Question about Durabrand DWT1304 13" TV
A/v input do you have to have a remote control to use the front a/v inputs on the 1304? went to menu functions, game on & off did not effect it any. how do I get it to recognize those inputs?
  • JayT Nov 22, 2007
    I'm trying to be able to play games and I also got to the game on/off and it does nothing. If I can't play games on it I'm going to have to throw it away.
  • don1974 Jan 04, 2008
    I have the same problem and I used a universal remote everything works fine but can't access the game channel and I guess i'm screwed as well........
Hey all I just solved my problem dropped in at a local pawn shop saw 2 tv's just like mine and I asked about a remote he did not have the original for either but he sells uiniversal remotes just for that situation so any universal that has the input button will work takes you to the game channel he showed me 2 both worked but he wanted $10 a piece so I went to the local Dollar Store bought one for $5 that has the input and done the code search and it WORKS LIKE A CHARM hope this info helps someone
Posted on Jan 06, 2008
Toshiba model 36A43 a Universal remote, a HD Digital Antenna the TV's settings menu no antenna as a auto ch. program search. Has TV/CABLE, I tryed cable didn't set.
I've checked the specs: of your TV. Its original remote control number is "Toshiba CT-90157". This remote control have a slide switch by the left side of it, [a selector switch]; that selects inputs TV, CBL/Sat, VCR, and DVD. You have to select the slide up position to select the TV, to select the TV function by its buttons. Just have to slide one step down to select the input to CBL/SAT; to select the CBL/SAT function by its buttons.
But, without a remote control, you can seect the TV/Video function by its front panel controls. There is press button switch, just right side of its Menu button. For each press of it, the set's input selection will change from TV to Video and vice versa.
Just press this button to select the TV as the input. Then only, the antenna socket at its back will turn effective. If you can't select input by this way, the input selector switch; specified above, has the fault, or the input selector IC inside the circuit board is faulty. Just try this after a Hard Reset to this set, and then check. If it do not help you, contact any service technician, or the authorized service center for Toshiba.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 22, 2016 | Toshiba Televison & Video
Sanyo AVM-3259S TV is stuck on video2 remote is lost. How do change video input? Right now I can only play video games on it.
As the TV has no menu button on its front panel, you must have its remote control to select inputs.
Jul 22, 2013 | Sanyo AVM-3259S TV
The remote and control panel are locked on my 52" LED LCD tv.
To unlock the remote control function do the following.
On the front pane touch control pad
1 Press MENU to display the MENU screen, and then
press VOL[--/+] to select "System Options".
2 Press CH [UP/DOWN] to select "Operation Lock Out", and
then press INPUT.
3 Press CH UP/DOWN] to select "Off", and then press INPUT
4 Press MENU to exit.
• To unlock the buttons on the TV, press MENU on the
remote control, and then select "Off" in "Operation Lock
Feb 16, 2011 | Sharp LC52LE810UN 52 in LCD TV
Trying to connect a Sega Genesis. I know it's connected properly to the place where the cable wire goes and then that is connected to the connector. What channel do I go to to play the games?
The input from the Sega wont be on any channel number - you need to select the correct input for the Sega using the "INPUT SELECT" button on the Symphonic remote control supplied with the TV. Switch on the TV the Sega, then press this button repeatedly until you can see the picture from the Sega.
- If you are using the sockets on the BACK of the TV, the correct input is "VIDEO 1"
- If you are using the sockets on the FRONT of the TV, the correct input is "VIDEO 2". You can also switch to the "VIDEO 2" input by pressing the "GAME" button on the Symphonic remote - if you still have it.
If you don't have the Symphonic remote, look for a button marked "INPUT" or "SOURCE" if you are using a universal remote.
If you don't have any remote for the TV, you will only be able to use the sockets on the front of the TV. You will then need to switch to "GAME MODE" by using the buttons on the front of the TV:
1. Switch ON the TV and the Sega;
2. Press the MENU button;
3. Press the VOLUME UP button to open the PICTURE MENU;
4. Highlight GAME MODE using the CHANNEL UP/DOWN buttons;
5. Set GAME MODE to "ON" using the VOLUME UP/DOWN buttons;
6. Press MENU again to close the menu
You should now be able to see the picture from the Sega. If not, check you have correctly connected the Sega to the TV. When you have finished using the Sega you will need to use the method above to switch game mode off again.
Hopefully, I've covered every possible angle. If you have a different Symphonic TV model from the one listed above (ST420FF), the method should be similar, but if you have any difficulty, please post back for further assistance.
Jan 16, 2011 | Symphonic ST420FF 20" TV
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
How can I switch between TV and Video without a remote control
Nov 14, 2008 | Durabrand BH1304D 13" TV
Im having trouble connect say my xbox 360, when i click the input button on the remote it only comes up with the following selections: HDMI, TV. no av1,2,3,4 or anything like that help
just went into menu-settings-input selections i think-and all but HDMI and TV had skip on them, i just put av4(front inputs on tv) on the game option
Apr 27, 2008 | Panasonic Televison & Video
Sylvania tv input channel with dishnetwork remote
The remote control has a "Game" button, which is how you select the external input. Since you don't have a remote you can select game mode via the front panel Menu button:
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the VOL(ume) ▲ button so that "PICTURE" is selected.
3) Select the feature you wish to adjust with the CH(annel) ▲ or ▼ button and adjust it with the VOL(ume) ▲ or ▼ button.
GAME MODE: Set to the most suitable position for TV
GAME. [+] : ON [ - ] : OFF
This will place your TV into Game mode and use the front panel video/audio jacks.
Here is a link to download the user guide:
Just enter your model number.
Please let me know if you have any questions.
Good Luck!
Mar 21, 2008 | Sylvania 6427TE 27" TV
Game mode
yes u can go to the menus and go to input then game mode
Dec 29, 2007 | Sylvania 6419TA 19" TV
Connecting VCR/DVD
Does your TV have more than one A-V input ? If so perhaps you're plugged into the wrong input. Make sure you're coming out an output on your VCR/DVD player and going into an input A-V plug on your TV. Stargazer I've messed up like this a few times!
Aug 16, 2007 | Durabrand DWT1304 13" TV
Durabrand DWT1304 13" TV Logo
81 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
