Question about Drills
How do i open chuckless drill to get bit out - Drills
  • 20 Answers
Firmly grab the chuck, put drill in reverse, squeeze trigger
Posted on Jun 05, 2009
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
How do you secure the drill bit
Chuckless or with a key. can be bought at any hardware store or walmart. if it looks like the item description picture it is a Key
Mar 10, 2015 | Drills
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
Drill bit does not stay gripped, chuckless drill
On this particular tool, you can't really tighten the bit in the anvil like a bit in a drill chuck. The bit is free floating but held in place by a small steel ball. The steel ball is held in place by the sleeve that slides up and down to release the ball so the bits can be changed. The sleeve is held down by a spring. Bits falling out can be caused by: Using bits without the groove in the bottom of them for the ball to catch in, dirt in the bottom of the anvil so the bit can't seat properly, the ball is missing or stuck, the spring is broke or binding, or the sleeve is bent or too dirty to slide up and down freely. Use compressed air to clean the anvil well and WD40 to clean and lube it further. If bits still fall out you'll have to take it apart and see if the ball, spring or sleeve need to be replaced.
Jan 13, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Can't locate manuel for dw222 chuckless drill and don't have a clue on how to change drill bit or whatever, help, it was my husbands and really need to use it
Keyless Chucks
Open chuck jaws by turning plastic collar with fingers and insert shank of bit about 3/4" into
chuck. Tighten plastic collar CLOCKWISE while depressing spindle lock button (F) on the right
side of the tool housing (Fig. 4). To release bit, turn plastic collar COUNTERCLOCKWISE while
depressing the spindle lock button (Fig. 4).
NOTE: DO NOT DEPRESS LOCK BUTTON WHILE OPERATING DRILL or while the chuck is
moving.
Link to manual:- http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW222&selectedType=2752#
Jun 13, 2011 | Garden
Black and Decker corded drill won't tighten around a bit.
the chuck sounds like it is bad or maybe stuck from rust, what you can try and do is spray some WD-40 on the jaws and then try and holding the collar with a glove and run the drill SLOWLY in forward/reverse and see if it loosens up if not you will need a new one.
Jan 14, 2010 | Black & Decker Drills
Black and Decker KD950K drill - how to insert drill bit
most keyless chucks have a button on top that you push in near the chuck it locks so you can tighten or undo
May 27, 2009 | Drills
Chuckless drill stuck tight with drill bit in
if you trap the chuck in a bench vice or alike and then use the drill in reverse in short bursts until it loosens a good spray with wd40 will also aid the situation
Mar 09, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita chuckless drill stuck full open
If you haven't fixed it yet here is the way that I have used to solve this problem. Spray some WD-40 on the inside of the chuck. Place a shop rag around the chuck and CAREFULLY grip with a pair of channel lock pliers set the drill rotation so that it will extend the jaws and SLOWLY depress the trigger. It should move. Let me know if I can help more. When trying this DO NOT SQUEEZE TRIGGER to full RPM.
Sep 11, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Drills Logo
871 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
