Hi Friend, As u have mentioned, the CMOS Battery will be Located at the inside of your Laptop,You can remove it by unscrewing all the Screws at the Bottom, u will be able to remove the bottom part of your Laptop and then u can see the CMOS Battery.
The Bios Battery is the Battery Located at the bottom and it will easy removable
The removal and replacement instructions can be found in the dell service documents available at support.dell.com. You can look it up by service tag or model number. But in short, the procedures are. 1. Remove the hard drive, then remove the keyboard. The keyboard is removed by removing the 5 screws on the bottom of the laptop marked with a "K" beside them. Then the keyboard can be removed. be careful not to tear the ribbon cable, and you do not have to remove the ribbon cable. The battery will be in the center of the opening, it will have a white plug that plugs into the keyboard. Contrary to Ayyasam's recomendations above, it is not necessary to remove "all" the screws on the bottom, nor is it necessary to remove the bottom of the laptop. It should be a 5 minute project. Again for any Dell item, the factory repair manuals are available online, and have exact instructions including pictures and diagrams.
Happy Computing
Daver56
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude C610 PC Notebook
I have latitude dell c610, when I power it on it tell me it can see the hard drive and that the cd...
(More)
I have latitude dell c610, when I power it on it tell me it can see the hard drive and that the cd rom is not properly fit it whilst its properly fit in. now when i take out the cd rom it tell me that it cant see the hard drive
When I attempt to boot up my Compaq laptop it says or to resume. But when I hit either of these keys...
(More)
When I attempt to boot up my Compaq laptop it says or to resume. But when I hit either of these keys nothing happens.
