Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Is there a charge for this?
My garage door opener opens by itself. I read your your solution, but I don know what the "learn" button on the receiver is?
    President:
  • 3,197 Answers
On the rear of your motor unit there is a button just to the left of where all those white wires go. That is the smart/learn button. There is no charge here.
Posted on Jun 04, 2009
My remote sends a signal, the opener indicator flashes, but the door does not open?
The learn button is located on the garage door opener unit itself that hangs from the ceiling. If you follow the gray antenna up to the unit you will see a red/orange button on the unit. That is the learn button. When you push that button and amber LED will light up either above or next to the learn button. This indicates that the garage door opener is now ready to learn a new device. Press and hold the button you want programed on the garage door opener remote and release it. The garage door opener will click and the garage door opener light will go off and come back on (if the light bulbs are in working order). The amber LED will go out, repeat if you need to program anything else.
Feb 22, 2015 | Craftsman Garage Door Opener 1/2 HP Chain...
How do I change the frequency of a garage door opener 139.53930ODM?
Hi... You have to "erase all codes" (you can read that section of the manual and teach the opener to use the remote using a new code. You can get the manual at the Craftsman site, page 35. Essentially you do this: access the reset button n the back right of the motor, press and hold the 'learn' for 6 seconds or more,until the learn light goes off. TO reprogram it, press the learn button until the light goes on, then within 30 seconds, press and hold the desired button of the remote. Voila!
Dec 26, 2014 | Chamberlain Liftmaster 355LM 315MHz Garage...
What is the different between 41AB150-2 and 41AC150-2?
This receiver logic board (part number 41AB150-2) is for garage door openers, including Craftsman garage door opener model 13953904D.
This receiver logic board (part number 41AC150-2) is for garage door openers, including Craftsman garage door opener model 13953901DM.
315MHz Security Radio Controls Purple Learn Button Replacement Garage door opener receiver logic board 41AB150 2 for... 25313039-z4aba1t3xnu0kgnrds04j5va-2-0.jpg
Dec 08, 2014 | Cars & Trucks
My Champion garage door opener opens by itself and the light does not come on
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 13953919 door opener. My garage door opens during the day when I am not home. The alarm company calls me to let me know, and the police have been by twice. Nothing is stolen, so I can...
Here are some things to check.
Apr 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
PROGRAM PRIUS GARAGE DOOR HOW DO I PROGRAM THE BUTTONS ON THE PRIUS' REAR VIEW MIRROR TO OPEN THE GARAGE DOOR
There was a minor change for mine to work.. see below..
- you must park your Prius close to the gate opener, leaving it running (obviously not in the way of the gate closing)
- Hold the button the the mirror and then push your garage door remote button and hold until the light on the mirror starts to flasyh fast. THIS programs the button on the mirror, but not the garage opener - yet (this was key for me)
- locate the "learning button" on the opener itself
- press the "learning button" on your gate opener and then get back into the Prius within 30 seconds (more time than it sounds) and press the SAME Homelink button you just programmed above. I don't recall how long I held the pre-programmed button, but the light will flash as I recall.
- Then, when working the garage door, you may need to hold the mirror button for a good second for it to work - but I had tried for months to get mine to work, and finally after reading many posts, the above sequence worked on my 2008 Prius with my Lift Master, Security + rolling codes garage opener.
Just - program the button on the mirror with your remote FIRST.. the garage opener will not work.. then use the Learn button on the garage opener and the SAME BUTTON you just programmed.. and it worked great for me. Not programming the mirror button first will not work. Using only the Learn button will not work. You must program the mirror first with the remote, then use the learn button and the SAME button on the mirror. Hope this helps.
Scott 2008 Prius with Lift Master Security + opener.
Oct 30, 2009 | 2007 Toyota Prius
I have a Lift Master 1160. It opens when my
To erase the memory press and hold the smart/learn button on the back of the motor unit for 10 seconds. This will stop any remote or keypad from opening your door. To program it press and hold the button on your remote and then press and immediately release the smart/learn button. Do this for each remote you have.
Jul 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on its own
u have to erase all memories in the receiver.. push the learn button for like 10 sec.... and memorize again ur transmitter by presing the learn button once and the the transmitter button... try it again..
Mar 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Change the code on a garage door transmitter?
There is a "learn" button on the garage door opener unit itself that you press before entering a code on the outside transmitter. This allows the receiver to learn a new code. The button is on the rear end of the housing near the terminals where the inside operation pushbutton connects.
Here's a link to programming instructions for a compatible unit by another manufacturer:
http://www.usdoorcontrol.com/instructions/liftmaster/keypads-66LM.pdf
Nov 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
46 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
