Question about Vizio L37 Television
Need to replace power supply to vizio l37 hdtv, difficulty level?
  • 92 Answers
Simple. take the stand out first, then the surrounding screws on back cover. Remove back cover and the power supply is just right there. Make sure you wear ESD or you may short out the fuse.
Posted on Jun 16, 2009
  • 12 Answers
SOURCE: l37 tv turns off on own and then will not turn back on
I have same problem and i put in a new power supply and this did not solve problem. I will be changing out main board next and post results.
Posted on Feb 23, 2008
bestdarngood
  • 3037 Answers
SOURCE: VIZIO L37
If anything, try taking it to a tv repair shop and see if they can find something wrong with it by looking at it which I am physically unable to do online. See if they can look at it free and tell them what you have replaced but I don't know what else without looking at it myself. I hope you get it working.
I doubt you can get a free inspection of it but you can try. Possibly let them know how much money you have spent already and maybe they will give a little leeway. Good luck.
Posted on Apr 02, 2008
SOURCE: VIZIO L37 HDTV
daewoo37in(dlt37g1) freeview will not store saying no signal but freeview will install on other equipment using same imput
Posted on Jul 08, 2008
freetek
  • 5568 Answers
SOURCE: Vizio TV (L37) will power up but no picture
The backlight is powered by its own supply (although it may receive input from the main supply) and it sounds like the main supply or one of its outputs has failed disabling the video and sound processing.
Posted on Dec 24, 2008
  • 13 Answers
SOURCE: LCD controller board location on Vizio L37
Display controller is usually under the Main board which you remove to get access to it. Display controller connects to the suis-boards which then send signal to the screen of the TV.
Posted on Mar 20, 2009
Cable port broken off vizio L37
The Main Board will need replacement. Soldering in another cable connector will usually not work in most cases unless you change the entire tuner
Aug 02, 2012 | Vizio L37hdtv10a L37 37" 720p Lcd Flat...
Vizio hdtv went POP then black while watching a program. Reset did not help.
sounds like a power supply failure open the unit and inspect the power supply for any damage type bad capacitor into google and look for any bad caps on ur power supply
replace them
if all else fails replace the power supply
please make sure to disconnect your tv from the mains and wait at least half an hour before doing any kind of work to it as it may still hold a charge that could harm you
May 15, 2012 | Vizio L37hdtv10a L37 37" 720p Lcd Flat...
My vizio l37 hdtv went black it is getting power the light stays yellow and does not go green. tried to rest it through tech support but nothing.
You need to replace the main board (signal). It is the board with all the A/V hookups on it. The part number is a number with 3 sets of 4 numbers and at the end of this number there is a number letter sequence with ( ) parentheses around it. Do a search on ebay and you should find one. Be sure to match the numbers I mentioned to the one on ebay!
Aug 16, 2011 | Vizio L37 Television
VIZIO TV MODEL L37 HDTV CODES FOR THE REMOTE
I found the codes online at DishTV
505,627,775,758,756,885,864
Apr 02, 2009 | Vizio L37 Television
My Vizio L37 is on with no picture
Most likely a defective power supply module which can be repaired to component level. A local svc co. would be your best bet now.
Feb 26, 2009 | Vizio L37 Television
Dec 24, 2008 | Vizio L37 Television
Vizio L37
Check all electrical connections. If standby light is off when plugged in, probably needs Power Supply board replaced. If standby light is on (Orange/Amber color) may need Power Supply board and or Main Board. If set was shutting down on it's own leading up to it not powering on at all, may need Main Board, and possibly Power Board as well. If standby light has changed from Orange/Amber color to Green, the set IS powered on, and you have an issue other than power.
Oct 04, 2008 | Vizio L37 Television
Tv will not turn on.
my vixio l37 will not turn on neither with the remote nor the power unit ,need some solutions
Sep 04, 2008 | Vizio L37 Television
Vizio L37 HDTV -Thanks for your Help
I found another used main board on ebay if your interested. It looks like the same unit I just purchased new.
http://cgi.ebay.com/Vizio-VX37L-HDTV10A-Main-Board-0171-2272-2174-LCD-TV_W0QQitemZ150271150573QQcmdZViewItem?_trksid=p3286.m20.l1116
Good luck,
Ed
Jul 29, 2008 | Vizio L37 Television
L37 tv turns off on own and then will not turn back on
Jan 31, 2008 | Vizio L37 Television
Vizio L37 Television Logo
983 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
