Question about Hotpoint Aquarius WMA42 Front Load Washer
Door on hotpoint aquarious wont open at end of wash cycle...in spite of door light OFF. Have checked drain off plug..its OK!
  • 30 Answers
Door catch is faulty unplug machine take off lid put hand down to door switch and pull back to open door replace handle kit
Posted on Jun 09, 2009
I have a Hotpoint Aquaris WF000, 1000 spin washing machine and when I put it on the lights flash and nothing else happens. What could be wrong with it please
Hi
It seems to be a fault with this make of washing machine.
I changed the door lock and that seemed to cure it for a while. However it now seems to be doing it again.
What I have discovered is the following:
Turn the washing machine off completely at the wall and pull the plug out - leave it out for about one minute and then plug it back in and switch on. This should cure the problem and it will work again.
You may have to do this every now and again to clear some fault it has in the circuit board so leave some access to your plug socket.
I hope this helps.
Feb 24, 2015 | Hotpoint Aquarius WF000 Front Load Washer
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
Door light no working so machine will not start
check power is getting to machine with suitable electrical screw driver.to do this remove top from machine and check live wire just inside rear of machine. fault could be door lock if you have power in machine
Feb 05, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Clothes still wet after fast spin cycle
Belt loose or motor / motor control board possibly defective
Sep 13, 2017 | Hotpoint Aquarius WF000 Front Load Washer
Cycle finished but door won't unlock, please help
normally, front loading machines have this bypass cables in case this things happens, if there is a small opening at the front to acces the drain filter, open it up then look for a small plastic pc with a ring at the end. this is the pull release cable of the door lock. pull it downwards and the door will be released.
if you do not have the small opening to access the drain filter, you can tilt the machine to its back, ( be carefull, its very heavy) then reach for the plastic ring underneath to pull to release the door lock.
tnx 4 using fixya..
drcool
Aug 30, 2008 | Hotpoint WMA40 Front Load Washer
We have a hotpoint wd420 washing machine and it wont finnish a wash cycle. wont drain the water either, we do get an error code though in that the door locked light flashes as well as the reduce creases...
you have a blocked pipe - where the water is draining out. Either that or your filter is blocked.
best you open the back and take a look at the filter before calling out hotpoint - might save you 100 pound call out charge.
Jul 28, 2008 | Washing Machines
Hotpoint aquarius washing machine
where is the filter for hotpoint aquarius wma54 washing machine
May 31, 2008 | Washing Machines
Hotpoint aquarius washer door wont open
I've got the same problem, the locked symbol is showing
Feb 17, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
435 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
