Question about Sony VAIO RB30C (VGCRB30) PC Desktop
I need to change the processor fan in my mothers sony Vaio desktop, but I can't figure out how to access it.
  • 87 Answers
Pop the side of the case off, it either uses screws or has plastic retention system. Then you will see a main fan over the CPU heatsink. Unscrew or unclip the fan. Install the new fan. If the fan is literally attached to the heatsink and cannot be removed then you will have to buy a whole new heatsink from www.newegg.com 10-30 dollars (comes with a new fan as well). If you remove the whole heatsink make sure you have thermal paste to reapply to the processor and heatsink. If you email me a picture of the inside of the case i can help you. letzfly777@gmail.com Hope that helps!
Posted on Jun 04, 2009
Is it possible to upgrade the processor for the sony vaio pcg 81114l
most likely this cannot be done, the sockets for the processors have changed twice since then. I don't think you would see a great prefprmace change if you could. You might thim=nk about upgrading to a more powerful core I7 from that generation, but you would need to find out which mother board you have and which processors it supports. Unless you are skilled in laptop repair, I would pass on the upgrade.
Nov 13, 2014 | Sony VAIO Computers & Internet
Please can you tell me the location of the cmos battery on pcv-af1m we have the back off and have been looking for for 8hours
Generally all Cmos batter available in front panel place. If you are used PC then open cabinet and see mother board front panel silver color small batter available.
If you are used Laptop then same place available other wise RAM slot nearest.
Thanks..
Oct 14, 2013 | Sony VAIO PCV-W20 PC Desktop
Sony VAIO VGC-RA810G Desktop overheats and freezes.
Following are the reasons for overheating, just take care of these things::
- Clean the Processor fan, Heat Sink and other peripherals
- Use High Speed fans
- Use CPU Heat Sink Paste in the processor
- Stop Overclocking your CPU
- Make sure your Heat Sink is placed properly above the processor
- Make sure your dint restrict the speed of CPU fan.
- Use Additional Cooling Units
- Shut down your computer at least two hour a day
Finally i will suggest you to get system utility program like PC Fresher. because it is a very useful tool that cleans your computer of temp files, history and cookies. Its also used to fix any registry errors that cause of overheating
Sep 16, 2013 | Sony VAIO PC Desktop
I have Sony VGC-RB30 and after power failure it is don't start at all, I can heat clicking and green button at back is flicking, what should I do?
first you have to remove the 24 pin conncter to your motherboard from the smps and short the green and black pin and see wether the smps is working if not working change them if working remove the the four pin conector to the motherboard from the smps and switch on the computer if the processor fan is working connect back the 4 pin connector to your motherboard and switch on the computer if not working the power section in the mother board has failure you can get assistance from a chiplevel service personal
Mar 27, 2011 | Sony VAIO® VGC-RC310G PC Desktop
VAIO® VGC-RC202 PC Desktop: I need one D945PPR D945GPR mother. Can you help me...
hi dude, you could use almost any motherboard compatible, i think you should seek on intel motherboards, cause they have the 9pin front panel you will need, check the size and if is it compatible with your processor and memory, you could write me to sdfuentes82@hotmail.com
May 16, 2010 | Sony VAIO® VGC-RC202 PC Desktop
I have a vgc rc110g model, system is getting hot, shuts down with message saying mother board is out of range, said temp is running around 69c, back fan is running
I would open the case and have a look at the fans, likely there is a fan failure on the motherboard, my bet would be on the processor assembly. Replace the fan that is not spinning, or possibly just hit is with a blast of canned air to clear it, and the situation should resolve.
Jan 10, 2010 | Sony VAIO VGC-RC110G (VGCR110G) PC Desktop
Cant get cpu to see i have a 2.66 in there
More info about system and processor needed to fix. What's the processor's l2 cache? MOBO? BIOS version? The more info, the better the fix.
May 04, 2009 | Sony VAIO Digital Studio PCV-RX755...
Noisy fan when downloading larger files
Well this really isn't much of a problem, as the fan turning on shows that it is doing its job. It turns on due to processor having to run faster, naturally raising its temperature, so the fan keeps the processors temperature within operable limits.
Apr 26, 2009 | Sony VAIO PCV-W20 PC Desktop
Upgrade Mother board and cpu
you can upgrade the CPU without changing the motherboard if the CPU is compatible with the motherboard, you have to buy an Intel processor since the motherboard is Intel. Log on to http://www.intel.com/
to learn more.
Feb 11, 2009 | Sony VAIO® VGC-RC202 PC Desktop
Sony VAIO RB30C (VGCRB30) PC Desktop Logo
187 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
