Question about Radio Shack Pro-2096 Base Scanner
My pro 2096
My screen has vertical black lines. can hear transmissions, but nothing on display.a friend of mine at rs downloaded software that he thought would fix but did not
I have same problem. First unplug and then turn radio on to clear any left over power. Open the radio by removing 4 screws on back, then 4 more screws to remove top of inner case. then you will see a white ribbon cable. This has either come loose or it is not lined up properly on the connector. There are tabs on each end of the connector, you will need a super tiny screwdriver like for use on eyeglasses to open the tabs. Slide them towards the display or front of radio to remove the ribbon cable. I then used some alcohol and a q-tip and cleaned the metal contact point. then I slid the cable into place, and being careful not to touch anything inside radio, turn it on and check display. It took some moving around for me but finally got it to come back. Then close tabs on connector to hold ribbon cable in place. It seems to be a common problem with this radio.
Posted on Aug 01, 2009
  • cgearhar Aug 28, 2011
    I tried this fix three times in the same evening "apparently" without success. But the next day I fired up the scanner and the display was back in action! Evidently the cable and the connector needed a little time to get reacquainted. Don't get discouraged if at first it seems the fix doesn't work.
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
Pro-2096 Digital trunking mobile/ base scanner
hello,
Open the mobile and the refix all the connection inside maybe some loss connection make it faulty.
best ,
melnavz
Apr 29, 2008 | Radio Shack Pro-2096 Base Scanner
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Display keeps going out of the pro 2096, it was repaired once,,,, is there any simple fixes to this?
Unfortunately there is not. This is one of the "gremlins" that plagued the 2096. From what I have been told by other 2096 owners, the problem comes from a fault where the ribbon cable (or flex) joins to the LCD display. You may want to try opening the scanner and checking the connection. Sometimes gently pressing on the joint with a pencil eraser can re-establish the connection.
Sorry I don't have a "quick fix" for you, but hopefully this will help steer you in the right direction for troubleshooting.
Feb 22, 2010 | Radio Shack Pro-2096 Base Scanner
LCD Displaying Red instead of Black, Vertical Lines in Display
I had a similar problem where the screen went to a pink shade periodically. Sony sent me a memory stick, with download instructions, that fit into one of the back ports. The problem has gone away. It was a software correction.
Mar 15, 2009 | Sony KDL-46XBR4 46 in. LCD Television
PRO-2096 digital scanner display lines from top to bottom
you can push on the display with your finger and see if you notice any change, if so it is probably a bad solder joint or crack in a circuit trace on the printed circuit board. Also with the unit unplugged you can open up the case and check for loose plugs by removeing them and then plugging them back in, then plug the scanner back into the wall outlet and turn it on to see if that helped. The voltages inside are low except where the power cord goes into the unit, at the fuse, and on the primary side of the transformer, so dont touch these areas unless you know what you are doing.
Jan 12, 2009 | Radio Shack Pro-2096 Base Scanner
Blank screen goes in and out
My 2096 was doing the same thing with a blank screen. IF, your scanner is scanning normally and the dim button still dims your display, your problem could be the same as mine was. This worked for me and got my display working like new again. First thing to do is to take the covers both top and bottom off to expose your scanners insides.Next, once you can see the inside of your scanner you will see a ribbon cable connected to the main board and also soldered to the display. Take the ribbon out of its coupling connector and gently clean the contacts on the ribbon with a cuetip with alcohol on it, also clean the solder joints on the display face that connect the ribbon to the display with the cuetip and alcohol. Ii then reassembled everything, ribbon back into its connector and made sure the clamping mechanisim on the ribbon was securely holding the ribbon. I pluged the power supply into it and turned it on before reassemblig the case covers to see if it would work. Bingo, it worked like new again. Hope it works for you ! Jim
Nov 04, 2008 | Radio Shack Pro-2096 Base Scanner
I have an 18 month old acer AT3220B TV - it has always had a rather loud humming noise in the background and also the volume adjusts itself?! Now I have a vertical black line down the RHS of the...
The TV reciever is capable of recieving an interference especially if your mobile cellphone is near the TV otherwise the black line which is shown on your screen is not normal,you have to sent your unit the service center.....
Jun 14, 2008 | Televison & Video
Mitsubushi vs4541 red,blue,green vertical lines no picture,very good sound
Try soldering the vertical output IC, sound without picture usually means vertical output is either defective or has bad solder joints. Does your on screen displays work when you press menu?
Mar 12, 2008 | Mitsubishi WS-48315 48" Rear Projection...
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Radio Shack Pro-2096 Base Scanner Logo
295 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
