Question about Procom ML300EBC Heater
Pilot light seems to high
The pilot light on my Ml300EHBC seems to run to high. It flickers and and has a very distinct pressure sound to it.  FLickers mostly blue to a little orange and seems to be too large a flame.  Is there an adjustment for this?  ALso the fire seems to high in the heater at times.  All new tank, lines installed and tested by gas professional.
  • Anonymous Dec 05, 2007
    The pilot light flickers and and has a very distinct pressure sound to it. Eventually the pilot light will blow out. Tech support had me try blowing out tubes and vent all to no avail. This unit in brand new and has done it since it was installed. Yea while it is still under warranty it looks like it may cost me more money to have a "Professional Installer" look at it.
    Signed: Fustrated in Oklahoma
  • 625 Answers
There may be an adjustment screw for pilot height. you'll have to look at the valve. a pilot should have an inner cone of greenish blue color and the surrounding flame should be a deep blue no yellow or orange tips. the pilot burns pure fuel no air. the main valve does mix air with the gas in order to burn.
Posted on Nov 04, 2007
I have a dyna glow 18000 btu btrand new the pilot just flickers on and off won't light is it because there is too much oxygen if need adjust where is the adjustment screw at
Flickers points to lack of air you may need to clean pilot so its strong and blue . Any adjustment would be near where the pilot supply goes in the the gas valve.
Jan 20, 2018 | Heating & Cooling
I have a Procom ML300EHBC. The pilot lights, then the burner comes on but both shut off within a few minutes. I'm wondering what things would cause this.
Because you are dealing with a gas appliance I suggest be very careful.
I recommend call the gas company and have them come out and check it.
Nov 21, 2017 | Procom Heating & Cooling
Pilot flame flickers when burners on and drops out valve
You should either do a smoke test or use a candle to check for drafts to be sure that it is not a gas pressure issue.
Aug 13, 2014 | Kingsman FDV200 Free Standing Direct Vent...
Desa heater
For (fire) safety, there is usually a thermostat that will turn off the gas if pilot light goes out.
So when you try to light the pilot you will have keep press & hold the pilot gas supply for at least 10 sec until the thermostat is heated up. Then only when the pilot light stays on continually, can you turn on the burner.
Forget about changing to a High pressure regulator!
Dec 24, 2013 | Heating & Cooling
I have a propane fireplace and the pilot flickers when burner is on and flame on burner seems low. I have filled the 100 lb tank, but problem still persists. The pilot used to flicker and go out when...
sound like a pressure problem low gas , check burner is not blocked , check vent on reg is not blocked, check gas line is not blocked , if all this is working then it could be your reg not working
Jan 22, 2011 | Heating & Cooling
I have a Halstead High Ace which will not light up the light flickers then goes off we have fitted a new dectection electrode but still will not light the boiler We also have flushed the system out ....
sounds basic, but make sure the electrode is in the pilot flame
check the overheat thermostat is not jammed on
disconnect and join wires together for temporary override check and run boiler.
Nov 14, 2009 | Water Heaters
Pilot flickers replkaced ther-cup now pilot wont lite/stay lit
Remove the cobwebs and junk from the pilot. Position the thermocouple where the tip can hit the flame to get the most out of the thermocouple.more
Jan 26, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Dyna-Glo RMC-8001SS
Replace the regulator. We had three for three with the same problem.
Oct 30, 2007 | Dyna-Glo RMC-8001SS Heater
Pitco Fryer
Sounds like the burners are dirty remove burners and run under cold water and replace propane gas burns dirty and might have blocked up burners creating a pop at the burners this will then blow out pilot light if this does not work give me a shout
Jul 27, 2007 | Pitco Frialator SG18S Deep Fryer
Procom ML300EBC Heater Logo
762 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
