Question about Hitachi hts548080m9at00 80 GB Hard Drive
HELP--- problem with the hd booting and pulling my hair out !!!!!!1
Ok it's like this , i have a ibm think pad laptop with the hts548080m9at00 80 gb hd . i loaned my computer to a friend and they some how messed it iup bad!! when ever you turn on my laptop it looks like it will load but then it like goes into what looks like total lock down!! in the upper left hand corner of my screen there is a picture of a pad lock and it gives you two times only to in-put a password i think! my friend does not know what he did but it will not boot to any thing at all it just goes to a locked state! ok but hear is where it gets weird i put a new drive in a ibm travelstar model djsa-220  15 gb  and  the lap top worked fine booted up into windows like it should until we had a power surge throughthe wall plug and fryed my hd!computer is fine had it looked at so i put other drive back in and and haveing same boot up problem as before can you help!!! please
  • 38 Answers
Sounds like you have a boot up password enabled and the only way to disable something like that is to remove the cmos battery from the computer. You could download the service manual from the ibm support website which would tell you how to remove that. After you remove it, wait 15 seconds and replace it. If you're still in warranty i would call up ibm and ask them if they have a software method or a master code to reset that.
Posted on Oct 25, 2007
What is the problem when uyou switch on the IBM
You probably need to replace the BIOS battery. This battery is small and on the inside of the laptop connected to the motherboard. It stores the BIOS settings, date and time. If this battery becomes worn out then it will cause your issue. First try and press F1. Navigate to the last tab and select to restore defaults, then save and exit. If the computer boots up fine but the next time you use it the same message appears then you need a new BIOS battery. Alternatively your HDD may be damaged if it cannot find a boot device. Check your HDD is recognised on the boot menu by pressing F12, select it and press enter and your OS should boot. Hope this helps,
www.PuterCare.com
Jul 23, 2010 | IBM ThinkPad T20 2647 Notebook
IBM Think Pad TDD
reinstall the OS, but first back up you files. you can remove the HDD located at the bottom of the Laptop. buy a cheap 2.5 inch usb to ide/sata enclosure and place your hdd on it. use a PC to transfer your files. then format the HDD. reinstall the HDD to your laptop and install the OS.
Jul 06, 2009 | IBM ThinkPad T22 2647 Notebook
BIOS self-set Password after upgrade/HD Install
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
try this if you can do  but i am not sure.  i am good on electronic things but its hard to do that. its only way.
May 28, 2009 | IBM ThinkPad T43 Notebook
Ibm think pad r51 nodisplay 4 beeps commaing
This indicates a possible memory problem. Reseat the RAM modules and boot up, if OK then the laptop is OK.
If not then :-
If you have two RAM modules, remove both and insert one and boot up, if it is OK then repeat with the other one - this will determine which memory module is faulty.
Mar 30, 2009 | IBM ThinkPad R51 Notebook
Need to know how to change boot squence in a R40 think pad
I believe you have a Administrator password set there.U need to check with IBM support
Mar 17, 2009 | IBM ThinkPad R40 2897 Notebook
I have a ibm think pad laptop. the text has gone red
You have a TFT failure - to confirm if it is not m/board related plug and external monitor to the external vga port and boot the unit. If the display to the external is ok then your TFT requires replacement.
Mar 08, 2009 | IBM ThinkPad T23 Notebook
Ibm think pad 600e
Do a search for memtest86.iso. Burn this image to a cd and reboot your computer. When your computer reboots it should begin checking your memory for errors. If you still have problems it might be your hard drive.
Feb 13, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Nov 24, 2008 | IBM ThinkPad T21 Notebook
Bios reset password
no worries..when you boot up, press F2..before the IBM logo appears, and then you'll see the bios password option on that screen..change it there, and you may see magique.
Mar 27, 2008 | IBM ThinkPad T43 Notebook
Hitachi hts548080m9at00 80 GB Hard Drive Logo
202 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
