Model MFW 9700SQO The washer flashes 02 then f when it is supposed to be spinning.
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
Washer will not spin. Does fill and agitate.
Any error code associated with fail to Spin?
Is this a FAV6800A LED console model or a FAV9800A LCD console model?
Like one of these?
Jul 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My whirlpool washer is not spinning all the time then flashes 02 f
Hi, f-02 means long drain. remove panel below door, pump will be in center right in front of you. Remove cap and clean out pump. Make sure you unplug washer first before you start...
Take care
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will not spin all of the water out after the spin sycle. There is a flashing F2 on the screen.
F/02 = Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Most likely cause is item 1.
  1. Check Screen Filter Assembly for foreign material lint, socks, coins, nails ect. To access the filter remove the lower front panel. The filter (white is located before the pump. Place a pan under the filter and remove it and clean then reassemble.
  2. Check the drain hose and make sure it is not plugged or kinked.
  3. Check the electrical connections at the pump and make sure the pump is running.
  4. If the above does not correct the problem, replace the pump.
Oct 31, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer flashing 02 F. Maytag epic washer won't spin -flashing 02 F about 15 minutes into the cycle. We just had new electrical components put into it.
You need to use the HE detergent. I believe that is a drain problem. By using the regular detergent that causes more suds and in turn clogs your drain
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
My MFW 9700S will not exit the final spin cycle. I'm on 220 current stepped down to 110. Is that a problem?
hellow: i think not related to current the biggest final spine period i see is 8:9 minute if you have more i think it come from the timer may be it has to change
Jun 06, 2009 | Maytag EPIC MFW9700S Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
