Question about Cobra 148 GTL 120-Channels Base CB Radio
My 360 stays key up all the time on ssb can you help
As above
  • 86 Answers
Try pulling the mic out to see if it stops if it does you have a problem in the mic if not it
is inside the radio.
Good luck
Posted on Sep 16, 2009
My general lee stops working on upper channels
Vco out of range.. Tuned wrong.. Very common.. It probably kept you from burning it up since your swr will get too high even 10ch above 27.405= ch40.. Bells cb or finetune cb can allign it correctly.... Imo stay on cb .. Your antenna is not broadbanded enough and you dont have ssb and its not legal..
Jul 07, 2016 | Radio Communications
Ranger 2995 Dx SSB Works But AM Power Stays Dead Key 120 Watts Variable power does Not Work
its the power transistor/voltage regulator on the rear right hand corner of the chassis facing the radio probably part # 2sc754 have this part replaced and it will resume normal operation
Apr 05, 2013 | Radio Communications
I have a galaxy 88 and when u try to use it on ssb the radio will only do half power even with ssb power all the way up!
there is a ssb regulator bad or the power is turned down
this how to adjust ssb power output SSB ALC:
Mode to USB.
MIKE GAIN to maximum.
Inject two-tone audio signal of 500 Hz and 2400 Hz, 30 mV (-18 dBm) atMIC jack adjust VR12 Key TX; adjust for 25 watts PEP.
Sep 12, 2012 | Galaxy Radios DX- 88HL Base CB Radio
Just want to know if i should use my ll203 amp in am or ssb mode when running with a cobra CB radio?
What radio?? Does it have single side band(SSB)? If not, then don't use SSB.
AM - amplitude modulation
SSB - single side band.
If you have SSB, there would be a switch on it to transmit in SSB. If not, it is AM only.
Second, Has this radio been worked on to be able to run on an amp? If not, you will blow the amp.
A CB radio transmits dead keys with 4 watts of power, and transmits with 4 watts of audio.
a 4 watt dead key is too much for a linear amp. You will smoke the transistors. Also, 4 watts of audio is not enough to drive it properly. You won't get full power.
The dead key needs to be around 2 to 2 -1/2 watts,or what ever makes the linear dead key half its peak wattage., and the modulation (audio) turned up all the way.
It doesn't sound like you know too much about CB radio's. Not a big deal, you can learn. For right now you may want to take it to a cb shop and tell them you want a peak and tune, and set up to run a linear.
You can find CB shops usually at truck stops. Some area's they are other places. Check the internet for local shops.
Oct 31, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Will not stay on 11 meter turn it off comes back on 10&12 meter will not transmit am or ssb recieve ok. rci 2995dx.
Hello janetsue, If this radio has the blue or green screen LCD face then this is a default that is built into the radio. It depends on how the radio was "converted" when it was bought new.
It will not key up on 10 or 12 because of the default. A little more info supplied would be real helpful,,,, Let me know, Mechanic
Nov 01, 2008 | Ranger RCI-2995DX Base Scanner
42PF5321D/37
That is correct about the SSB. Now before we go any futher is this set still under warranty? If so or if it is just a little out like a couple of months contact Philips @1-888-744-5477. PS. on the front of the set where the power button is how mant times do that led blinks.
Aug 20, 2008 | Philips 50PFP5332D 50 in. Plasma...
42PF5321D/37
Measure the connector from the logic board to the power supply the second pin from the left it will say Vs_ On if the set has 3.1 volts the problem is the SSB or the logic board. On the logic board there should be a solid led and a flashing led that shown that data id flowing and the problem is the SSB. The SSB is easy to replace just remember what you tokk loose and from where. You probely will save money that way. If the set is in warranty or just out of warranty contact Philips 1-888-744-5477 and see what they can do first.
Jun 23, 2008 | Philips 50PFP5332D 50 in. Plasma...
Galaxy 2527 all works except no dead key wattage.
if you are talking on SSB then their is never a dead key wattage.
SSB uses all modulation, no dead key.
Apr 25, 2008 | Magnum OmegaForce S45 CB Radio
Cobra 148 gtl stays keyed up on tx on both am and ssb
Your problem is a faulty changeover relay on the circuit board. It is a small black device , and may have the brand name MRATA
etched on it (the switchover contact points are stuck together)
WORTH A TRY GOOD LUCK
flyingfox@prople.net.au
Mar 30, 2008 | Cobra 148 GTL 120-Channels Base CB Radio
Need to be able to re install norton 360 after use of restoration disc
if you brought it online you should have gotten a product key, and serial number. if you google "norton 360 redownload" it should take you a norton page or symantec page. enter "redownload norton 360" in search box and it should go right to it. now just enter product key and serial number and you should be good to go. ihave restored my computer a number of times and this is how i get my norton 360 back without paying again. hope i helped
Oct 24, 2007 | Microsoft Office Outlook 2003 for PC
Cobra 148 GTL 120-Channels Base CB Radio Logo
63 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
