Question about Refrigerators
Refrigerator not defrosting and evaporator motor not running! I have 115v power to fan?
  • stevenm06 Jun 08, 2009
    Nice Try, With the refrigerator and compressor running the evaporator fan is not working! I checked power to the fan and it showed 115 volts and is not defrosting and evaporator is solid with ice! I took the fan motor out and plug it to a outlet which has 120 v and it worked! This is a samsung refrigerator bottom freezer! It has a main control board! Any Ideas?
  • 122 Answers
you have a defrost issue not being able to verify circuits on the mother board i would replace the high limit, what you are calling the termination stat this stat stays closed unless the temp hits 140, thats right 140 degrees f and change the evaperator sensor.
evap sensor can cause missed defrosts or no defrosts
high limit part number wr50x10068
sensor number is wr55x10025
Posted on Jun 09, 2009
    Sergeant:
  • 296 Answers
Hi
chek this sites to ve an indepth knoledge
http://www.appliance411.com/faq/defrostproblem.shtml
1. The evaporator fan should only be on when the compressor is running.
Not when the fridge is in defrost.
2. it would be best to check for 120 volts while the fridge is on and not in defrost.
3. There should be a light amount of frost on the cooling lines.
But if the fan isn't working then there will normally be more frost then you would usually see.
If the fan is getting 120 volts while the fridge is on then you will have to replace the Evaporator Fan Motor
OR
Try removing the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get clogged with frost, it will block the evaporator fan motor from blowing the cold air. The fan blade could also hit the frost and become noisy, or stop altogether.
DEFROST TIMER, THERMOSTAT & HEATER
You can locate the defrost timer, but it can be tricky, since they are often hidden behind the back bottom corners of the fridge. In the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw-like wheel, in the middle of the defrost timer, with a screwdriver until the fridge shuts off. Now the fridge is in defrost mode. If the defrost heater comes on now, replace the defrost timer and defrost thermostat. If the heater does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater. If you have no power to the heater, you can also bypass the defrost thermostat to see if the heater will come on; join the two wires together, to bypass the thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy or ticking, replace it.
chek this link too
http://www.applianceaid.com/frig_notcold.html
Hope u will b helpfull
regards
Posted on Jun 04, 2009
I have a side by side whirlpool fridge and the freezer is fine but the fridge is now freezing everything. It's about 11 years old.
Since you stand to loose all the food I would call a service tech ASAP. But here are the most common reasons for the problem you have.
Cause 1
The Evaporator Coils are Frosted Over The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Cause 3
Damper Control Assembly The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won't let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Nov 19, 2016 | Whirlpool Refrigerators
Evaporator fan in my MSD2351HEQ quit running.
Carl, is the condenser fan motor running also? Looking at the wiring diagram of your refrigerator, you need to check for 120vac at the fan motor. If there is, replace the fan motor. If there is not, replace the Defrost Control.
Apr 10, 2014 | Maytag Refrigerators
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Everything in ref freezing up
1)check the temperature setting.it should be set on normal mode. 2) check if the ventilation in the fridge are blocked .there are two possibilities you will have to check 1)the defrost timer 2)the evaporator coil. How a common frost free defrost cycle works and the main parts. When the refrigerator is running ( cooling mode ) the defrost timer contacts prevents any power from getting to the defrost heater. When the defrost timer turns off the power to the compressor and fan motor(s) the power is then redirected to the defrost system. The defrost timer motor. Defrost timers:
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
the evaporator coils are located at the inner side of the freezer section.if the ice gets collected in the coil and the evaporator fan stops running then the inner system of refrigerator will get over cool and this problem happens.
now to solve the issue .if to check evaporator coil is faulty or not there is a system.just unplug the unit from main power outlet then wait for 24 hours.then replug the power cord in the main power outlet.in 24 hours all the ice collected in between the coil and anywhere will get melted and then check out.if it works properly the problem was ice in coils.but if same problem then defrost timer needs replacement,you can get new timer friom
--- www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Ammana Fridge-Evaporator Fan not working
Replace the defrost bimetal . On older Amanas' , the coil has to be cold , before the evaporator fan starts ( bimetal closes ) . This way , heat from the defrost cycle , will not be blown into the refrig section .
Oct 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Not cooling no p0wer to evaporating fan
Part number R0161089 defrost thermostat $35 ,but if the freezer coil is defrosted there would be no power to the motor because this switch has to be chilled to about 0°F to send the power to the fan motor.
Sep 27, 2009 | Amana SXD524VW Side by Side Refrigerator
My Amana Side-by_Side SXD26VL is not cooling. The
clean cond coil at back of unit.
check amp draw on the compressor wires.
Sep 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
GE Refrigerator forms and Ice dam which stops the evaporator fan from turning.
is it defrosting theres a glass tube which is the defroster bar,there known to have these fail
Jul 07, 2008 | GE GDS20SBS Stainless Steel Bottom Freezer...
Freezer is working/refrigerator works sometimes
No No No. The most likely reason that the evaporator fan is not running is that it probably uses the heater circuit for its neutral feed. I.E. In order for the fan to have 230v/115v it needs a zero voltage brought back through the defrost heater and defrost stat. I know this for a fact because I just did one today and have fallen for this scenario (ie bad fan motor) before. You need to check from ground(earth) to each side of the fan motor (which is easily accessible) and then across the fan motor windings. The chances are that you have zero voltage across the motor. The fan will also not run until the temperature of the evaporator coil has been brought below 0 'C (32'F) and this can take up to 20 mins (again speaking from experience). This is to prevent snow being produced after defrost. I would advise getting the engineer to come back if you have paid him money and do a proper job. Shorts in Amanas can happen but have not come across one yet. Hope this helps.
Aug 26, 2007 | Amana ABB1927DE Bottom Freezer...
Amana Refrigerator SCD22JL
Good trouble shooting TD, the evap fan runs through the defrost T-stat. Change it out and you should be set. Catriver.
Aug 14, 2007 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
