Question about Waring WCT708 4-Slice Toaster
Left side dont work
The left side wont stay down to toast if you hold it down it will heat up,but only if you hold it down
    Scholar:
    New Friend:
  • 67 Answers
The holder is a bimetallic strip that heats up and opens when it reaches a preset temperature based on the darkness setting. It should latch onto the toast loading mechanism when cold and then snap open when it reaches a certain temperature. The darkness setting knob adjusts the point at which it opens. Probably either the release mechanism is broken or bent or the setting knob is broken. You can disassemble it when unplugged by removing the screws on the bottom and prying off the toast loading knobs by placing a ruler wrapped in cloth against the housing and prying the knobs off with a large screwdriver carefully going back and forth from side to side. If the knobs break or won't go back on use a high temperature epoxy to reassemble. You have a good side to compare the bad side to. Look for differences from one side to the other as the toast loader lever goes down and as the darkness knob is rotated. You may just have something blocking the mechanism. After working on it, plug it in outside to a ground-fault protected outlet on a fireproof surface before attempting to use it.
Posted on Nov 30, 2007
SOURCE:
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Hi i have a four slice toaster it is only 13 months old but one side does not work please can you help as i think this should last a lot longer as it was not cheap i dont think it is fit for purpose i
Hi, Try to set the toaster to a darker setting. this will make the toast stay down longer. But keep an eye on it as it can burn. As for the other side not working. Unplug it and look carefully at the heat coils.
If there is a break in the wire you will have to take it to be repaired. Good luck.
Jan 12, 2015 | DeLonghi Toaster Ovens
Toast wont stay down
Don't eat the right side. It must be bad.
Nov 01, 2014 | Applica T4030-b & D T4030 4-slice Toaster...
The left side of the toaster does not stay engaged...if I hold it down it heats up but it doesn't stay down ..it doesn't catch.
There are two printed circuit boards inside front of toaster - One PC board for each side. The circuit board on the side that won't latch down in the "toasting" position , is defective. Now, does anyone have access to a schematic for this toaster?
Jul 02, 2011 | Cuisinart CMT-400 Cast Metal 4-Slice...
Left-hand section only toasts on one side
The heating resistor on the left side has shorted with the case. Since you don't know very much on electrical equipment (to fix it you would have to open it, remove the shorted piece of wire, reattach all and insulate them properly) and the price of a new item is low, just buy a new one and discard this one. You shouldn't use it again, under no circumstances - if you're unlucky it can kill you.
Oct 03, 2009 | Breville Kitchen Appliances - Others
GE 169137 Classic 4-Slice
have you tried to turn up the heat thermostat on the side.
Jul 10, 2008 | GE 169137 Classic 4-Slice Toaster
Tefal toaster wont stay down - Avanti Elite, twin.
Hi, I assume that you had the toast carriage pushed down when you check the solenoid (hold down coil) volts ? .. a bit dangerous to try though
Either way, try resoldering the solenoid connections, they can develop hairline cracks that limit the current.
Feb 11, 2008 | Kitchen Appliances - Others
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
Waring WCT708 4-Slice Toaster Logo
481 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Bruce Eichhorst
Ps Daengr
Ps Daengr
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
