Question about Electrolux Dishwashers
Dishwasher takes in water and then pumps it out to drain, showing that the cycle is finished, the re-circ pump does not come on at all, any ideas with this problem. The Model is a Tricity Bendix TDF200
  • 6,784 Answers
This is a control fault. you will need to replace the timer or control board. this will fix your issue.
Posted on Jun 05, 2009
Bosch diswasher model no.She3ar72uc/22! It gives me a code E-24!!! How can I get rid of that code to get my dishwasher to work?
theres either a problem with the drain pump or the re-circ pump is drawing too much current, if the error appears at the start before it fills with water and there is no water left inside the unit it is the re-circ pump, if its not draining water its a blockage or a faulty drain pump
Jan 10, 2017 | Bosch Dishwashers
Tip
L.G E1 Error / Whistling Sound In this Tip I will show you how to fix it. This...
In this Tip I will show you how to fix it. This error is not to be confused with the 1E error, as this means something completely different.
TOOLS REQUIRED:
- Circulation Pump (P/N: 5859DD9001A) * I will use "Circ. Pump" when referring to it. Get it from your nearest appliance spare shop.
- Screw Driver (Star/Phillips)
- Towel
- Pointed Object (Flat Screwdriver is best)
- Patience
SYMPTOM:
E1 is showing on the LED Panel. In most cases this is accompanied with a whirring/whistling sound from the Dishwasher. This solution will also solve motor noises as described above.
REASON:
There is an excessive or low amount of RPM picked up on the Circ. Motor Impellers during wash cycle. The reason for this is a water leakage on the Circ. Motor. The seal basically got worn, and water came through to the motor shaft leading to the bearings, thus the whistling sound (if any):
The only way to repair this error correctly is to replace the Circ. Pump.
CHECKS YOU HAVE TO PERFORM BEFORE DOING ANYTHING:
Firstly check for any leakages on the hoses or plastic covers, especially the hoses & covers directly connected to the Circulation Pump, any leakages will also trigger this error code. Check the below mentioned "Accessing the Circulation pump" instructions, for easy access to the Circulation Motor.
THE REPAIR PROCEDURE
STEP 1 (Accessing the Circulation Motor)
Firstly, remove the Inlet hose from the unit, and position it in an area where you would be able to lay it on its side. Then drain all water from the dishwasher, this can be done by placing the Drainage hose on the floor (either into a low bucket or out the back door).
Then remove the Top Table (The "roof" of the dishwasher), this can be done by removing 2 to 4 screws at the back -this may vary from model to model:
Remove the Right hand Panel, you will need to open the door for the front screws - See attached pictures:
You then need to close the door, and remove the bottom cover panel, there will be 2 more screws here:
You can now remove the Right hand Panel and you should see the following:
Now, put the towel on the Left side of the machine, you are going to tilt the dishwasher to its side, and water will likely leak out on that side.
Lift up the insulation material, and then lean the dishwasher back so that it is laying on the Left Panel:
Again some screws would need to be removed from the Base Cover, see pictures:
STEP 2 (Removing the Circ. Motor)
Now you have to stretch the Base Cover to allow yourself some more space to remove the Circulation Pump. To do this, insert your flat end into the Jimmy Space (Shown on the previous picture), use this in a crowbar like action, to give you some extra space - Beware not to break the plastic!
Remove the Screw mounting the Circulation Pump to the Base Cover:
Disconnect the Power cord to the Circulation Pump:
Then remove the Mounting piece, and twist and pull out the Circulation Pump from its nesting area, be careful not to break fittings or move other components (Especially the Sump) while pulling the Circulation Pump free:
The sump as seen above must not be showing more than 2 mm of silver lining, if it does, it means the sump has shifted too much, and leakages is almost a certainty. YOU DO NOT WANT THIS TO HAPPEN :-)
With the Circ. pump removed, you can now easily insert a new one, and use the reverse of my instructions to finish the job.
Just another quick note:
Sometimes the mounting supplied is different than the one that was in the machine, always fit the new one.
That is it! Re-attach the hoses and water, connect the dishwasher to power. Test it and viola, the E1 error is no more, and any whistling sound that may have been there is now a distant memory.
PLEASE BE AWARE:
Even though this is accomplish-able by yourself, no person would disagree that an experienced and qualified technician will be able to do it more accurately and without further damages to your appliance.
Experience is what you got by not having it when you need it. ~Author Unknown
Thanks for reading my Tip.
on Jul 06, 2011 | Dishwashers
Whirlpool dishwasher, quiet partner 1. Does not drain, does not finish wash cycle.
ensure your dishwasher pump and drain hose are unobstructed. If your machine does not drain it will not refill with fresh rinse water and since it can't do that the cycle will never finish.
Many people don't completely rinse off food stuffs from their dishware, expecting the dishwasher to take care of it. To be honest, a dishwasher is more of a fine cleaning and disinfecting device than a pot scrubber. Because of this, grease, food debris, etc can clog the pump or drain line over time. be sure to use a good de-greasing agent regularly once the flow of water has been cleared (don't wash your dishes with it however)
Mar 20, 2015 | Whirlpool Dishwashers
Hi I have an Bosch SGs43c02gb/35 and it does not drain all of the water out when it has finished the cycle, I have cleaned the filters out which were relatively clean and run it with a dish washer cleaner...
Hello
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Aug 20, 2011 | Bosch 24 in. SGS43C12 Classixx...
Kenmore elite washer does not finish the drain cycle and it shows a LD error and does not finish washing.
LD error is for long drain. The pump filter in the pump assembly is probably clogged. Remove front lower panel, pump assembly is in the front with a cap that unscrews. Once cap is unscrewed you can slide out the filter and clean. Remove as much water as possible from basket before taking off pump cap or else water will come flooding out when filter is removed. Reinstall and run drain spin cycle. Should drain ok.
Feb 02, 2010 | Kenmore Elite HE4 Electric Dryer
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water left standing inside the buttom of dishwasher
It depends on What kind of Dishwasher you have. If the pump is old it may very well be bad or it could be a drain hose routing issue. The drain hoseshould always be looped up in the cabinet under the sink. If the drain hose is laid down low, the water could be backing up from the hose back into the dishwasher.
Feb 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosh dishwasher Class1xx
I think if u take the left side pannel off u will find the meatering tank clogged up which can not fill up the machine at diffrent levels.
Jan 02, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
96 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
