Question about Konica Minolta magicolor 2400 Laser Printer
Paper feed issue
I have a Konica Minolta Magicolor 2400w printer. My problem is that the paper feed seems to me out of time causing a 1" unprinted area at the top of each page. I have cheched the feed roller and they are very clean. The machine is on the same computer and worked fine for over a year. It is only about 2 years old and we simply stopped using it because of this problem
  • 210 Answers
You didn't setup the paper size correct, check again in the driver and application to have the same dimension with the actual paper in printer.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
Magicolor 2400w prints page and then says jammed
It`s possible you`re using too heavy paper, same problem´s with thin sheet´s?
Oct 03, 2009 | Minolta magicolor 2400W Laser Printer
Konica Minolta magicolor 2400w will not print
will print??? or the paper not coming out of the draw does it work using the bypass tray???
Jun 03, 2017 | Konica Minolta magicolor 2400 Laser...
Paper got stuck in Konica Milolta magicolor 2400w
I had the same problem and this worked, although it is not the answer to your question:
Take a standard manila file folder and cut it to the basic shape of a standard piece of paper. When you lift the top cover on the under side you will see a diagram on how to pull the paper out in the case of a paper jam. Feed you file folder up from the bottom and you will ~ with a little work, more than likely be able to clear the jam.
Feb 20, 2009 | Konica Minolta magicolor 2400 Laser...
Magicolor 2400w won't feed paper
CLICK HERE for the manual
See page 55 for cleaning the media roller.
Jan 26, 2009 | Minolta magicolor 2400W Laser Printer
Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Jan 20, 2009 | Konica Minolta magicolor 2400 Laser...
Paper keeps jaming!
Print a test page, then when it jams, notice if the paper made it's way in to fuser (toward the back of the unit. If it got that far, your fuser may be bad.
Let me know.
Nov 22, 2008 | Minolta magicolor 2400W Laser Printer
Problem woth mejenta color
patches or white spots? if white spots the cause of that is the paper moisture. dry the paper and then use it or try to open another pack of paper. the problem is on the paper.
i hope this will help
Jun 21, 2008 | Konica Minolta magicolor 2400 Laser...
Regular toner drag marks on printout
MACHINE DRUM UNIT, IMAGE BELT, AND TONER UNIT NEED TO BE REMOVED AND CHECKED AND CLEANED IF THEY LOOK GOOD THERE MIGHT BE A PIECE OF PAPER BLOCKING THE LASER SITE AREA INSIDE THE MACHINE IF ALL IS GOOD, CHECK THE FUSER FOR WOREN HOT ROLLER ,DIRT OR PAPER WILL BLOCK THE IMAGE TH THE PAPER
Dec 30, 2007 | Konica Minolta magicolor 2400 Laser...
Magicolor no longer grabs thicker papers
I think you need to clean take up roller first, and then set the settings in printer propertis in thick paper.
shold work.
cleaning:
open cover, remove imagine unit, then you can see the take up roller. clean it.
Dec 25, 2007 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2400 Laser Printer Logo
415 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
