Question about HP Pavilion dv6000z Notebook
HP Pavillion 9720 with blank screen
My wife has the same HP issue with the screen, and I have gotten it back up. As long as I only put it in sleep mode, it is fine. Shutdown, and cold boot, and nothing. The computer is 5 months out of warranty, and HP says the extended warranty service doesn't cover this product. Has anyone gotten HP to cough up a fix on this series?  If not, has anyone started a class action on this? HP seems to write a lot of check to attorneys because they don't take care of issues like this. Thanks.
  • gikanne May 11, 2010
    How long is the system startup time for a cold boot?
    Maybe the BIOS battery has reahed the end.
My hp pavillion g7 will not bootup i turn it on and the screen comes on and thats it
Question: What do you see on the screen? A black screen that is blank? A lit up screen that is blank? What Operating system do you use? Did you make any changes or replace anything on the Pavillion G7?
Feb 20, 2013 | HP Computers & Internet
Have a hp desktop pavillion computer in sleep mode what should i do.
You should just be able to move oyur mouse and it will either come back to where you were or it will come up to the logon screen. Just log back on.
Apr 30, 2011 | HP Computers & Internet
HP pavillion entertainment PC has blank screen. I
Hi there from reading your whats you wrote this tell's me that your computer screen has gone bad. Because you are using a laptop you cannot change the graphic card,for you to solve this problem you need to change the screen.
May 19, 2010 | HP Pavilion dv6000z Notebook
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
My monitor will not wake up
I wm having this same issue. Dis you ever get this resolved? princess242@comcast.net
Oct 17, 2009 | HP W2007 LCD Monitor
I have a HP Pavilion tx 1000. Blank screen, LED lights on.
Hello, seems like your sleep mode doesent work as it should. Try to download all windows updates and look for a fix on microsoft sites.
But the best solution is to inactive the sleep mode setting and use the Hibernate options(if you want a fast start) but I suggest that you turn off windows with shutdown, its the safest and best way to have your computer to work properly.
To inactivate sleep mode.
windows xp
go control panel and power options
Change the system standby to never.
also choose power schemes battery, and change the system standby to never.
also the harddisk to never.
This should solve your problem.
To activate Hibernate you need to click on hibernate tab and bock the square.
hibernate= saves all your work to harddrive to restart your computer where you left off.
sleep mode= saves your work to RAM memory=takes a little bit energy.
Sep 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My HP Pavillion laptop just started this. I will get up from using the laptop, and when I come back the screen is black and won't come back. Moving the mouse won't bring it back. HELP!
Remove screensaver and sleep settings. And wait for the same duration. It is goes blank and locks up, report again. Else it is a problem with the screen saver. Change the screensaver and try again
Jun 25, 2009 | Dell XPS M1530 Laptop
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
HP Pavilion dv9667ea laptop continually freezes
fORMAT YOUR oPERATING SYSTEM BEFORE THAT DO TAKE VACKUP THIS WILL SURELY HELP YOU
Dec 21, 2008 | HP Computers & Internet
Pavillion laptop is not booting.
Try to boot the notebook with F8 Key. (Safe Mode)
Also try to go into the BIOS setting and change there --> Power and Boot Priority.
For BIOS try: ESC, DEL or F2 keys.
Regards
Ellin
Sep 28, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
315 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
