Question about Pitco Frialator 35C Deep Fryer
35C+ Pitco Frialator overheats oil what is likely problem
The above fryer is used seasonally and goes below freezing in the winter. It has taken to overheating the oil. Not sure if it needs equipment cnage or if there is something I cna do to correct the problem without replacing hardware.
    Problem Solver:
  • 7 Answers
Get a tstat gas style and replace it and it is like 172.00 i had the same problem with mine is it a pitco frialator model 35cs
Posted on Feb 25, 2010
I am having the same exact problem and I am assuming either the tstat or high limit units have failed.....
Posted on Jan 02, 2010
How to check gas pressue on pitco frialator
To check manifold pressure, there is a pressure tap on the manifold on which the burners are mounted. Remove the tap, hook up your manometer and turn the fryer on. Be sure you have no gas leaks once you reinstall the plug. The gas pressure should match what is on the data plate.
Apr 12, 2013 | Pitco Frialator 35C Deep Fryer
After we used our fryer last time, there was a soot build up on our exhaust. Just tested it again, and it seems to be running really hot. Do we need a new thermostat? How much is a thermostat?
Soot is formed when fuel combustion is incomplete. Check if the gas pressure is sufficient and of correct type (natural or propane gas). Thermostat can be checked by observing if the burner flame goes off when the oil temperature reached the thermostat setting. Price can be checked at pitco website on www.middleby.com.
Apr 14, 2011 | Pitco Frialator 35C Deep Fryer
I am wondering about fabricating a lid for my Pitco 35C fryer. It is in a mobile unit and I would; one like to keep moisture out of the open fryer when not in use, and two possibly get a seal on it that...
you an fabricate a lid and it must be made of stainless steel. try to fabricate a lid with food grade silicone gasket that will fit on the fry tank opening so that oil will not spill if your truck is in transit.
Mar 11, 2011 | Pitco Frialator 35C Deep Fryer
Hello i have an electric Pitco Frialator and when I turn it on the light comes on but it doesn't click and doesn't heat up. What could be causing this?
If the mechanical thermostat is set at temperature higher than the present oil temperature and does not "click" it is a bad thermostat and needs replacement. Clicking sound on thermostat indicates closing of the mechanical contacts.
Physically examine the thermostat capillary and sensing bulb, any puncture found indicates that it needs replacement.
Oct 11, 2010 | Pitco Frialator 35C Deep Fryer
I have a pitco frialator
That's generally not a problem.
Feb 25, 2010 | Pitco Frialator 35C Deep Fryer
Soot coming from flu
Remove the burners and clean the burner orfices and baffles,also check the vent cap on the pressure regulator that sits on the back of the fryer.Let me know.
May 14, 2009 | Pitco Frialator 35C Deep Fryer
Converting a pitco frialator from natural gas to propane
you need to change the pressure regulator,burner orfices and possibly the gas valve.goto northernparts.com and type in the model of the fryer for propane
Dec 12, 2007 | Pitco Frialator SG14 Deep Fryer
Kitchen Appliances - Others Logo
197 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
