Question about Airforce Welding Tools
I cant cut very well and i dont learn how cut in position correct
    Champion:
  • 225 Answers
Keep the cutting tip just off the surface and try to hold gun straight up and down,if it dont cut through work peice turn the amps up.
Posted on Jun 28, 2009
Why won't the car start with the new Crank shaft position sensor installed? 2005 Buick Lacrosse cxl 3.8l engine.
After replacing crank sensor Perform the crankshaft position system variation learn procedure. Refer to Crankshaft Position System Variation Learn !
No you don't need to replace the balancer !
Install a scan tool.
Monitor the powertrain control module (PCM) for DTCs with a scan tool. If other DTCs are set, except DTC P0315, refer to Diagnostic Trouble Code (DTC) List - Vehicle in Vehicle DTC Information for the applicable DTC.
Select the crankshaft position variation learn procedure with a scan tool.
The scan tool instructs you to perform the following:
4.1. Accelerate to wide open throttle (WOT).
4.2. Release the throttle when fuel cut-off occurs.
4.3. Observe the fuel cut-off specifications for the applicable engine.
4.4. The engine should not accelerate beyond the calibrated RPM value.
4.5. Release the throttle immediately if the value is exceeded.
4.6. Block the drive wheels.
4.7. Set the parking brake.
4.8. DO NOT apply the brake pedal.
4.9. Cycle the ignition from OFF to ON.
4.10. Apply and hold the brake pedal.
4.11. Start and idle the engine.
4.12. Turn the A/C OFF.
4.13. The vehicle must remain in Park or Neutral.
4.14. The scan tool monitors certain component signals to determine if all the conditions are met to continue with the procedure. The scan tool only displays the condition that inhibits the procedure. The scan tool monitors the following components:
• Crankshaft position (CKP) sensors activity--If there is a CKP sensor condition, refer to the applicable DTC.
• Camshaft position (CMP) signal activity--If there is a CMP signal condition, refer to the applicable DTC.
• Engine coolant temperature (ECT)--If the engine coolant temperature is not warm enough, idle the engine until the engine coolant temperature reaches the correct temperature.
Enable the crankshaft position system variation learn procedure with the scan tool and perform the following:
Important: While the learn procedure is in progress, release the throttle immediately when the engine starts to decelerate. The engine control is returned to the operator and the engine responds to throttle position after the learn procedure is complete.
5.1. Accelerate to WOT.
5.2. Release when fuel cut-off occurs.
5.3. Test in progress.
The scan tool displays Learn Status: Learned this ignition. If the scan tool indicates that DTC P0315 ran and passed, the CKP variation learn procedure is complete. If the scan tool indicates DTC P0315 failed or did not run, refer to DTC P0315. If any other DTCs set, refer to Diagnostic Trouble Code (DTC) List - Vehicle in Vehicle DTC Information for the applicable DTC.
Turn OFF the ignition for 30 seconds after the learn procedure is completed successfully.
The CKP system variation learn procedure is also required when the following service procedures have been performed, regardless of whether DTC P0315 is set.
• Engine replacement
Feb 07, 2017 | 2005 Buick LaCrosse
P0315 hammer h3 2006
code p 0315 refers to crankshaft position system---variation not learned ===causes engine mechanical fault ---wiring
check for correct air gap from the sensor to the rotor and check for wiring and connections
Dec 26, 2016 | Cars & Trucks
How do I replace the crankshaft sensor on my 2001 Buick Regal? Both knocksensors?
You best bet is take to a ASE certified repair shop or a GM dealer ! When replacing crank sensor a special procedure has to be done with a scan tool .
The Crankshaft Position System Variation Learn Procedure should be performed if any of the following conditions are true:
DTC P1336 is set
The PCM has been replaced
The engine has been replaced
The crankshaft has been replaced
The crankshaft harmonic balancer has been replaced
The crankshaft position sensor has been replaced
Important: Set the vehicle parking brake and block the drive wheels when performing the crankshaft position system variation learn procedure in order to prevent personal injury. Release the throttle when the engine reaches the SECOND fuel cut off. Leaving the throttle open during the fuel cut-off will allow the engine to decel at an even rate. Once the learn procedure is completed, the PCM will return the engine control to the operator and the engine will respond to the throttle position.
