Question about Philips HTS-6500/37 System
Stuck DVDs I used to be able to get stuck DVDs out of the unit by starting to put in another dvd or prying the stuck one with a butter knife.  This doesn't work anymore.  I would not recommend this unit to anyone - have been having trouble with the DVD portion of the until since right after it went out of warranty :(
I put in a DVD yesterday and it got stuck in the machine. no mtter what i did, it wouldn't eject. it just said "No Disc". I read all the posts here and everywhere on the net. none of them worked (Stop +2-5-9), eject right after powering up. So, i called Phillips and the guy told me to unplug the machine and wait at least 5 minutes. then plug it back in, and HOLD the power button down for at least 30 seconds. after about 20 seconds it will flash some stuff on the little screen. keep holding the button. then push eject button. AND IT WORKED. the disc ejected. Now i am going to upgrade the firmware. i let the phillips guy know that they should be embarassed to have sold this unit. i am anxious to see if the firmware upgrade will fix this issue. the download for the firmware can be found at www.philips.com. search for the unit (HTS6500) under support link on top. at least i know now that i can get a disc out if its stuck.
Posted on Jul 16, 2009
Disc inserted improperly now stuck
Carolyn:
Take a butter knife (not a steak knife) and push the diskette into the drive the rest of the way, and then eject it.
Jul 12, 2015 | HP 19-2014 All-in-One Desktop PC - ENERGY...
The cutter is stuck how can I get the cutter off of the champion juicer?
I have had this happen in the past...couple things you might try.... put it outside or in the freezer to cool it down. next i have dumped olive oil 'around' the end of it that is butted against the unit- some should seeps down and then i used a dull butter knife or steak knife to wedge in there to pry it off.(genlty) in different positions. If it is rusted on, well that's another matter entirely. But if it's just stuck, could be that you haven't oiled it each time? or my other guess is they aren't making the cutters like they did 25 years ago as i have had 3 champtions and more problems with the new ones and cutters jamming (i put a coule drops of olive oil into the hole in the cutter each time). and as a last resort a big burly man with gloves and feet to hang on to it and jimmy it off LOL good luck ;-)
Jan 08, 2011 | Champion G5NG853S Household Juice...
Stuck dvd
Same problem! Go to EXIT on the remote. A pull down box will come down. It will have several choices. Choose DVD. From there you will see different operations. Choose eject or whatever u have for getting the disc out. Now the DVD screen won't go off. Just hit the "ch" channel button. Yuo are now back in TV mode. I learned by experimenting. Lady techie
Apr 13, 2010 | RCA B27TF680 27 in. TV/VCR/DVD Combo
2008 Honda pilot with 2 discs stuck in single dvd player
Carefully use a butterknife to remove the discs. I just did this tonight. I stuck the butter knife under the bottom disc and applied pressure, while slightly tilting the jagged part of the knife down. I managed to remove them without scratching the discs.
Dec 06, 2009 | 2008 Honda Pilot
Dvd stuck in dvd player in 06 honda odyssey
I had the EXACT same thing happen with my 2 year-old and our 2006 Odyssey last week! I drove to the dealer today to have them remove it and after banging hard on the side of the DVD player for several minutes, they said it was really stuck and I would have to pay $400 to have the DVD player removed and sent to a repair center. What!?!?!
I came home and decided to try the tweezer idea. I am not handy and I'm eight months pregnant so I couldn't get as close as I would have liked to the DVD player but as soon as I propped the little rubber doors open with the tweezers to take a peek, I saw both DVDs!! I pulled the top DVD out in about 3 seconds. I then turned my car on and the second DVD popped right out!! :) I put the DVD back in to make sure everything worked and it did. I CANNOT believe I was considering spending $400 AND be without a DVD player for weeks while they shipped it off. The DVD I pulled out has a scratch from where the tweezers were holding on to it but it's on the very outside of the DVD and if I do need to replace it, ... we're talking $10-$20 rather than $400 . Sooooo glad I didn't listen to the dealer this time!!! :)
Oct 08, 2009 | 2004 Honda Odyssey
Retractable Iron Cord Stuck
under the knob to press to retract the cord there is a screw,
slacken it ad try to adjust it again.
Jul 26, 2009 | Black & Decker Irons
DVD stuck in DVD player, TV/DVD player combo
I have had this before, get yourself a butter knife, slide it gently into the space, and try to maneurver the dvd back a little, and while you have the butter knife in, push your open/close button, hope this works for you it did for me!
Mar 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Coins stuck in washer
I've used a butter knife or putty knife to pry them up.. just enough to allow the coins to slide back out. Just roll the drum back and forth with the knife wedged in there. Good Luck.
Jan 25, 2009 | Maytag Neptune MAH6700A Front Load Washer
Two dvd's stuck in player thanks to a busy toddler
I had the same problem... my DVD took one in even though it already had one in there... Tweezers did not work until we used a pie server covered in masking tape with the DVD attempting to eject and then grabbed one DVD out. The DVD player works too!
Nov 11, 2008 | Rosen CV7080D Portable DVD Player
Westinghouse 42"lcd dvd player
We got a disk stuck in our Westinghouse also. After aticking toothpicks and butter knifes in there trying to get it out, we were told to unplug the power and plug it back in and try. When we did we could hear the DVD trying to come out. We stuck the butter knife in there and got it to pop up and out. We havent tried to put another one in but when we do we know how to get it out now.
Feb 09, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Philips HTS-6500/37 System Logo
855 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
