Question about Swimways SUBMERGENCY
How do you turn it off ??
It will just die ever time
86 4.3 4BC 1500 Chevy Die rolling up to light Started up and ch of fuel and it died 3 times now no start smell fuel and quit yellow spark Have replaced cap rotor plugs wires EGR coil ECM Rebuilt carb
It sounds more like a fuel problem to me then a bad coil or spark ign the spark should be blue but its hard to see in daylight
You say you rebuilt the carb are you sure your main mixture jets are at least 2 to 3 turns out off the stops .
Try pouring fuel down the barrel fill the float bowl if it runs then dies its fuel don't let it catch unfire you should have 45 sec. of run time then adjust the the mixture screws 2 turns is base but when its is running good turn them in 1 at a time and give it 30 sec. to adjust until it starts to stumble then back it out a 1/4 two 1/2 turn then repeat on bank 2
Nov 23, 2016 | Chevrolet Cars & Trucks
My 2006 Kia sportage won't start first time every
Check fuel pressure the motor
Mileage no longer has anything to do
with having problems
Vehicles sadly, are not reliable, as they were
from 1950 thru 1980
Sep 02, 2013 | Cars & Trucks
Starts and dies unless I rev it up then it will Idle
The battery might be low but I doubt it is causing the "no idle" problem.
You should have an idle air control valve that the computer uses to adjust idle speed. That valve could be faulty or dirty.
Is the check engine light on when the engine is running ?
Jul 19, 2012 | 2001 Dodge Durango
My 85 thunderbird died on me twice once while i was at a street like the engine started to shake then it died all the lights where on then i put it in park and turned it on with some difficulty but i...
One of several possible issues. Check for any vacuum leaks. If you have an external fuel filter, have you replaced it ? If filter is internal with fuel pump, inside fuel tank, may want to do a fuel pressure test first.
Have you checked for any codes in your engine control module ?
Jul 24, 2017 | 1985 Ford Thunderbird
Car dies going down the highway after about 20 miles then starts back and dies again some times it starts right away sometimes after 5/6 tries always restarts???? no code some times when it starts dieing...
Had this happen with a Honda Accord: carb icing.
You do not have a carb.
Had this happen with a newer Honda, bad ignition switch. It was intermittent. $24 and one hour fixed it.
Good luck
Apr 09, 2010 | 2001 Hyundai Elantra
My 1997 Ford F150 dies whenever i turn on wipers
sounds like a new problem, I would try unpluging the windshield wiper motor under the hood turn on the switch inside the truck and see if it still dies, if it doesn't suspect a short inside the wiper motor itself (replace wiper motor).
Jan 19, 2010 | Ford F-150 Cars & Trucks
Car dies when slowing down or turning.
Have the idle air control valve checked.
Aug 07, 2009 | 2000 Chevrolet Cavalier
95' 1.9 escort LX died on interstate
Definately have broke the timing belt. The turning over faster did it for me. That is a clear sign the timing belt broke.
Sep 13, 2008 | 1995 Ford Escort
Swimways SUBMERGENCY Logo
59 people viewed this question
Top Swimways Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Swimways Pool and Spa Expert? Answer questions, earn points and help others