Important: The scan tool crankshaft position system variation learn function will be inhibited if engine coolant temperature is less than 70?°C (158?°F). Allow the engine to warm to at least 70?°C (158?°F) before attempting the crankshaft position system variation learn procedure.
The scan tool crankshaft position system variation learn function will be inhibited if any powertrain DTCs other than DTC P1336 are set before or during the crankshaft position system variation learn procedure. Diagnose and repair any DTCs if set.
The crankshaft position system variation learn function will be inhibited if the PCM detects a malfunction involving the camshaft position signal circuit, the 3X reference circuit, or the 18X reference circuit.
If the scan tool indicates a problem with the cam signal, refer to DTC P0341 .
If the scan tool indicates a problem with the 3X crank signal, refer to DTC P1374 .
If the scan tool indicates a problem with the 18X crank signal, refer to DTC P0336 .
Now why do you want to replace these thing's ? mite be able to save you some time an money. Do you have a check engine light lit ? Codes ? Does it start an run ?
Dec 08, 2015 | Buick Cars & Trucks
2005 buick lacrosse crank shaft sensor how to replace
What engine does yours have ? 3.6 or 3.8 L An when finished a
  1. Install a scan tool.
  2. Monitor the powertrain control module (PCM) for DTCs with a scan tool. If other DTCs are set, except DTC P0315, refer to Diagnostic Trouble Code (DTC) List - Vehicle in Vehicle DTC Information for the applicable DTC.
  3. Select the crankshaft position variation learn procedure with a scan tool.
  4. The scan tool instructs you to perform the following:
  5. 4.1.
    4.2.
    4.3.
    4.4.
    4.5.
    4.6.
    4.7.
    4.8.
    4.9.
    4.10.
    4.11.
    4.12.
    Turn the A/C OFF.
    4.13.
    4.14.
  6. Enable the crankshaft position system variation learn procedure with the scan tool and perform the following:
You best bet is take to the dealer ,unless you have a GM Tech2 factory scan tool .
Oct 20, 2015 | Buick Cars & Trucks
On Homelight 3816c what is the position position of chain brake when cutting
Easy enough to test which position is correct. With the saw not running of course, Try each position the one where the chain moves freely is the correct position. Most likely on this saw it will away from the bar (rearward).
Nov 16, 2014 | Garden
Can i use my chainsaw without the band break?
That's totally unsafe! Why do you need to take it off? There should be no position you cannot cut in without the hand brake lever being there, otherwise you shouldn't be cutting in that position, and if you do, I hope you have an accident to learn a lesson. Look impressive to those around you, and be safe and use the equipment correctly. Unless you want to lose fingers and rip your shoulder off with your chainsaw because you removed the safety feature. It takes like a SPLIT-SECOND at 15,000 RPMs to fly up and hit you in the face, much faster than you can react. Don't be a coolguy, just use the saw they way it was designed.
Dec 11, 2011 | Stihl Garden
I installed the car starter and when i try to start it with the remote the car starts and shuts off quickly. which tells me the started is installed correctly now its just the modual bypass... which its...
It is very important to know what kind of car you have. First sounds like you have passlock issues thats what the pljx is for. You have to have to know what car so you can program it for that car and to make sure you are using the right interface module. If you do have the correct parts then remove the module and make sure all connections are right and no wires are cut. You should be able to start the car at this point. If it does start then you must have not programmed the pljx correct.
Jan 29, 2011 | Directed PLJX GM Self Learning Passlock...
I took the blade off of my riding mower and didn't note the original position of the blades. How do I find the correct position for the replacement blades?
Dont know exactly what you mean, but turn blades with cutting angle up. Make sure if a star like center on blade is lined up and goes over the star like on shaft and tightned bolts. If it has a tray like blade holder, just put up against it and tightned bolt. The way to remember is to put the cutting edge angled side up.
Jun 26, 2010 | Garden
Speed ometer and tack omiter dont work all outher gadges work
If was only techomeer would have suggested Alternator. as an option get that checked, can usually get it done free especially if you are a member of a motoring organisation.
