Question about Panasonic PT-40LC12 40" Rear Projection HDTV
PT-40LC12 fuse problem
Since I can't find the thermal fuse ( L3 250V, 5A, 115C) for my Panasonic PT-40LC12, can I replace it with a differnet thermal fuse which has this spec 250V 10A 117C ?  Please help
  • Anonymous May 24, 2008
    same problem
I went here for a tech manual for the Panasonic tv.
http://www.ManualsParadise.com
then ordered
Manufacturer: Panasonic
Part Description: FUSE
Part Number: LSJA0411-1
from PartStore.com
it was mounted to the case that holds the lamp. had to remove the back panel, etc. Also think I had to splice in the fuse or something. was a while ago.
mine is broken again. this is getting old between lamps and repairs.
Posted on Nov 22, 2007
    Problem Solver:
  • 16 Answers
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Posted on May 22, 2008
When I turn the power on all I get is a blinking green power light and nothing else. The lamp is new.
Have you checked the thermal Fuse that is located right above Lamp? These sets had problems
with Thermal Fuse. Is all of the Fans working ? Lamp Fan?
Ballast board is what powers Lamp on. You need to also check 2 thermistors,they are known to be bad.
R2901 (180K-800K)
R2911 (40K-130K)
Jan 13, 2011 | Panasonic PT-40LC12 40" Rear Projection...
I just replaced the lamp on my Panasonic PT-40LC12 TV. How do I reset the timer and make the red light go off?
what you need to do is have your remote handy and go up to the tv. Hold volume down the tv and pip on the remote for 5 seconds.
Dec 08, 2009 | Panasonic PT-40LC12 40 in. LCD Television
Ballast problem on PT-40LC12
Feb 01, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Brief picture for 30 seconds, then lamp button blinks
Found that the thermistor/temp measuring device is suspect, no resistance across legs. There is a label there that says F701 see service manual
http://www.goodmans.net/get_item_th-tf117c_thermal-fuse-117-degrees-celsius.htm
tv.
then ordered
from
PartStore.com
i purchased a NTE8115 from my electronics supplier, closest I could find.
Radio shack also has them.
remove the back cover and measure for continuity across the thermal fuse
above the lamp housing.
if open jump it wth a 5 amp fuse, be sure to close the safety switch with
the small blue lever then try to power on.
If comes on ok you will need to replace the entire ballast assembly to get
that fuse.
Panasonic does not have a part number for just the fuse on the PT40LC
series.
It is possible to cut off the fuse and replace with another but dont solder
Dec 22, 2007 | Panasonic PT-40LC12 40" Rear Projection...
No picture Panasonic PT-40LC12 40
tv.
then ordered
from
PartStore.com
that fuse.
series.
Dec 13, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Respond doc
Vulb,
Having had to change the lamp I would suspect the lamp thermal fuse is open... It's located over the duct for the fan housing and solders into the ballast board.. Check it for continuity and if open replace it..
There are several thermal fuses in that unit and not all of them as easy to access as the lamp one.
Good Luck
Bill
Nov 17, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic pt-40lc12
tv.
then ordered
from
PartStore.com
that fuse.
series.
Nov 15, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Thermal fuse
i purchased a NTE8115 from my electronics supplier, closest I could find.  Radio shack also has them.
Sep 25, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT40LC12 - Blinking green power light - no lamp fire up.
Had similar issue but had high resistance across leads. replaced with thermal fuse from RadioShack in the similar temp and everything works great. Info on the original part is on this link. http://www.willas-array.com/prod/products/directory/pdf/sefuse/FUSE_SMG.PDF Hope that helps. Chris
Apr 15, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
497 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
