Question about Apple Epson Stylus Color 777i InkJet Printer
Still flashes red after changing ink, cartridges stuck to right.
Epson Stylus 7771. I thought I was out of ink when the printer flashed red. When I attemped to change them, the cartridges rolled to the right and will not cycle back to the middle for removal. I was able to pull them back to the center to change the ink but after doing that I got the same red light flashing and the cartridges rolled back to the right side and will not move from there. So nothing will print. I turned it off and on, moved them once again by hand and still get the same result. I just printed on it a couple of hours agao. Any suggestions?
3 Suggested Answers
  • 700 Answers
SOURCE: epson c48 printer
Reset your counter back to zero. But for some you must also check the waste bin status. Need disassembling this is to ensure ink will not overflow from your printer.
Reseting is only software base. Try this link
http://www.fixya.com/support/t1837800-step_step_use_resetter_software
Post again if you cannot still got it.
Posted on May 31, 2009
nonontech
  • 4737 Answers
SOURCE: THE PRINTER DOES NOT PRINT.
If you can't move the carriage to the center manually, I would suggest you to dismantle the machine and check for broken or obstruction. But first of all, try moving it manually, pull it while you shake it gently. If it could be moved to the center somehow, then Turn back on the machine and check again. Try changing the cartridges or clean the contacts. If the problem persists, I will also recommend you to go for a new machine (if you wish to do) and the model you've mentioned "Epson Stylus NX305 All-in-One Printer" is 100% compatible with your Mac (It supports PowerPc OSx 10.3.9 to 105.x) [Click here for more info].
*Sometimes repairing the machine or replacing cartridges would cost more than the Printer's price which isn't recommended.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Nov 24, 2010
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
Epson r220, power light flashing green, ink light red
Include the printer. Press and hold the buttons STOP, MANITENANCE ("drop") and POWER whereupon switch off feeding.
http://files.mail.ru/N287AI
Sep 24, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus photo R230 Desktop : Printer icon flashing with exclaimation mark `No Ink` changed Black Ink cartridge in printer , Red & Green lights on not flashing Please help.. how do you know which...
go to the printer setting under control panel, right click on the icon then properties..you can check the ink level there...normally if your printer blinks and ask for a new cartridge..better follow what the printer says... : >
Aug 31, 2009 | Epson Stylus Photo R300 InkJet Printer
Hi, epson c66 has 2 red lights on. no paper stuck and cant move the cartridges to change. any idea
hi dude
your printer's ink waste pads are full and the counter needs resetting Try this site and software
It allows resetting of the counters, and gives much more control over cleans etc. (Also will allow cleaning when the red Ink light is flashing)
Aug 10, 2009 | Epson Stylus C66 Inkjet Printer
Green and red light flashing
SSC Service Utility allows you to do many things to your Epson printer, Work directly with CSIC in Epson Stylus printers cartridges, Freeze internal ink counters, Reset internal ink counters even with empty cartridges, Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode, Hot swapping of cartridges supported, Resetting of protection counter (even then it is already full), More then 60 different Epson printers supported This allows many people with high printing demands to save money (program works with both black and color cartridges).
May 12, 2009 | Epson Stylus C43SX InkJet Printer
Epson C46, changed coloured ink, won't print flashing red light
If the red light is flashing by itself, it means the printer thinks a cartridge is low on ink. Have a look at what the Status Monitor thinks (right click the printer Icon in the bottom Right-Hand corner and select Ink Monitor). This will show which cartridge it is. If it's the new colour cartridge, it means the cartridge is faulty (then replace it), or it is a refilled cartridge that hasn't had it's chip reset to "full". For this you will need a chip resetter, available on E-Bay very cheaply. If it's the black cartridge then replace it.
If both green and red lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C4x), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
Mar 11, 2009 | Epson Stylus C46 InkJet Printer
Cartridge holder won't move when i press button to change ink
Hi, it's not ready for a replacement cartridge yet, the printer is only LOW on ink not OUT of ink. continue to use the printer until the flashing red light remains on solidly, then the head will move to the replace cartridge poswition when you press the button.
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus CX 4800
actually, all you did was correct.
if it´s not the unit - hopefully the cartridges
call EPSON - prepare the date of purchase / place of purchase of the inks
Dec 28, 2007 | Epson Stylus Pro 4800 InkJet Printer
Apple Epson Stylus Color 777i InkJet Printer Logo
75 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Don  Farrell
Don Farrell
Abdul Mannan
Abdul Mannan
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
