozzles may clogged, try to clean the nozzles with solvents & try it...If no result ,. replace the color cartridge..
Mar 28, 2015 | HP PSC 1315 All-In-One InkJet Printer
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
Whenever I print color, entire page comes out blue. I have replaced the cyan cartridge (twice) and the Laser Transfer Kit. Sometimes there are thick blue streaks in addition to the overall blue color. What...
Run the "disable cartridge check"
It will be in the Diagnostics.
Once you start the test, you can remove all the cartridges. Put the cyan in the black cartridge slot.
print a config page. If it is all blue, you have another bad cartridge. If it prints correctly(minus the other colors)...continue
Now put the magenta in the cyan cartridge slot. Print the config page again. If you have red all over the page, you have a problem with the slot itself.
Press the STOP button and then select EXIT diagnostics. Put the cartridges back where they all go and run CALIBRATION more than once.
Select/menus/down arrow/configure devce/select configure device
Down arrow/print quality/seect print quality
Down arrow/ calibrate now. Select it and wait.
Oct 25, 2010 | HP Color Laserjet 3550 Printer
I have new photo (58) and color (57) carts and when I print wallet size (9 pics per 8.5x11 photo paper) the first 3 print true color and the last 6 are blue. I have cleaned the rollers and still do not...
hello, you are using the photo color ink cart, have you tried running a cleaning cycle or test print, the reason why i ask, is that maybe 1 of the colors is not printing, the test pages would prove what color is missing, if black not printing, it would print possible blue, or no black at all. i know you have put in new inks, but since the volume of ink in these cartridges run out according to usage, one color might run out before the others, and since black and yellow are the most used colors, without them your prints will show color faults.
Oct 07, 2010 | HP PSC 1350v All-In-One InkJet Printer
Color mismatch
This is kind of hard to diagnose with just what you list. However there are a few things you can do to test it further.
What I usually do is open up Microsoft paint (start-all programs-accessories- the click on paint)
Then make a small box and print the 3 primary colors plus black (red, blue, yellow) see if all three colors print. My guess is only one will print (blue) if this is the case then the ink cartridge is most likely dried up or defective. Also if you have not printed something in a very long time this can also cause the cartridge to dry up. Again this is based on a guess that I think your cartridge might be dried up. However it can be a number of other items.
Also some printers have there own test pages you can run that can also tell you what colors are working and what colors are not.
Thanks again
Hope this helps you out a little bit.
Steven.
Apr 21, 2010 | Brother MFC-5840CN All-In-One InkJet...
Hi Ihave a MP-500 that prints off color.
You need a new printhead, QY6-0059-000, around $60.00. They do wear out and also plug when you use generic inks.
Oct 23, 2009 | Canon Pixma MP500 All-In-One InkJet...
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Despite installing new cartridges,cleaning and priming, my HP Deskjet 710C prints pink only. Using Windows XP test page shows no blue, or yellow.
hi,
do you installing both cartridges (black and colour)?
if you do so, my advice is to reinstall the driver for your printer.
if you install ONLY the black cartridge, and the color cartridge remain the old one, (which in my opinion is the present case), your problem is from the color cartridge.
The color cartridge have 3 colors and this are: cyan (some kind of blue), yellow and magenta (similar with a pink color, but more intense). The problem is simple: in your color cartridge has left only the magenta color, cyan and yellow tanks are empty.
have 2 options:
1. buy a new color cartridge
2. refill the color cartridge.
Sep 23, 2008 | HP Office Equipment & Supplies
Color Quality is not so great anymore
Sounds like the machine needs to be cleaned. Probably a heavy use machine that has quite a bit of ink spray build up on the inside. I would imagine your service station has quite a bit of ink build up in it as well possibly causing the cartridges not to be cleaned like they should. A good cleaning cures most of what ails inkjet printers. We would charge $85 in our shop for complete disassembly down to the metal frame and cleaning.
Inkworks
May 05, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP DeskJet 932c InkJet Printer Logo
97 people viewed this question
Seeker5211
Seeker5211
