Question about Kenmore Oasis HE 27082 Top Load Washer
Same here code f1 when taking in water.2 year old peice of junk
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 11, 2010
My stove keeps beeping and showing F1-8 on the display and telling me to call a tech. What is the problem. This slide in stove is abou 6 years old.
The F1-8 error code means that a button on the touchpad is stuck in and the touchpad needs to be replaced. The computer runs a self check on the oven several times per hour and it thinks a button on the touchpad has malfunctioned. Depending on your exact model the touchpad is a seperate peice or it has been intergrated into the control panel, so if it's seperate only it needs to be replace,if it's intergrated the whole control board needs to be replaced.
Hope this helps ya
Gene
Aug 01, 2011 | Jenn-Air Ovens
My kenmore keeps getting f1 code had it fixed and it cost almost 400 dollars and it is doing it again washer was just over a year old when this happened,gave 1200 for washer should last 10 years with out...
This problem has been found to be inherent with this model including its Whirlpool (Cabrio) and Maytag (Bravos) counterparts. It is due to the design of the water level control system, the pressure transducer, which has been integrated with the machine/motor control assembly. It has been found that issues with the pressure transducer including the pressure hose results in the flashing of the fault code F1. Air leaks and moisture in the pressure hose and lint or flashing in the air dome can result in signal error being sent to the machine/motor control assembly and hence the fault code F1 which is according to the service manual, a machine/motor control fault. You may observe that this fault code appears whenever water runs into the machine.
Whirlpool, the manufacturer of these models, has issued a bulletin regarding this issue and suggested the necessary actions in identifying the real cause of this problem and how to address it. Click on the link below for the troubleshooting and repair details.
Troubleshooting Fault Code F1 on Whirlpool Cabrio, Kenmore Elite Oasis, and Maytag Bravos Top Load Washers
Jun 17, 2011 | Kenmore Oasis HE 27082 Top Load Washer
F1E1 error happened repeatedly, jenn air says cut
F1 - E1
EEPROM checksum error
1.
Disconnect power for at least 30 seconds.
2. Re-apply power and observe for
at least one minute.
3. If code re-appears, replace control board (also
called ERC or clock).
Note: Applies to all F1-E...
codes except F1-E3.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Jenn
Air Range / Stove / Oven Fault Codes#ixzz19GMNtS3r
Dec 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
52 Ford F1...steering sucks...need advice on wheels/tires
Outside of trying a junk yard, the only other place that I know of for trucks that old is----- www.lmctrucks.com, and get a free catalog for that year, can also order on line.
Aug 28, 2009 | 2007 Ford F
Water is in the bottom of the washer after a day
are the inlet valves leaking? to test this shut off the water supply, if the water stops then replace the washers water intlet valves..
Aug 25, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
We are getting the F1 error code also. Is it the circuit board??
I have the same overpriced piece of junk and have the f-1 code also . It means you have a primary control failure . Also known as the computer brain module . It cost anywhere from 165.00 -400.00 depending on where you buy it . It will only gets better ,sometimes I get an f-51 code which is a motor rotor sensor failure but could be a false code because somehow this thing will **** clothing under the drum and cause drain problems as well as floods . I got the service manual offline for the repairs , but you may also complain to whirlpool because they are aware of the problem and they may send a repairmen even if its out of warranty . Best bet don`t buy anymore whirlpool junk
Mar 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error on Whirlpool cabrio
it means that the control board is not sensing the water pressure (this tells the machine how much water to put in the washer) in my experience you have to replace the control board which will cost over 200 plus labor which will be over a 100
Dec 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
F1-2 Runaway Cook Lower Oven Check the sensor 1050-1100
ohms, wiring, control
F1-8 Keypad Shorted Replace Control
Here is the link for you to print off the service manual on your range
http://www.servicematters.com/maytag_library/docs/16010107.pdf
PLZ Rate my service
Feb 17, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kenmore Oasis HE 27082 Top Load Washer Logo
75 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