Speedo is usually operated via a connection to your wheels so that connection may be damaged if you have 'bottomed out; your car anywhere.
Sorry cant be more helpful
Mar 05, 2010 | 2003 Ford Focus
How do i change the crank positioning sensor on a 8.1 liter chevy silvarado?
Crankshaft Position Sensor: Service and Repair
Crankshaft Position (CKP) Sensor Replacement
REMOVAL PROCEDURE
IMPORTANT: Care must be taken when removing the crankshaft position (CKP) sensor. Use penetrating oil and allow to soak around the CKP
sensor before removing the sensor. Twist the sensor to break the O-ring seals loose. When removing the sensor, pull the sensor straight out of the
engine block at the same angle the sensor was installed. Failure to be careful may result in sensor damage.
1. Raise the vehicle. Refer to Lifting and Jacking the Vehicle.
2. Disconnect the crankshaft position (CKP) sensor harness connector at the CKP sensor.
3. Remove the fuel line bracket and retaining bolt.
4. Use penetrating oil and allow to soak around the CKP sensor before removing the sensor.
5. Remove the CKP sensor retaining bolt.
6. Prior to removal of the CKP sensor, rotate the sensor back and forth.
7. Remove the CKP sensor at the same angle at which the CKP sensor was installed.
INSTALLATION PROCEDURE
IMPORTANT: Inspect the CKP sensor O-ring for wear or damage. If a problem is found, replace the O-ring. Lubricate the new O-ring with engine
oil before installing.
1. Install the CKP sensor at the same angle at which the CKP sensor was removed.
NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the CKP sensor retaining bolt.
Tighten
Tighten the bolt to 12 N.m (106 lb in).
3. Connect the CKP sensor harness connector.
4. Install the fuel line bracket and retaining bolt.
5. Lower the vehicle.
6. Perform the CKP System Variation Learn Procedure. See: Testing and Inspection/Programming and Relearning
IMPORTANT: For additional diagnostic information, refer to DTC P1336.
2. With a scan tool, monitor the powertrain control module for DTCs. If other DTCs are set, except DTC P1336, refer to Diagnostic Trouble Code
(DTC) List for the applicable DTC that set.
3. Close the vehicle's hood.
4. With a scan tool, select the crankshaft position variation learn procedure.
5. Observe the fuel cut-off for the engine that you are performing the learn procedure on.
6. The scan tool instructs you to perform the following:
^ Apply the vehicles parking brake.
^ Block the drive wheels.
^ Cycle the ignition from OFF to ON.
^ Apply and hold the brake pedal.
^ Start and idle the engine.
^ Turn OFF the A/C.
^ Place the vehicle's transmission in Park (A/T) or Neutral (M/T).
^ The scan tool monitors certain component signals to determine if all the conditions are met to continue with the procedure. The scan tool only
- Crankshaft position (CKP) sensors activity - If there is a CKP sensor condition, refer to DTC P0335 or DTC P0336.
- Camshaft position (CMP) sensor activity- If there is a CMP sensor condition, refer to DTC P0341, DTC P0342 or DTC P0343.
- Engine coolant temperature (ECT) - If the engine coolant temperature is not warm enough, idle the engine until the engine coolant
7. With the scan tool, enable the crankshaft position system variation learn procedure.
IMPORTANT: While the learn procedure is in progress, release the throttle immediately when the engine starts to decelerate. The engine control is
8. Slowly increase the engine speed to the RPM that you observed.
9. Immediately release the throttle when fuel cut-off is reached.
10. The scan tool displays Learn Status: Learned this ignition. If the scan tool does NOT display this message and no additional DTCs set, refer to
Symptoms - Engine Mechanical. If a DTC set, refer to Diagnostic Trouble Code (DTC) List for the applicable DTC that set.
11. Turn OFF the ignition for 30 seconds after the learn procedure is completed successfully.
Sep 11, 2009 | 2001 Chevrolet Silverado 2500HD
Welding Tools Logo
80 people viewed this question
Top Airforce Welding Tools Experts
Bill Boyd
Are you an Airforce Welding Tool Expert? Answer questions, earn points and help others
